skibum5 Offline Upload & Sell: Off
| p.1 #1 · Lens Rentals AF test 5D3 vs 5D2 + new vs old lenses!! | |
Very interesting results!
Any lens older than the 70-200 2.8 IS II did much worse with phase AF consistency than with liveview AF on both bodies, 5D2 and 5D3, no surprise, already well known and expected.
Regardless of lens age they all did much worse with phase precision than contrast focus precision on the 5D2.
But with a 5D3, all of the new lenses, on that body only, focus much more precisely!
The 70-200 2.8 IS II was sort of in between somewhat better but not like with the newest lenses.
They found that the new 24mm 2.8 IS, 28mm 2.8 IS, 300 2.8 IS II and 70-300mm IS L all focused much more precisely when used with the new 5D3 (and likely 1DX) AF system than on the older 5D2 and that the 70-200 2.8 IS II possibly focused somewhat better (although they were not sure in this case). They said those few lenses actually focused almost as precisely with phase AF as with contrast liveview AF. The old 300 2.8 IS did not.
So apparently the new AF system can hook into some secret stuff with the newest lens designs.
I wonder if that means that third party lenses are not likely to be able to match the same AF precision of the new Canon lenses on the 5D3/1DX, at least not for some time, since they won't have the special whatever it is that makes the new Canon lenses focus extra well with the new AF system.
Edited on Jul 30, 2012 at 01:35 AM · View previous versions
