Archive 2012 · Do I need other strobes
skasol
p.1 #1 · Do I need other strobes
Hi,
I ordered two canon 600 EX and I was wondering if these are sufficient for portrait work. I am barely getting used to it and starting. I got two umbrellas, stands and flash adapters. are these sufficient for studio work or should I go with strobes?
Thank you in advance.
May 14, 2012 at 06:04 PM
alohadave
p.1 #2 · Do I need other strobes
They'll work fine.
May 14, 2012 at 06:16 PM
skasol
p.1 #3 · Do I need other strobes
Thanks.
May 14, 2012 at 06:18 PM
k7xd
p.1 #4 · Do I need other strobes
They have their time and place. Good to learn with.
If you stick with it for awhile their limitations will become obvious.
May 14, 2012 at 11:42 PM
colinm
p.1 #5 · Do I need other strobes
I'm not personally a fan of Speedlites for learning lighting because they don't have modeling lights. Not being able to see what you're doing makes it difficult for many people to visualize what's going on with their lighting patterns.
They are perfectly sufficient for most portrait work, though.
May 15, 2012 at 12:48 AM
cordellwillis
p.1 #6 · Do I need other strobes
Make sure you use them in Manual and NOT ETTL if you're trying to learn portrait/studio lighting. ETTL is not the way to learn it. ETTL is best suited for on the go flash with changing lighting conditions.
May 15, 2012 at 11:03 AM
skasol
p.1 #7 · Do I need other strobes
Thanks.
May 15, 2012 at 11:48 AM
cgardner
p.1 #8 · Do I need other strobes
The downside vs. studio lights are the lack of modeling lights for placement and slower recycle times. These aren't show stoppers, you'll just need to chimp and watch you pace of shooting.
A problem with umbrellas in a small room is they spill so much light off ceiling and walls that you may have trouble controlling direction. You should consider getting a pair of 24 x 24 softboxes at some point so you will have better control when needed.
May 15, 2012 at 04:14 PM
skasol
p.1 #9 · Do I need other strobes
I am trying to decide whether I should keep the 600's or just return them and get studio lights.
I also do have a soft box.
May 15, 2012 at 05:09 PM
cgardner
p.1 #10 · Do I need other strobes
I have both. I use the speedlights on location 10x more than the studio lights because as a hobbyist I just don't have much demand for static studio portraits. The choice of which to use for me is logistics: I don't like to haul a lot of gear on location. I use one 580ex on a bracket for fill with another 580ex on a rolling stand. The studio gear stays set-up in the basement..
It's a bit of a chicken / egg dilemma. If you were to get studio lighting instead of speedlights, once you learn to use them you'll see a lot of situations on location shooting candids where you'll wish you had the ablity to control the ligting better with the speedlights.
If you only have the speedlights you'll also quickly realize two lights is limiting what you can do. Then you'll face the decision of buying a third or perphaps a fourth light. See this tutorilal of mine to understand what I mean:
http://photo.nova.org/FourLightExercise/
So what I'd suggest based on my experience is to start with the speedlights then if you reach the point where you want to add that third or fourth Canon flash buy the studio lightis instead. For the cost of two 600EX-RTs you can buy four AB800. That way instead of having a marginal four speedlight studio set-up you'll have two sets of tools, one ideal for run-n-gun PJ style location shooting indoors and out, and another for more critical static situations — products, formal portraits.
May 15, 2012 at 06:39 PM
skasol
p.1 #11 · Do I need other strobes
Thank u
May 15, 2012 at 08:18 PM
hondageek
p.1 #12 · Do I need other strobes
For what the 600EXs cost, you could get two used 580EXs and two AB800s. The 600EX isn't a lot of flash power per dollar.
May 16, 2012 at 08:36 AM
skasol
p.1 #13 · Do I need other strobes
Thanks. I got the 600's at a steal. 400 each.
I think I will just start playing and practicing with them.
With strobes how do u fire them wirelessly?
May 16, 2012 at 08:40 AM
hondageek
p.1 #14 · Do I need other strobes
Wow. That's cheap. Sounds like they fell off the back of a truck.
You can trigger strobes with a flash from an on camera flash turned around and bounced off a wall, or you can buy some cheap Chinese triggers on Ebay.
To start off, you can use a sync cord to your main and use the optical on the other strobe to fire it.
May 16, 2012 at 08:46 AM
skasol
p.1 #15 · Do I need other strobes
Thank u. Yeah I work retail and have some really nice connections.
May 16, 2012 at 09:11 AM
Jo Dilbeck
p.1 #16 · Do I need other strobes
I use RadioPoppers JRX system on my 580-II's, but don't know if they work iwth the 600's. works great, flashes in manual, trigger on camera controls both individually. Great to start with as I don't do much in the way of portraits, but more so outdoor fill flash scenarios.
Jo
May 16, 2012 at 01:55 PM
cgardner
p.1 #17 · Do I need other strobes
The 600EX-RT have built-in radio triggering so you don't need any third party triggers. If you keep one in the hotshoe or attached to it via the OC-E3 cord to mount the on camera flash on a bracket (what I do with my Master 580ex).
If you want to remotely fire two flashes on stands you'll need to pick up a ST-E3-RT transmitter. It fits into the hotshoe and acts as a controller for the slave flashes.
May 16, 2012 at 02:24 PM
jfnphotography
p.1 #18 · Do I need other strobes
I would rent a strobe and see what you think. speedlights are great for run and gun. But for portrait work in a studio, nothing like a strobe.
May 16, 2012 at 02:36 PM
hondageek
p.1 #19 · Do I need other strobes
He was asking how to wirelessly trigger the strobes, not the 600s.
May 16, 2012 at 11:01 PM
skasol
p.1 #20 · Do I need other strobes
Thanks. I was, I know the 600's have rf and wil fire wireless with adapter.
May 16, 2012 at 11:49 PM
