Archive 2012 · A couple of Hummers
viczig
p.1 #1 · A couple of Hummers
Among my first attempts at shooting them, I'm not to happy with the dark background caused by the flash.
Jul 06, 2012 at 12:53 PM
p.1 #2 · A couple of Hummers
You have beautiful detail Vic.
It is not the flash that is causing the dark background, it is your ambient exposure. What you need to do is expose for the ambient light as if you are not using flash. The ISO you chose is very low and you want one that will give you a reasonable fast shutter as the ambient exposure will be part of your exposure. I like to do my primary exposure in manual and use auto flash though you can use auto exposure if you like. As you are shooting Nikon you can take advantage of the wonderful Nikon CLS feature called Balanced Light. This will require your setting your metering mode to Matrix so that the camera can meter the background and tell the flash to expose to put the same amount of flash on your subject as is on the background. Also enable High Speed Sync on your body to allow the use of flash at high shutter speeds. Set your flash for TTL-BL and you should be close to where you want to be if not spot on.
Good luck,
Jul 06, 2012 at 01:45 PM
viczig
p.1 #3 · A couple of Hummers
Thanks Morris I'll give it a go.
Jul 06, 2012 at 03:39 PM
Ted ellis
p.1 #4 · A couple of Hummers
Victor, I have no problem with a dark bg. In many cases I seek darker bgs when shooting hummers. Some noise reduction greatly enhances your image(s).
Ted
Jul 06, 2012 at 03:47 PM
Tim Kuhn
p.1 #5 · A couple of Hummers
For my eye the dark background works nicely, it is the bright objects in the background that I find distracting. The bird is tack sharp and beautiful
Tim
Jul 06, 2012 at 05:02 PM
Jonathan Huynh
p.1 #6 · A couple of Hummers
Excellence.
Jul 06, 2012 at 11:17 PM
kmunroe
p.1 #7 · A couple of Hummers
great set of hummers Vic
Jul 07, 2012 at 03:39 AM
