Wedding Resource List
Archive 2012 · Honeycomb Grid for your flash.
Ghost
p.1 #1 · Honeycomb Grid for your flash.
Hi. I noticed a few of you use this modifier on some E-session and even weddings. I'm just wondering to those that use the honeycomb grid, what is a good size?
Is it better to go with 1/4" for a wider light and fall off or 1/8" with a narrower light scatter?
This is for the 580ex series flash. Any thoughts and advise would be appreciated.
Aug 14, 2012 at 12:40 PM
sboerup
p.1 #2 · Honeycomb Grid for your flash.
I use a 1/4" more than the 1/8", but both see their use. Depends on the size of the area you are trying to light.
Aug 14, 2012 at 01:57 PM
Ghost
p.1 #3 · Honeycomb Grid for your flash.
Thanks for your input. I saw Amazon has these Opteka ones for about $13 each. Cheap enough to buy two types.
Aug 15, 2012 at 12:09 PM
widjayaman
p.1 #4 · Honeycomb Grid for your flash.
Maybe I had a bad batch.. but my Opteka grid just kinda split open as soon not long after I got it. My honl is still going strong.
Aug 15, 2012 at 12:45 PM
joelconner
p.1 #5 · Honeycomb Grid for your flash.
same thing happened to me...cannot figure out how to get the thing back together.
Aug 15, 2012 at 12:49 PM
Scott Clark
p.1 #6 · Honeycomb Grid for your flash.
I have an old set of Dynalite grids (10, 20, 30, 40 degree)...they're designed for studio lights, but I can bungee them on speedlights or my old Norman LH-2 heads just fine. It's nice to have all four to choose from, depending on how much coverage you want.
Aug 15, 2012 at 12:57 PM
Ghost
p.1 #7 · Honeycomb Grid for your flash.
Huh. Now I have to do more research. Is the grid flimsy?
Aug 15, 2012 at 12:59 PM
widjayaman
p.1 #8 · Honeycomb Grid for your flash.
Not really. The plastic is the same weight/thickness as the honl. It just seems like it's not glued on as good.. I would think that gluing it would solve the problem ( actually I might just do that.)
Aug 15, 2012 at 01:12 PM
S-Man23
p.1 #9 · Honeycomb Grid for your flash.
I recently purchased the Rogue Gel Pack and came across some of their other products. This grid set looks pretty good. Not super cheap but seems really well made, and it's 3-in-1 design covers all the bases.
http://www.amazon.com/Rogue-ROGUEGRID-Stacking-Honeycomb-Shoe-Mount/dp/B004TGZ7WM/ref=pd_bxgy_p_img_b
Aug 15, 2012 at 02:41 PM
