Archive 2012 · GT1541T vs GT1542T
fracas
p.1 #1 · GT1541T vs GT1542T
I just ordered the 1541T, but my dealer has currently in stock the 1542T ...
Apart from the differences in length and weigth, there are quality differences between the two tripods?
Thanks,
Francesco
May 19, 2012 at 07:16 AM
sjms
p.1 #2 · GT1541T vs GT1542T
the 1541T has been discontinued the 1542T replaces it
http://www.gitzo.us/series-1-carbon-6x-traveler-tripod-4-section-with-g-lock
http://www.gitzo.us/traveler-series-1-4-section-tripod
the 1542T is approx 9cm taller overall.
Edited on May 19, 2012 at 07:46 AM · View previous versions
May 19, 2012 at 07:42 AM
fracas
p.1 #3 · GT1541T vs GT1542T
ok, thanks ... so it is a no-brainer decision!
May 19, 2012 at 07:44 AM
sjms
p.1 #4 · GT1541T vs GT1542T
evidently they found a way to get blood out of a rock as they added material and lowered the list price a bit. magic, isn't it?
fracas
p.1 #5 · GT1541T vs GT1542T
in Italy the 1542 is 30 euros more expensive for 30 grams more ... I arrived late
May 19, 2012 at 07:57 AM
sjms
p.1 #6 · GT1541T vs GT1542T
in the US the 1541T list price is $667 the 1542T is $756. i do believe i made quite the, Ooops!, little price error. forgive me. the blood out of the rock they have found turns out to be yours.
May 19, 2012 at 08:36 AM
pompeio
p.1 #7 · GT1541T vs GT1542T
I debated last year between the GT1541T and the GT1542T.
The GT1541T has greater weight capacity (17.6 lbs vs. 15.43#), is barely lighter (2.1 lbs vs. 2.2 lbs.), is slightly shorter when folded (16.1" vs. 16.73") and has shorter maximum height (44.5" vs 45.87"). I did not consider the maximum height with column extended as I remove the column (do not what a modified monopod).
I bought the GT1541T as it had the greater weight capacity and the others differences were fairly negligible. It was, and is, cheaper than the GT1542T.
May 19, 2012 at 10:50 AM
Lars Johnsson
p.1 #8 · GT1541T vs GT1542T
According to both the Gitzo website, and to their catalog. Then the weight capacity (load rating) is exactly the same on those two tripods. 8kg or 17,64 lbs
May 20, 2012 at 02:45 AM
sjms
p.1 #9 · GT1541T vs GT1542T
i concur with you Mr Johnsson
May 20, 2012 at 03:51 AM
peter_n
p.1 #10 · GT1541T vs GT1542T
I sold my 1541T a few weeks ago.
A new 1541T sold on eBay recently for $760!
May 21, 2012 at 04:26 PM
pompeio
p.1 #11 · GT1541T vs GT1542T
Prior to purchasing the GT1541T I contacted Gitzo and was told the 1541T had a greater weight capacity than the 1542T and that it was a misprint on their site. It appears they never corrected it. If one takes the time to go to B&H's site you can still pull up the specs for the discontinued 1541T and compare to the 1542T. Several test reviews also gave the different weight capacities when they made comparisons.
May 21, 2012 at 08:25 PM
Lars Johnsson
p.1 #12 · GT1541T vs GT1542T
It's obvious jus B&H that have a misprint on their site. Every other store I looked at have the real load capacity of 8kg.
Gitzo have 8kg both in their printed catalalogs and in their PDF catalogs. Not only the latest catalogs but everyone from 2008 until todays. And they also have 8 kg on their website and have had that for years,
It's also obvious that 8kg or 17,64lbs is the right load rating. All the other series 1 tripods that are similar and CF have 8kg. Like the 1541, 1531, 1540, 1530, 1540G and so on.......
May 22, 2012 at 12:12 AM
sjms
p.1 #13 · GT1541T vs GT1542T
nothing like truth in a dvertising
May 22, 2012 at 09:03 AM
Suresh T
p.1 #14 · GT1541T vs GT1542T
I'm in the market for a tripod upgrade, and am a bit puzzled by the prices mentioned above, since I see a *new* 1542T selling for $550-$600 on a couple of different "mainstream" websites.
Does the $700+ price above include a ball head or something?
May 22, 2012 at 06:15 PM
peter_n
p.1 #15 · GT1541T vs GT1542T
The item that was sold was a brand new tripod in its box with all of the box content intact. As if you bought it from a store. No ballhead.
Gitzo have recently redesigned most of their range and some prefer the earlier models, so when hard-to-find items appear they go for artificially high prices.
May 23, 2012 at 07:34 AM
Lars Johnsson
p.1 #16 · GT1541T vs GT1542T
In Europe all the old versions sells with a discount. Often 25-40% lower than the latest version
May 23, 2012 at 12:15 PM
