Can anyone tell me if the NR engine from LR4 is the same like the one in LR3 ? I know that is called PROCESS 2012 ,is called like that because of the new tools (the replacement of the "recovery" and the other sliders) and the NR is the same like in LR 3 or even the NR engine is also different (from what I see, there is no difference ).Thank you in advance !!!
Although it is somewhat the same I believe they have made some improvements in it. From what I've read, and what little playing with it I've done, it doesn't give the image that plastic look nearly as bad as before. Now if you use it cranked way up you will still get some of that, just not as bad.
