Archive 2012 · Need Quick Plate suggestions to use with BlackStrap
jsjames
p.1 #1 · Need Quick Plate suggestions to use with BlackStrap
I just bought the PhotoClam PC-69-UP3 mounting plate for my 70-200 L and was hoping to use the Fasten RT1 for my strap, however the RT1 is too wide to screw into the plate since the location for the RT1 to screw in is on the end of the plate and the RT1 is wider than the original screw.
Does anyone use a "universal" lens mounting plate and a blackrapid strap? I was hoping to use a mounting plate that is flush so it can sit on a table. Unlike a typical tripod mounting plate that is not flush.
Photo Clam PC-69-UP3
Black Rapid Fasten RT1
Maybe this one will work? Looks like it allows more room for the RT1 to screw in.
Desmond P-70
May 24, 2012 at 03:01 PM
M635_Guy
p.1 #2 · Need Quick Plate suggestions to use with BlackStrap
the RT1 is for Manfrotto.
I have a setup to let my L-bracket stay on when I use my BR-7.
br_fix640x480 by e24mpwr, on Flickr
20111220-143937 by e24mpwr, on Flickr
Full write-up on my blog:
http://enthusiastphotographer.com/2011/12/20/black-rapid-arca-solution/
May 24, 2012 at 04:49 PM
surf monkey
p.1 #3 · Need Quick Plate suggestions to use with BlackStrap
You might take a look at this:
http://www.customslr.com/products/m-plate-pro
May 24, 2012 at 05:30 PM
jsjames
p.1 #4 · Need Quick Plate suggestions to use with BlackStrap
That is on my list!
May 24, 2012 at 05:34 PM
M635_Guy
p.1 #5 · Need Quick Plate suggestions to use with BlackStrap
The setup I'm using costs less and works better IMHO
May 24, 2012 at 07:12 PM
dfresh
p.1 #6 · Need Quick Plate suggestions to use with BlackStrap
Nice setup Lee! I will have to consider doing the same...
May 25, 2012 at 04:01 PM
M635_Guy
p.1 #7 · Need Quick Plate suggestions to use with BlackStrap
BTW - I'm not being defensive about my setup. I found it very clumsy that the strap stays on the body while it is on the tripod. It also doesn't account for an L-plate. I think the protrusion of the mounting point for the strap under the lens seems...wrong and in the way. Top it off with being expensive, and I'm just not a fan.
My setup (which wasn't invented by me - I just pushed several ideas together and thought a bit about where the safety strap should go) is super fast, easy, flexible (works with my 80-200 RRS foot plate or another body if I had one) and is less expensive.
May 26, 2012 at 04:26 PM
