Archive 2012 · d800 - trap focus gone
Kerry Pierce
p.1 #1 · d800 - trap focus gone
Thom Hogan has published his review of the d800. He mentions the problem with focus priority that I had asked about here in another thread. Apparently, Nikon has "lost" the ability to trap focus with the d800 because the focus priority settings no longer mean what they mean on earlier cameras. Here's a quote on that from his review.
"Next up we have a doozy: you can take out of focus pictures when you've got the camera set to take only in-focus pictures! A setting of "Focus" doesn't actually mean what it used to. In fact, not only does it not mean what it used to, but it also removes a very useful capability that virtually all higher end Nikon models have had for 30 years: trap focus. This change is so egregious that I made my complaint directly to Nikon: at least give us the option to restore the old functionality via a Custom Setting."
I agree with his complaint. I don't often use trap focus, but I do use the focus priority setting to try to ensure focus lock on critical shots. I don't understand why they did this. If I wanted to use release priority, it has been there to use. I hope that this isn't a "feature" on all the new Nikons.
Kerry
Jul 07, 2012 at 04:50 PM
davidnholtjr
p.1 #2 · d800 - trap focus gone
Maybe this is a bug in the D800 that just needs to be fixed??
Jul 08, 2012 at 07:35 AM
taob
p.1 #3 · d800 - trap focus gone
This is how the Canon focus/release priority worked, and it was one of the few features I missed when I switched to Nikon. I'm glad that it's back! Basically, the thinking is this: it is often better to have an OOF image that no image at all. The old way of doing it, it is possible that the camera simply will not fire at all. That's bad. This class of camera should always take a photo when you want it to. For me, the D800's implementation comes closer to that ideal.
Case in point: if I autofocus on the subject and then recompose, my D700 would not fire while in focus priority mode, even though the image is in focus! This is because it only knows about the area under the active AF point (which is no longer in focus because I recomposed the shot). This meant putting the camera in release priority mode, so it will fire regardless of AF lock.
But if I'm in release priority mode, it is hard to catch quick action shots. Whether I use AF-ON or the shutter button, the camera fires as soon as possible, instead of when I want it to (which is when AF lock is achieved). So now I have to flip it back to focus priority mode. That means a trip through the menu system, as I do not believe it is possible to toggle that with a custom button setting.
Here's how Canon does it, and also the way it is done on the D800. The focus/release priority setting is only in effect while the camera is actively autofocusing. For me, this is when I have the AF-ON button held down. As soon as I let go, the camera instantly and automatically switches back to release priority. Why is this a good thing? Because it takes into account my intentions. If I am pressing the AF-ON button, it means I want the camera to focus the lens. This implies that I don't want a shot to be taken until focus has been achieved. However, if I simply trip the shutter while AF-ON is not pressed, it must mean I want the photo to be taken right away. No menus, no buttons, no switches. The camera just "knows" what I want it to do.
The above situations happen in all of my shoots (weddings and children's photography), and I much, much prefer the D800 in those situations. The D3S acts like the D700 in this regard, and it is a frustrating experience going back to that now that I have the D800. The D3S soemtimes fires when I don't want it to, and sometimes won't fire when I want it to. The D800 very rarely does that.
So Nikon, if you're reading this, please don't take this feature away! Feel free to add a custom setting to toggle between the behaviours, but I would be very sad if you removed it entirely just because there is one person on this planet who actually uses trap focus.
Jul 08, 2012 at 08:59 AM
rd4tile
p.1 #4 · d800 - trap focus gone
As an ex Canon shooter I had to look up "trap focus" to see what the heck he was talking about. My first thought was maybe that feature might be handy for a fast moving object in lieu of pre focusing but in reality if there isn't enough time to hit the shutter when the object comes into the scene I doubt the AF system is going to work quickly enough to make the capture. Can someone who uses "trap focus" on a regular basis explain where this feature gives one superior results. If F&R is unreliable, as taob points out, when using AF-S set to focus priority then I wouldn't this feature either - that would be a deal killer!
Jul 08, 2012 at 09:38 AM
brett maxwell
p.1 #5 · d800 - trap focus gone
Good explanation! So this means that if you have AF set to the shutter button the D800 should behave just like earlier Nikons, right? Since AF would be engaged any time you're pressing the shutter.
Jul 08, 2012 at 09:47 AM
taob
p.1 #6 · d800 - trap focus gone
I have not explored every scenario while using the shutter button for AF (I've been an AF-ON button guy for 10 years now), but I believe you are correct. However, that doesn't help folks like Thom, who I believe rely on the old behaviour when the shutter button is not used for AF. That is, the shutter button is held down and the camera waits until it sees something in focus before firing. I do not believe that is possible on the D800, D800E and D4, but I have not tried very hard to look for a solution (e.g., maybe some combination of LiveView and AF mode?).
Jul 08, 2012 at 10:24 AM
myam203
p.1 #7 · d800 - trap focus gone
This is not true. The camera will absolutely fire after focusing and recomposing in focus priority mode.
Jul 08, 2012 at 10:36 AM
taob
p.1 #8 · d800 - trap focus gone
You are correct in all your assumptions, except one. The trap focus method relies (at least on modern AF cameras) on having the shutter button pressed all the way down. The camera will then wait until AF is achieved before firing.
Normally, you would have AF enabled, and thus the wait time is simply how long it takes the camera and lens to find focus lock. However, if you have AF disabled (i.e., manual focus), you must instead wait for the subject itself to move to the focus distance. Once that happens, the camera fires the shutter. You would do this instead of manually taking the shot because 1) the camera reacts faster than you, and 2) you can leave a camera unattended to do its thing.
Example: You have an Olympic hurdler sprinting towards you on a track. You pre-focus on a hurdle. Now you want a photo of the runner as they leap over the hurdle. One method is to use continuous AF to track the subject, firing off several frames. Another method is to use trap focus, where you wait until the runner enters the focus zone, at which point the camera takes a single, hopefully perfect photo.
Example: You have your macro lens and sturdy tripod set up, with the camera aimed just above a flower where you hope to capture some bees. You manually focus at the spot where you want the bee to land. Using your trusty wired remote, you lock down the shutter button. Without the bee there, the AF point over that spot is not in focus, and thus the camera does not fire. But as soon as a bee lands on that spot, the camera reacts and takes a shot before it flies away again. Instead of you crouching down at bee level for 30-40 minutes waiting for the perfect shot, just let the camera do all the work!
Jul 08, 2012 at 10:37 AM
taob
p.1 #9 · d800 - trap focus gone
Not in the configuration I describe, which is the issue for the people who relied on that behaviour for trap focus. It is possible to do what you say on the D700 if you are specifically in AF-S mode, focus at the desired spot, recompose, then take the shot while not disengaging AF. The camera will then think the AF point is still in focus (because it has not re-evaluated it since achieving lock), and will thus fire. That is not always possible nor convenient.
Jul 08, 2012 at 10:47 AM
myam203
p.1 #10 · d800 - trap focus gone
I see. Carry on!
Jul 08, 2012 at 10:49 AM
Kerry Pierce
p.1 #11 · d800 - trap focus gone
That's what Release Priority is for, it will always fire when you depress the shutter button all the way, regardless as to whether or not the active focus point is on a part of the image that is in focus.
It certainly isn't bad that the camera won't fire if focus lock isn't achieved. The camera knows when focus lock is achieved far faster and easier and more reliably than the user can know. It is especially important on consumer/prosumer bodies, where people already have enough trouble making good images without having the camera not do what it is supposed to do for AF.
That's the way it is supposed to work. Use the AF on button for focus, disable focus on the shutter button, use release priority and the d700 will behave the way you say you want it to.
Again, that's the way all prior Nikons have worked. If Focus Priority doesn't mean that priority is given to Focus, then there's no need to have the feature. What you describe is what the Focus + Release setting is for, where focus and speed are given equal weight.
I think that you could achieve the same end by using either Release Priority or Focus + Release all of the time and using the AF-On button to focus when you want to be sure of focus and using the shutter button to focus and release the shutter, when you want the shot taken without heavy favor to focus.
I don't understand your statement that a Canon won't fire while it is actively autofocusing. Does a Canon have continuous focus like a Nikon? It would seem not, from your statement.
Try the above settings on the d700 and see if it doesn't work the way you want.
We'll have to agree to disagree on this. Focus trapping is a very useful feature as is the ability to prevent the camera from firing until focus is locked. There's no way to do either of those things with the d800 as it is now, which is a big PITA for me and anyone else that uses and has used Focus Priority on previous bodies. If the d4 AF works the same way, I'd bet that there will be a lot of unhappy pros at the coming Olympic games in London.... I had intended to buy a d800, but this is giving me pause. When the time comes, if Nikon hasn't fixed this problem, I'll need to rent one to see if it will work to my satisfaction. It might be okay, since I rarely have used focus trapping. dunno I'd much prefer that they fix it so I don't have to worry about it.
I believe that you can set the d700, d3, etc, to behave as you seem to be saying that the Canon AF works. But, now, there's apparently no way to make a d800 act like a Nikon....... That's sad.... :-(
Kerry
Jul 08, 2012 at 03:11 PM
Mark_L
p.1 #12 · d800 - trap focus gone
It's pretty bad this is gone, what is the point is even having the option there anymore if it does nothing? It was useful to ensure in focus shots at super dark wedding receptions.
Jul 08, 2012 at 04:53 PM
rd4tile
p.1 #13 · d800 - trap focus gone
Kerry
Please explain how the lack of this feature will affect Pro's shooting sports at the Olympics?
How many sports shooters shoot in static mode to begin with?
I'm just not seeing any use for this feature for sports.
Jul 08, 2012 at 05:13 PM
taob
p.1 #14 · d800 - trap focus gone
It doesn't "do nothing". It works as advertised while AF is engaged. Before, it would be in effect at all times. IMHO, this is the more strictly correct behaviour, and certainly suits my shooting style better. The only situation that is affected, AFAIK, is trap focus.
It's even better now, because you can switch between focus priority shooting (i.e., takes the shot only when focus lock is achieved) as well as release priority shooting (i.e., for focus-and-recompose shots) simply based on whether you are pressing on the AF-ON button. Before, you had to go six clicks into the menu to change the option.
Jul 08, 2012 at 06:51 PM
taob
p.1 #15 · d800 - trap focus gone
I find a lot of people don't quite understand the advantages of the way Canon (and now Nikon) implement shooting priority. I started off on Canon, so there never was "another way" of doing things until I switched to Nikon, and went "huh, this is dumb!". Let me see if I can try to explain it differently here, without confusing more people! I'm going to condense a few sentences together to illustrate my point:
Everything you say above is true. The problem on older Nikon bodies is that sometimes I want focus priority behaviour, and other times I want release priority behaviour. On the D700, toggling Priority Selection (Nikon's term) requires a minimum of three button presses, and that's if I sacrifice the first My Menu item to this setting. Otherwise it can take between 4 and 8 presses of three or four buttons, and about 1 to 1.5 seconds with my eye away from the viewfinder. That's far, far too fidgety for me. Now on the D800, toggling Priority Selection simply means pressing on the AF-ON button, or letting it go. That takes, what, 1/10th of a second? It is 10 to 15 times faster, does not require that I move my eye from the viewfinder, and I can hit the AF-ON button with 99.999% accuracy.
It does still mean that. The difference now is that it only applies while AF is engaged, which makes sense. If I am not actively autofocusing when I shoot, then it most likely means I just want the shot to be taken, and thus release vs focus priority is irrelevant. I say "most likely" because of the trap focus scenario.
No, that's not the same. I want either focus or release priority given 100% weight each, but at different times. Focus+Release tries to balance both at the same time. Also, F+R is only available in AF-C mode, whereas I need the ability to instantly toggle between focus and release priority in both AF-C and AF-S modes.
Yes, Canon has "AI Servo" ("AF-C mode" in Nikon speak). There is a C.Fn in the 1D bodies (not sure about the other models) that lets you tweak how much emphasis the camera should place on higher frame rate vs. focus accuracy.
What I was describing on the Canon side is in "One-shot AF" ("AF-S mode" for Nikons). This may have changed in newer bodies, but when I was shooting Canons, they did not give you the ability to choose between focus and release priorities in One-shot AF mode. It would automatically engage focus priority during AF (e.g., when the shutter button was half-pressed, or you were pressing the AF-ON button), and then disengage it when there was no AF (e.g., not pressing AF-ON, or lens was in manual focus mode).
Now, for people who focus using the shutter button, a Canon is effectively always in focus priority when in One-shot AF mode. That's simply because you cannot full-press the shutter button without first going through the half-press stage, obviously. But for the BBF (back button focus) people, it is an important distinction.
Nikon changed the way the D800 (and D4, I believe) behaves when it comes to enabling/disabling Selection Priority. If the camera is not actively autofocusing (i.e., AF is disabled, the lens is in manual focus, or you don't have an AF lens), then the shutter will always fire. But if AF is engaged when you press the shutter button, the camera will check your Selection Priority setting to decide what to do. Before the D800, the camera will check the Selection Priority setting at all times, not just when AF is active.
They do work they way I want. The problem is that there is no quick way to switch between the two behaviours, as there is now on the D800.
I was being a bit facetious with my last comment (thus the smiley). Trap focus is very useful when you need it, but in my case, I rarely ever need it. About the only time I used it on the D700 was to do handheld macro shots. I would slowly lean in closer and closer to the object, and as soon as it reached the exact focus distance, the camera would fire. That eliminated my slow reaction time, as well as any camera shake from me manually pressing the shutter button. I can't do that with the D800 now, but I have other ways to work around the problem (like the improved LiveView implementation).
I think the best way for Nikon to keep everyone happy is to add a new custom setting. There would be two settings: AF Only, Always. I would set it to AF Only, while the trap focus people would set it to Always. Done!
I don't know about that. Canon has traditionally dominated the pro sports photography world, although I am seeing more black lenses at events now. Guess what... Canon DSLRs can't do proper trap focus either! I would also be surprised if a significant number of the Nikon shooters used trap focus on a regular basis. Pre-focusing on a particular spot (e.g., race finish line, baseball home plate, etc.) is one thing, but that's not trap focus. The problem with trap focus is that the camera decides when to take the shot. It should be the photographer making that decision. I would rather have a slightly OOF shot taken at the peak of emotion or action, than one taken a fraction of a second too early or too late, but crisply in focus.
Jul 08, 2012 at 07:41 PM
bemyzeke
p.1 #16 · d800 - trap focus gone
I switched from Canon and had no idea what trap-focus was. Now that I know about it, it sounds like an incredibly useful feature, for macro, wildlife, BIF, racing, and even some sports (as a alternate to high speed continuous shooting, which D800 does not do).
Jul 09, 2012 at 12:14 AM
Zebrabot
p.1 #17 · d800 - trap focus gone
"trap focus" was called "freeze focus" on the F5 and was available only if you had the MF-28 databack to enabled this and other gimmicky modes.
There is a large distinction between sounding useful and actually using a feature like this though.
I recall my D700 came in some horrible mode like this where unless the camera could focus, it would refuse to take a photos. It have have been set by some jerk at the store or more likely by really clever people at nikon.
Jul 09, 2012 at 08:33 AM
SoundHound
p.1 #18 · d800 - trap focus gone
I believe that this discussion assumes that the shooter can capture the ultimate moment in a frame or two. That means that he can, compose and time the shot for the perfect posture and expression with no motion blur while the camera also peaks with optimum AF, VR (AE, etc?).
My experience is that there are substantial technical and animate subject variations so I shoot 9/10 frame bursts and select the best shot, or in the extreme, combine the best parts of two or more frames.
That's why my D800e sits by my panoramic view window to record vistas that vary by weather and my D3s and D4 goes with me for everything else (set to continious AF and max fps). Certainly the D800(e) can take fine shots with various work arounds but, as compared to the D3s/D4, it will miss many others.
Jul 09, 2012 at 09:10 AM
Kerry Pierce
p.1 #19 · d800 - trap focus gone
Well, I still don't understand it, because I'm too stupid to operate such complicated equipment. I don't see any advantage to that, but of course I'm more than happy with the way my d3s, d700, d300 and IIRC, the d200 work with the focus, release, or focus+release settings in the menu under AF-C. Canon and the d800 don't allow the user to ensure focus is locked like the older Nikons do. That's not an advantage, it's something that you are used to. As I said before, I think that I can emulate the Canon way, by selecting AF-C and focus+release in the menu, while using the AF-On button and disabling the shutter release button. If you still have your d700 and want it to emulate the d800, I hope you'll give that a try. I'd like to know if that is the behavior you're describing and you're the only one I know that could verify it.
Honestly, I don't understand what you're saying about the AF still working thing. If the AF quits but hasn't achieved focus lock, which is what I think you get with the focus+release setting, that's not much different than just using release. OOF is OOF, no?
I am not an elite sport shooter, so I don't "know" how the guys will shoot at the Olympics. I can only repeat what I've read, which is that some sports guys have expressed unhappiness with the loss of focus trapping. I do know that a lot of folks used the d3 and later the d3s for Olympic and other high level shooting. I also know that the d3s will shoot max FPS frame rate with focus trapping because I just tested it. I presume that the older bodies will do likewise.
I recall reading an article by the SI chief editor about a superbowl shoot. He doesn't share the view that an OOF shot is better than no shot. He was really unhappy with some of the shots his team were submitting. This was when Canon ruled the sidelines.
Dunno how much this change will bother me and I won't know until I buy a new body with this behavior. I do know that I'm glad that I'm not a big user of focus trapping.
Kerry
Jul 09, 2012 at 04:30 PM
Kerry Pierce
p.1 #20 · d800 - trap focus gone
I agree. I use focus lock for most all of my shots. FWIW, other than trap focus, I don't believe that it's gone completely missing, or it would seem logical that there would be a *lot* more OOF shots coming out of the d800.
I think we'll know that it was a bug, if Nikon issues a fix. If they don't issue a fix, then I think we can safely assume that it works the way Nikon wants it to work.
Kerry
Jul 09, 2012 at 04:37 PM
