p.1 #1 · elizabeth & dan// huntington beach library wedding
Up and running on the blog again (finally). As per last time, IF YOU ARE GOING TO COMMENT, PLEASE NOTE AT LEAST ONE THING THAT COULD BE IMPROVED. I'm fine without any circle-jerking thanks
Also, sorry for the mis-numbered photos, Andrew Ho's forum converter ALMOST worked
p.1 #2 · elizabeth & dan// huntington beach library wedding
The only thing I would say is that I wish you had more pictures of them together... it seems like a pretty low key simple affair that did not last long. The portrait section is not week it is just low key like the wedding... can't decide if that is good or bad.
Either way great work, you're like...umm... the best EVER!!!!
p.1 #3 · elizabeth & dan// huntington beach library wedding
Not a strong image to lead with IMHO. My eye goes right to that box of C%$P, which, unless it holds some sort of special significance should have been moved for the shot.
Is that uncle bob in the last two or your 2nd? Sucks you are both in each other's shots.
p.1 #5 · elizabeth & dan// huntington beach library wedding
That's a very different place to shoot a wedding.
This is nit-picky, but 21A is cropped right at her wrist, making it look like her hand was amputated. How did you get her dress to puff out like that in #7?
p.1 #6 · elizabeth & dan// huntington beach library wedding
Thanks folks.
Doug - Hahaha. Also, I actually did a ton of portraits with them together, but left most out of the blog as I didn't want them to over power the rest of the set (short set in general - not a TON of images that I wanted to show off).
The guy with the fatty camera in the dancing shots is my second. He was in every shot. Blah.
John - She had a pretty funky dress, so when she spun to show it off to her bridesmaids it just naturally puffed out like that. I just clicked the shutter.
