Archive 2012 · big problem of this canon 85mm L II?
gohokie
p.1 #1 · big problem of this canon 85mm L II?
It looks as though part of the inner perimeter of the ring is chipping off
Is it a common problem for Canon 85L II?
Thanks
https://lh3.googleusercontent.com/-bLi9oRZqR3c/T3z2SDjKtxI/AAAAAAAAAac/FJgd0YwWIvQ/s512/IMG_5378-2.jpg
https://lh3.googleusercontent.com/-Ys9NhOb0q_c/T3z2SLoWWHI/AAAAAAAAAag/Ne71R7D7pi8/s512/IMG_5378-4.jpg
Apr 12, 2012 at 01:57 PM
KaaX
p.1 #2 · big problem of this canon 85mm L II?
I don't know if it's a *common* problem, but because the rear element protrudes so much you have to be extra careful handling this lens when it is off the camera.
Does this look like the ring disintegrates by itself or there's been an impact there?
Apr 12, 2012 at 02:07 PM
gohokie
p.1 #3 · big problem of this canon 85mm L II?
I can't tell. I bought it from ebay. Seller offers me $100 discount for this issue.
Apr 12, 2012 at 02:12 PM
twistedlim
p.1 #4 · big problem of this canon 85mm L II?
Looks like it has been impacted. Forget the $100, get a refund and send it back.
Apr 12, 2012 at 02:14 PM
Rav13
p.1 #5 · big problem of this canon 85mm L II?
yes, it will cost £250 in the uk to repair, I've chipped mine when I let someone borrow it, won't be lending it again as I didn't check properly when i got it back.
Apr 12, 2012 at 02:18 PM
jdben622
p.1 #6 · big problem of this canon 85mm L II?
Ouch...yeah, that's more than $100 worth of "issue". It might not have an impact on IQ. However, most shooters can forgive marks on the front element, but when the rear element is concerned...meh.
Apr 12, 2012 at 02:27 PM
deepbluejh
p.1 #7 · big problem of this canon 85mm L II?
I agree, this is not a typical problem. This lens has been impacted..
THAT SAID... this won't make any sort of a differences in your images, unless you shoot at like F16 (seriously). I'd be inclined to keep the lens.
Apr 12, 2012 at 02:31 PM
KaaX
p.1 #8 · big problem of this canon 85mm L II?
The usual worry with impacts is that the shock disturbed the internal alignment of lens elements.
It's like with a used car that's been in a collision. Maybe it's fine. Or maybe its front end got subtly misaligned and you find out about it when your front tires wear out in 10K miles...
Apr 12, 2012 at 02:48 PM
deepbluejh
p.1 #9 · big problem of this canon 85mm L II?
A few very quick test shots will tell you if it's ok optically.
Apr 12, 2012 at 02:52 PM
gohokie
p.1 #10 · big problem of this canon 85mm L II?
optical quality is ok
Apr 12, 2012 at 03:28 PM
morganb4
p.1 #11 · big problem of this canon 85mm L II?
^Bingo. Take the ton. Buy a good scotch.
Apr 12, 2012 at 09:36 PM
