Archive 2012 · Newbie with a 1D Classic
tamle
p.1 #1 · Newbie with a 1D Classic
Hi all,
I just purchased a Canon 1D classic today and am looking for some advice. I've never owned a DSLR until today. and I'm wondering if I have my bearings straight. I would like to take scenic/landscape photos and from my research I plan on picking up the following lenses in this order when I can manage the funds:
EF 50mm f/1.8 (MK I if poss.) ->
EF 85mm f/1.8 USM ->
EF 24-70mm f/2.8L USM ->
EF 50mm f/2.5 Compact Macro (for photographing coral my aquarium)->
Fisheye (in my dreams/for fun)
I should be "set" after that, right? I'd also like to take night time landscape shots, but that should just require managing the settings correctly, yes? I tried on the gf's Nikon D3100 once and failed. If there are lenses from other makers that I should consider instead of the ones listed, please fill me in on your opinions. Lens acquisition will be a slow journey, no doubt.
Also, if anyone has any 1D specific/newbie accessories they're looking to sell, please send me a PM. All I have so far is the body, battery and charger. I'm particularly after the OEM charger (NC-E2) as my bundle came with an aftermarket charger/batteries. Thank you for your consideration.
Tam
Edited on Jun 04, 2012 at 10:45 AM · View previous versions
Jun 02, 2012 at 11:51 PM
NygaardDK
p.1 #2 · Newbie with a 1D Classic
If your primary interest are landscapes/scenics I would say your order of purchase is a bit off.
I would start with the 24-70 - or even better for landscapes the 17-40L which is cheaper. 24mm isnt that wide on a 1.3x crop - and 50mm and 85mm certainly isnt.
And not to critizise your choise of camera - the 1D is an awesome camera, I have a mk2N - but for landscapes I would choose my 5D at any time. 4 megapixel isnt a lot for scenics, leaves no room for cropping whatsoever.
But to make it short - with your interests my first purchase would be something wider than 50mm.
Jun 03, 2012 at 03:28 AM
ultrapix
p.1 #3 · Newbie with a 1D Classic
It looks like a bugdet oriented choose. If so, there isn't a better choice than 50 1,8; BTW, just a little more expensive, the 35/2 may fit better your need.
Jun 03, 2012 at 03:50 AM
Alan321
p.1 #4 · Newbie with a 1D Classic
I'd skip the 50 f/1.8 and get the 50 f/2.5 CM instead for the added versatility. However, a 17-40 f/4L is likely to be more useful for landscapes that need a wide angle of view. Not all do, but enough do to justify a 17-40. It makes a better walk-around lens too.
Before long you'll be wanting a newer camera with more pixels and more mod cons.
- Alan
Jun 03, 2012 at 04:25 AM
Dragonfire
p.1 #5 · Newbie with a 1D Classic
I always liked the 17-40L on the 1D and the 50 CM is excellent everywhere.
Lenmar batteries work well and a 4gig card formatted to FAT in your computer also works.
Enjoy
Jun 03, 2012 at 06:04 AM
omarlyn
p.1 #6 · Newbie with a 1D Classic
tamle wrote:
Hi all,
Tam
Hmmm...your first DSLR is a (classic) 1D Don't get me wrong, I love the ol' 1D...In fact, I have two that I regularly use and the 1D is STILL a very capable camera but I would hardly recommend it as a first DSLR. The menu is rather 'cluncky' and the interface to get to all the custom functions requires the old Firewire interface and a copy of the old Eos Utility...it's not exactly user-freindly.
As for your choice of lenses for landscape use...the easy answer you'll get from most people is to get a REALLY wide angle lens...however, there are other ways to do landscape. You can take 'intimate' landscape with a longer focal length and isolate on a particular subject or plane. Further, many of the historically 'classic' landscape images were taken with an equivalent 'normal' focal length which in the case of the 1D would be approximately 40mm.
A search here for 1D batteries will show an almost universal recommendation for Lenmars...I use 'em and get well over 1,000 shots per charge. The OEM charger is nice because it has a 're-fresh' function that does a complete discharge/recharge cycle...they typically go used for about $100 (no more than $120).
That's my 2 cents...just something to consider....YMMV...good luck.
Omar
Jun 03, 2012 at 11:31 AM
anthonygh
p.1 #7 · Newbie with a 1D Classic
What is your budget?
If it is low...research the USM 24 - 85mm
If it is reasonable...research the 17 - 40L ...and consider changing your body. A 40D will be much better for what you want to do.
Remember you might need other stuff...a decent tripod and filter set for example...not cheap.
Jun 03, 2012 at 02:53 PM
Hammy
p.1 #8 · Newbie with a 1D Classic
Oh my, nothing like other people to spend your money for you!
I will agree with others, glass will be key to your growth in photography. Good glass will outlive several generations of bodies.
However, I believe you are a crossroads of Getting Started Street and Budget Freeway.
The nifty fifty (f/1.8) will get you a long ways before satisfying your itch to get the better glass recommended here. Great landscapes can be had at 50mm and stitching. Cheap to free software will get you high resolution landscapes with a little technique.
Adding lens extensions can get you some decent macros before committing to a macro lens.
The only drawback to the 1D classic (I have two of them, along with 2x Mk2Ns and 7D) is that exposures more than about 15 seconds generates amplifier blooms in two of the corners of the sensor:
http://www.thecgo.com/id31.html
Options are to crop the image within the affected area as noted, or work with shorter image durations and stack the images.
The 1D is a great body - a milestone when it came out. You'll be able to get great images. I highly recommend reading the manual a couple times to understand the full capability of options available to you.
Jun 03, 2012 at 06:26 PM
jasonpatrick
p.1 #9 · Newbie with a 1D Classic
+1 - no sense having two 50mm's, especially since the 1.8 needs to be stopped down a bit to get really sharp. the 2.5 is good wide open. The 17-40 will suit your landscape needs. After those two the 85 or 70-200mm f/4 would be a good addition.
4mp's isn't much, but I'd rather dive into DSLR's with a 1D classic than a t3 for sure.
Jun 04, 2012 at 09:32 AM
lexvo
p.1 #10 · Newbie with a 1D Classic
I agree with the others: start with the 50/2.5 CM.
And here are some old articles I wrote about the 1D
http://lex1963.home.xs4all.nl/foto/Lex/1d_classic.html
http://lex1963.home.xs4all.nl/foto/Lex/1d_high_ISO.html
http://lex1963.home.xs4all.nl/foto/Lex/1d_concert.html
Jun 04, 2012 at 10:42 AM
tamle
p.1 #11 · Newbie with a 1D Classic
The reason the list is in the order it is is because of $$$ and my lack of it at the moment. Starting with the 50mm would be least costly and still allow me to shoot and practice even if it isn't the particularly type of photography I'm trying to pursue.
Quite right ultrapix, I've always been struggling to find the money to pick up a DSLR and something that isn't a Rebel or lower end Nikon. Thanks for the suggestion on the 35/2, I will look into it further.
- Alan
Thanks for your advice, Alan. I'll keep it in mind and have added it to my list of advice and lens suggestions. I'd love a newer camera (Wouldn't we all? ) but I think the 1D will be a great place to start.
Enjoy
Another vote for the 17-40L added to the list. I've read that others have had success with Lenmar batteries, sure enough one was included in the sale. Now I just need that OEM charger to I can "refresh" it. Is there a particular brand/speed of memory card you would suggest? Thanks for your input Psychic1.
Hi Omar, the reason I chose the 1D to start with was because of a thread here on FM. A lot of users were commenting on how they wished they'd never sold theirs or how they still put it to good use so many years after it's release. As far as customizations go, my macbook has a f/w port so I'll have to find a cable and look into that, thanks for mentioning it and the advice on shooting. The hunt continues for the OEM charger!
My budget low. Low to the ground low. I will take into consideration the 24-85 per your suggestion and add another + next to the 17-40. I'll also look into tripods. Can you generically suggest a filter set or do they differ for intended use? I'll look into that some. Thanks, Anthony.
Thanks for your advice, Hammy. I feel like you get where I'm coming from. I intend on reading the manual many times (when I can find a copy.)
Do you think that a 50 f/1.8 + extension tube would work just as well as the 50 f/2.5? Another +1 to the 17-40 on my advice list and have taken note of your other suggestions. Thanks, Jason.
Interesting, that makes it 3 votes for the 50 f/2.5. I've always read about how great the "nifty fifty" is but I'll have to really consider the "nifty fifty 2.5." Thanks for linking to your articles, Lex. I'll give them a read when I get out of class later today.
I'd like to say again that I am extremely grateful for all of your input. All of your comments have got the gears in my head turning and I'll be able to make better informed decisions because of that. Thank you. Also, if you have any more fuel to add to the fire, please don't hold back!
Jun 04, 2012 at 11:52 AM
Dragonfire
p.1 #12 · Newbie with a 1D Classic
The 1D is a focus machine and for that reason you might be best to start with the 85-1.8 and learn the camera.
Any 4 gig card is fine and I would purchase Lenmars with a 3 year warrantee and return if they die instead of the OEM charger.
Lightroom 4 noise reduction does wonders on high iso raw files.
Enjoy.
Jun 04, 2012 at 12:09 PM
jasonpatrick
p.1 #13 · Newbie with a 1D Classic
The nifty 50 is a great lens, but the 50mm 2.5 is more versatile as it does 1:2 macro, which adds to it's value. That, plus the sharpness wide open and the build quality (metal mount) are the reason's it's my pick over the 50 1.8. I've never tried a 50 1.8 with extension tubes. While those can be effective, you loose infinity focus, actually depending on the size of the tube you can loose everything beyond a few feet.
I own the 24-85 and use it on a 1DII. It is a good value lens and can be had for 150 or so used.
Jun 04, 2012 at 03:21 PM
jboucher50
p.1 #14 · Newbie with a 1D Classic
congratulations! I hope you enjoy exploring your new DSLR! Read the manual and take LOTS of pics.
the 50mm f1.8 is a great lens to start. If you primary interest is landcape I would suggest a 35mm f2 or 28mm f2.8.
Also, don't forget a tripod with a good ballhead.
Jun 05, 2012 at 09:52 AM
vokoun29
p.1 #15 · Newbie with a 1D Classic
You'll love that 1d. I still keep mine by the back door with the 70-200 on it, ready for birds or whatever catches my eye. They're built like a tank, and I think they make incredible photos. 4mb makes great images unless you need to crop a lot or want to make a billboard.
Shoot everything in raw format. That's probably the best advice I got when I got my 1d. You'll be able to see that you missed an exposure, but may be able to save it or even turn a missed exposure into something interesting.
Jun 05, 2012 at 08:31 PM
Mike Tuomey
p.1 #16 · Newbie with a 1D Classic
+1 for the EF 35/2
Jun 05, 2012 at 08:36 PM
tamle
p.1 #17 · Newbie with a 1D Classic
Enjoy.
I've had good luck with Transcend cards in the past so I'll pick one of those up from Amazon and I'll pick up Lenmars when the time come for battery replacement. I appreciate you coming back and following up. Thanks!
Noted, I have the 50mm 2.5 as numero uno on my list in place of the 50mm 1.8. I actually just missed one on CL that went for $150.
Thank you very much Mr. Boucher! Hammy was kind enough to provide me with a copy of the manual that I've started to look over. I'll add another +1 to the 35mm f2 and add the 28mm f/2.8 to my list. Thank you for your input.
I don't think I'll be cropping too much or filling a billboard any time soon. I'll heed your advice and shoot in raw format. Thank you for the tips!
Mike Tuomey wrote:
+1 for the EF 35/2
+1'd.
Jun 06, 2012 at 02:23 AM
Ian.Dobinson
p.1 #18 · Newbie with a 1D Classic
I've had good luck with Transcend cards in the past so I'll pick one of those up from Amazon .
just a quick point on the CF cards.
the 1D Nativity supports upto 2gig. you can use 4 gig but you have to format the car on a PC (dont know about a mac) . I cant remember exacly how you had to format the card but i seem to remember it had something to do with cluster size . (someone on here will remember and run you thru it).
But you must remember to NOT format the Card in the camera. if you do you will have a 2gig card. I did it once and it was a real pain to get the 4 gigs back . reformatting on the PC did not sort it. I think I had to download a utility to do it.
Personally I would stick to a bunch of 2 gig cards. the file sizes are small anyway and its alot less hassle.
I will also echo those above. the 1D would not have been my first choice as a 1st digital . but its a great camera.
i would more likely have chosen somethin a little more mainstream like the 5D (mk1)
but anyway you have the 1D now and Im sure you will enjoy it
By the way beware. I had a 1D as a 'plaything' . I sold it quite quickly but always hankered after other 1 series. currently have a 1Dmk2n (2nd one ive had) and would jump at a 1Ds2 if I see one at a good price .
Jun 06, 2012 at 05:40 AM
campyone
p.1 #19 · Newbie with a 1D Classic
If funds are a major concern and if landscapes are your major area of interest I'd suggest forgetting the f/2.8 24-70 and substitute the f/4 24-105. You probably won't need the wider aperture of the 2.8 vs 4 for landscapes very often if ever, especially if you use a tripod, and the 24-105 gives you more flexibility at the long end. I'd also forget the 17-40 someone mentioned if it were me. I have that lens and it's the first lens I leave at home when I want to lighten my backpack. I find it too wide for the kind of landscapes I do and too limiting at the long end.
I'm also not sure why you want to stop at 85mm on the long end. Maybe "landscape" to you means "vistas" and "wide angle of view" which is certainly fine if that's the case. But for me "landscape" includes more than that so I use my 70-200 quite a lot for landscapes. You could pick up a used earlier version of the f/4 70-200 very inexpensively (as Canon lenses go) and greatly expand your range and flexibility compared to an 85mm prime.
Obviously like anyone else here I can only say what would be best for my vision. Yours may be different and if the lenses you list seem like they'd work for you, that's fine. Just enjoy your new camera regardless of what lenses you end up with.
Jun 06, 2012 at 06:19 AM
Wobble
p.1 #20 · Newbie with a 1D Classic
Here is the link to your reading assignment (with downloads available for various utilities):
Canon Brochures and Manuals
For tripod and ballhead, try Feisol...FEISOL Homepage
Jun 06, 2012 at 06:45 AM
