Archive 2012 · Resizing in photoshop
cowski54
p.1 #1 · Resizing in photoshop
I have a picture I would like to print an 8x10 of...My current pixels are 4190x2459...can anyone help...Thanks
May 17, 2012 at 07:48 PM
Monito
p.1 #2 · Resizing in photoshop
It would help if you explained in detail what steps you thought through and where your thinking bogged down.
You will have to crop it. 8 x 10 is in the ratio of 4:5 or about 1 to 1.2. 4190 x 2459 is in the ratio of 1 to 1.7 (from 4190 / 2459), which is wider than a DSLR ratio.
When you've cropped it to an 8 x 10 ratio, you will have 2459 x 1.2 = 2951 pixels on one side and 2459 pixels on the other side.
Another altermative is to add black pixels on two sides until you have an image that is 4190 on one side and 3352 pixels on the other (with two black bands, since 4190 x 0.8 = 3352. The reciprocal of 1.2 is 0.8. Or you can think of the 8 inch side as eight tenths of the ten inch side.).
The third alternative is to combine the two approaches: crop a little and add a little black.
It may seem tricky the first time you do this, but this is all basic fourth grade arithmetic and sixth grade geometry. So do it and practice it and think about it six ways sideways until you master it. It is really fundamental and needs to be mastered.
May 17, 2012 at 08:33 PM
cgardner
p.1 #3 · Resizing in photoshop
The simplest way I know in Photoshop is to select the crop tool, enter 8 x 10 for dimensions and the desired output resolution then drag the crop tool across the photo in the edit window, selecting the part of in you want to fit those proportions.
The value for resolution you'd enter would vary depending on what you are printing it on. For example if the printer has a native resolution of 300ppi then you'd enter 8 x 10 and 300 and wind up with file which is 2400 x 3000 pixels.
The Help function in Photoshop is a good resource for questions like this:
http://helpx.adobe.com/photoshop/using/adjusting-crop-rotation-canvas.html
May 17, 2012 at 09:06 PM
cowski54
p.1 #4 · Resizing in photoshop
Your Awesome thanks to all of you for suggestions and help...got it
May 17, 2012 at 09:13 PM
