I shoot a ton of headshots...but I'm looking inspiration. If you could post your favorite UNIQUE headshots(your work or links to others work) that would be amaing.
95% of what I shoot is on white or gray paper. There is a reason why these backdrop are common but I'm looking to change things up and add some accent pieces to my portfolio. Would love interesting backdrop and lighting ideas I can use in studio or on location.
Thanks!
Joe
Going from Hurley's example and others, I don't know if interesting backdrops and lighting ideas are what you need for headshots.
Interesting character and expression rule. Lighting and backdrops should be non-evident.
Headshots should show the person's character and props, lighting, and backgrounds should all be transparent. If you call attention to anything other than the subject it is a failed headshot.
For the "wow" factor, look at some of Dean Collins work from 10 to 20+ years ago (film era).
See if you can obtain the DVD "The Best of Dean Collins on Lighting" by Dean Collins and copies of his Finelight series. www.software-cinema.com may be able to help.
While Dean Collins pictures may be dated, Collins' work still to this day shows how to use lighting to obtain the "wow" factor you seek! Of course, you also have to direct the subject's expression for the right effect.
It depends on what the headshots are for. There is a difference between a headshot of an executive of a company for their website and a high school senior. My point is that replies regarding that lighting should be transparent are not always true....again, depending on what it's for.
I have the Peter Hurley DVD- he's incredible.
Thanks for the Dean Collins suggestion, I will try to check it out.
Kelsey Edwards has some really nice stuff, definitely some good ideas in there.
