Archive 2012 · Nikon 105mm 2.5
jekmandco
p.1 #1 · Nikon 105mm 2.5
First time I have posted in the ALT forum.
Pretty much wondering if this Nikon 105mm f2.5 is something worth keeping. I have a Canon 40D that I shoot with, and thought it would be fun to play around w/ some older stuff, but dont know anything about what is worthwhile and what is not.
Anyone have one that can show me some sample shots? :-)
May 14, 2012 at 07:48 PM
cputeq
p.1 #2 · Nikon 105mm 2.5
Very good lens, though I'm not sure how much I would like it on a crop camera because (to me) ~160mm is a lot less useful than 105mm. It would probably sing on an old 5D though
I wouldn't hesitate to keep it, but that's me!
May 14, 2012 at 08:04 PM
Reagan
p.1 #3 · Nikon 105mm 2.5
go to the Nikon Manual focus thread and you will see a lot of photos there taken with that lens
but they were all taken with Nikon cameras that is the intent of the thread Nikon camera's and nikon manual focus lens
Reagan
May 14, 2012 at 08:17 PM
OpticalFlow
p.1 #4 · Nikon 105mm 2.5
In my opinion a no-brainer - worth keeping. There are several different versions, all are good). You'll find many samples on flickr. I use mine on a 5D II and have used it on the 550D before. Have to agree with cputeq - I also find 105mm a more useful focal length on full frame.
May 14, 2012 at 08:39 PM
JimBuchanan
p.1 #5 · Nikon 105mm 2.5
This is a classic lens, on full frame, and a worthy contender for the focal length. You just have to accept the fact it focuses in the wrong direction from Canon and Leica.
May 14, 2012 at 09:03 PM
jekmandco
p.1 #6 · Nikon 105mm 2.5
I was doing some reading through the FAQ in this forum, and was on the Leitax webpage.
Is this lens that I mentioned a Nikon G lens?
May 14, 2012 at 09:27 PM
AhamB
p.1 #7 · Nikon 105mm 2.5
No, the Nikon G lenses are all modern AF lenses without an aperture ring to control the aperture. Your 105/2.5 most likely is an Ai or Ai-S lens and can be adapted to your 40D with a simple adapter from Fotodiox or a similar brand. You don't need a Leitax mount replacement.
May 14, 2012 at 10:05 PM
OpticalFlow
p.1 #8 · Nikon 105mm 2.5
And as it hasn't been mentioned in this thread yet - the "Afghan Girl" portrait was shot with this lens:
http://en.wikipedia.org/wiki/Afghan_Girl
May 14, 2012 at 10:55 PM
mcbroomf
p.1 #9 · Nikon 105mm 2.5
There are 2 different types of this lens, earlier sonnar design and later gauss. The gauss design is reputed to be better. PC indicates a multicoated lens (vs earlier P).
http://www.naturfotograf.com/index2.html
You have to navigate to Lenses then skip the next page and choose medium long lenses to get Bjorn's descriptions.
Mike
May 15, 2012 at 04:20 AM
jekmandco
p.1 #10 · Nikon 105mm 2.5
Mike
I read through the page you described although I am still unclear on where the markings should be to differentiate the 2 different types. any help?
May 15, 2012 at 05:36 AM
LightShow
p.1 #11 · Nikon 105mm 2.5
There are more than 2, there are those with metal focus rings, a silver nose, and a black nose, the name ring says "Nikkor P" or "Nikkor P.C"(multicoated), then there are the rubber focus ring version(s?), The mounts are important to consider when mounting on Nikons, Canons don't care about
those differences.
May 15, 2012 at 06:37 AM
mcbroomf
p.1 #12 · Nikon 105mm 2.5
The P or PC are on the front of the lens.. just look thru ebay pics and you'll see the differences. If you decide to get a P then you'll need to verify with your buyer if you're getting a sonnar or gauss. There may be a way to tell but I don't know.
As Lightshow said there are many actual versions.. about 8 I believe.
Mike
May 15, 2012 at 06:58 AM
AhamB
p.1 #13 · Nikon 105mm 2.5
You can identify your type of lens with this table (click on the links on the left to see pictures of the lenses): http://www.photosynthesis.co.nz/nikon/specs.html#105
By the way, as far as I know the Gauss design is the most common type you'll encounter. At any rate, the lens should be worth the cost of an adapter unless the optics are in really bad shape.
To clarify: all types of this lens have the same Nikon F mount and all regular Nikon to Canon adapters are made for this mount. Just buy an adapter and enjoy the lens.
Edited on May 15, 2012 at 08:01 AM · View previous versions
May 15, 2012 at 07:40 AM
OpticalFlow
p.1 #14 · Nikon 105mm 2.5
Roland Vink's page has all the versions:
http://www.photosynthesis.co.nz/nikon/serialno.html#105
May 15, 2012 at 07:43 AM
OpticalFlow
p.1 #15 · Nikon 105mm 2.5
looks like we had the same thought at the same time, Aham
May 15, 2012 at 07:45 AM
jekmandco
p.1 #16 · Nikon 105mm 2.5
this looks like this is the same as mine.
http://www.photosynthesis.co.nz/nikon/ais10525.jpg
as far as I can tell the optics are all in very good shape.
If I remember correctly I acquired the lens from my father in-law who was worked for GE for many years fixing and installing x-ray machines, cat scanners, etc... My understanding is that this was used for some purpose for his job.
May 15, 2012 at 08:37 AM
mawz
p.1 #17 · Nikon 105mm 2.5
That's the last AI-S version.
It's an excellent lens overall, probably the single best value of the non-AF Nikkor's.
May 15, 2012 at 08:57 AM
jekmandco
p.1 #18 · Nikon 105mm 2.5
Reagan
Where is this thread, I have been looking for it for the last 15 minutes and cant seem to find it :-)
May 15, 2012 at 12:03 PM
mcbroomf
p.1 #19 · Nikon 105mm 2.5
This one?
https://www.fredmiranda.com/forum/topic/929565
Mike
May 15, 2012 at 12:21 PM
