Archive 2012 · Addendum to my Ethical Nest Photography Guide
larkinsg
p.1 #1 · Addendum to my Ethical Nest Photography Guide
Guide to Ethical Nest Photography
By
Grover L. Larkins Jr.
How often have you seen a beautiful photograph of a nesting bird in a magazine? Have you ever wished that you had such a photo in your collection? Most of us, myself included, would be tempted by the opportunity to photograph a bird on its nest. In many instances this is one of the few times that you can easily get close enough to a bird to use a short telephoto or zoom lens and get a satisfactory image. Since this is also one of the most critical times in the life of a bird it is also very easy to upset and harm them.
Our interference with the normal routine of the nest can be limited by adhering to some simple rules. The question which many of us fail to ask is what the consequences of displaying and/or publishing a nest photograph may be for other birds. I have tabulated some guidelines for photographing nesting birds and some suggestions for the display and publication of their photographs.
First, before approaching any nest site, study the adults and determine what their behavior is in an undisturbed condition. This will give you a means of gauging when you have entered their tolerance zone (caused them anxiety). In most cases this means studying the pair from cover with binoculars. To do this time how long they are away from the nest foraging in the morning, mid-day and afternoon hours. Record the average temperature at these times of day. Three quarters of this interval is the longest time that you should spend inside the adult's tolerance zone. This time will vary depending upon the temperature and time of day; it may mean that you will have only two or three minutes in the morning, 10 minutes at noon and five minutes at 5:00 pm. Your approaches to the nest should be limited to three per day at the most; if the adults do not return within twice your time within the tolerance zone leave the nest alone for the rest of the day! Also it is almost always better to remain outside the tolerance zone and use a telephoto lens than to disturb the nest. Be warned though that the mere action of pointing a lens at a nest can increase the limits of the tolerance zone -- lenses and firearms look a lot alike to a gun-wary bird (or any other animal).
Events at the nest can also alter the tolerance zone. Consider the following example: photos of two nesting Osprey were made at the limits of their tolerance zone; approximately 40 yards. Their eggs are not yet laid and the time away from the nest was about an hour or so on the first day. By the second day it is almost certain that there is an egg in the nest. The time away from the nest is down to the few minutes (5 or less) that the female spends on the branches at the edge of the nest. The male's tolerance zone has now expanded to over 100 yards -- any closer than that and he takes up station overhead ready to defend his family. An approach to 40 yards was permitted but the female began to appear agitated at 35 yards distance. I returned to 40 yards for 5 minutes. The male settled down and I was afforded a 15 minute period to photograph them together. My total time inside his 100 yard tolerance zone was 30 minutes -- exactly 2/3 of the 45 minute average time he spent away from the nest. The mere fact that on the second day there are eggs in the nest has caused a significant alteration in the bird's behavior and in the tolerance zone for the male (in the event that the young have left the nest and are on the ground you should also expect a behavioral change on the part of the adults).
The location of the nest will also have quite a bit to do with the tolerance zone. A normally shy yellow crowned night heron has a nest at the edge a wildlife refuge road. With so much traffic the birds have become quite tame and showed no signs of distress at a distance of less than 10 feet. Since the birds and their nest were best viewed from a distance (due to branches and leaves obstructing the view) my photos were taken using a 400 mm telephoto lens at 15 -- 30 feet. Remember that closer is not always better! To get a photo of the yellow crowned night heron with his crest raised in alarm I waited until the resident red-shouldered hawk flew past. Birds are generally active animals and don't usually need our stimulation for an interesting photograph -- don't harass them with sticks, stones, hand claps or car horns. Also, as with any wildlife photography, patience pays off. I had been waiting for an opportunity to photograph a night heron for 2 years when I happened across this nest. I had seen other nests but the tolerance zone was a formidable 40 - 50 yards even in mangrove forests. Rather than attempt to get a photo from one of these "sensitive" nests I elected to wait. Eventually the waiting paid off!
Remember also that the more people you attract to the nest the more you will disturb it. Groups of people tend to surround things to get a better view. The surrounding of any animal will cause it anxiety. I witnessed an incident in Denali where a group of people surrounded a Caribou. It panicked and ran through a crowd of senior citizens at a bus stop. No one was injured but luck and the caribou had more to do with that than the would-be photographer who circled behind the animal and caused the panic (he didn't get his photo since the animal departed so abruptly). In this case he was told by others at the scene not to go behind the caribou but elected to ignore their advice. He received a humiliating lecture by a ranger and a warning for his actions there. The lesson in this is plain: since you cannot control the actions of others, you should never disclose the location of a nest. It only takes one inconsiderate or ignorant person to cause unnecessary stress and possible failure of the nest.
The limits and guidelines above are derived from ordinary common sense. More concrete rules are: never touch the nest, never disturb young in or out of the nest, don't touch eggs and do not ever bend, remove, trim or otherwise alter the trees, branches or whatever which are providing cover or support for the nest. Removal of one limb to obtain better illumination or a better angle can cause the young or the eggs to literally fry in the sun! If one or more of the chicks looks like it is starving to death it may well be doing just that! In many species this is a normal occurrence; three or four eggs may be laid and hatch but the strongest one or two survive -- it isn't nice but it is natural. Interfering with this process will endanger the remaining nestlings and probably (almost certainly) not save the starving one. The net result of this interference is the possible loss of all of the young. Leave "rescue" missions to the biologists and authorities.
Finally, if you have any doubt about the impact which you will have on the birds, leave them alone!
When (and if) you publish your photographs make certain that the captions of each photograph with a nest in evidence includes the following information: are there eggs in the nest, are the young fledged, is this photograph taken from a blind, are any special precautions to prevent the disturbance of the birds being taken? Never disclose the location of the nest since many species return for their entire adult lifespan to the same area to nest. In the event that your magazine’s editors have a problem with keeping the nest location a secret try to explain your reasons for it. If they still have a problem with keeping it a secret, sell your photograph to another magazine with a more sympathetic editor.
Stock agencies should also be able to follow this procedure; I am certain that the better agencies would have few problems with this request. If they do, explain the consequences to them. Their objection may only be due to a desire not to have to stock an additional explanation for each nest shot. A simple caption on a 2X2 (slide sized) card affixed to the image with a piece of tape should overcome this objection. The reasons for the publication rules are simple; people try to imitate. If they try to imitate and don't understand the conditions under which the photographs they are imitating were obtained they are likely to damage the health of their subjects. For this reason always attempt to place your photographs in an ethical setting. Indicate that you used a 600 mm f4 EDIF with a doubler or a blind erected at night to get the shot. Detail the signs of agitation for the birds in the photo that delineate the tolerance zone in the accompanying text. With any luck you will have just saved an entire generation from ignorant harassment. To summarize:
• Observe from a position outside of the tolerance one with binoculars.
• Time the bird’s absence from the nest as a function of the time of day and/or temperature.
• Determine the tolerance zone by establishing a distance at which the birds begin to show signs of agitation.
• Use the tolerance zone limit for routine photography of the nest.
• Enter the tolerance zone only once on each morning and afternoon.
• Each venture into the tolerance zone should last for only 3/4 as long as the average absence from the nest at that time of day.
• Always indicate in the captions that the photographs were taken ethically -- no trimmed limbs or disturbed nests.
I realize that in many cases people are going to disturb a nest to get a "great" photo no matter what you and I may publish. All we can do is try to eliminate their most common excuses. As a final word; always try to get a copy of the rules of any Park or Refuge in which you are planning a photographic trip. The rules are usually there for a reason. If any of them seem unreasonable take the time to inquire. A polite inquiry can often make you a valuable acquaintance at the park (and sometimes even an exception to the written rule in question). Also, if you witness an action by another individual which is either unethical or illegal by all means take a photograph of the event and person(s) involved and report the incident to the authorities. With any luck this will inhibit the unnecessary disturbance of any wildlife. Remember; when we photograph wildlife we are in their world and present at their sufferance. Be a polite visitor!
Ethical Nest Photography – some addenda for the Digital Age:
1. If you are going to use a flash, use as high an ISO setting on your camera as will give good results. This reduces the amount of “fill flash” power required and, as a result eliminates any possible ocular damage to the species being photographed.
2. Keep your distance. With the new crop factor making a 400mm lens into a 600+mm super-telephoto you can back off and still get a great photo. The advent of stabilization and higher ISO abilities (remember when I first wrote this piece “fast” film was ISO 100!) have made equivalent focal lengths of 600+mm commonplace and an ISO of 400 brings shutter speeds for a modest f5.6 lens into line with what previously required an f2.8 lens aperture to achieve under the same lighting conditions with ISO 100 film.
3. Tape/Electronically Reproduced Calls: This is a big problem, with the proliferation of “calls” on the Internet, IPhone Apps etc. every mental midget and wannabe on the planet has an ideal way to harass wildlife. Yes, calling an owl with the IPhone app will work. Yes it will trigger a strong territorial response and stress the bird UNBELIEVABLY. It will also get you a citation/fine in any National Park and quite likely you will be injured by the owl’s active response to the call. This means a trip to the Emergency Room since those talons were previously in some rodent’s entrails and certainly were not sterilized afterwards. I STRONGLY ADVISE AGAINST THE USE OF ELECTRONIC CALLS!!!!
Apr 12, 2012 at 12:03 PM
DonGut
p.1 #2 · Addendum to my Ethical Nest Photography Guide
Grover, Thanks for this. I have photographed nesting birds for years. I agree with what you say for the most part and I have a couple things to add. First, I am not sure flashes harm or even bother the birds. The first time the flash goes, they react. After that they just carry on like nothing happened. I don't use the flash if I can do without.
Very few nests I find are suitable for photography; too much cover etc. etc. I leave those alone and stay away. I strongly believe that nest photography should be done from a blind. For small birds there level of comfort doesn't allow close enough approach without the use of a blind. I try to set the blind up early in the nesting activity; preferably during the nest building stage. Also I only work for short times and then leave. I don't photograph the bird while it is incubating the eggs, and not until the young are a bit older with some feather cover so they aren't susceptible to the elements. The days before the young fledge are the most rewarding for photography anyway. And I don't put up my blind in an area where other people would find it. If the nest is not on my property I ask permission and ask the owners not to disturb the area. And I don't photograph ground nests as the blind will often attract racoons!!!!
Just thought I'd ad my own thoughts. Thanks for the post.
Don
Apr 12, 2012 at 02:38 PM
tfoltz
p.1 #3 · Addendum to my Ethical Nest Photography Guide
I was disappointed to find a group of photographers on ladders (within 3 ft. or less) taking shots of a hummingbird nest with flashes and macro lenses last week. I asked them to please back off, that they were stressing out the mother HB and it wasn't a cool thing to do. They stated they had been doing it for 3 days and that they didn't have to move. Do you really needs hundreds of shots of the same thing? Several others also told them but they continued to do so even though it was obvious the parent hummingbird was stressed out and not feeding the babies as much as normal. They continued for hours, without a care to the disturbance of the birds. This group was part of a photography club, and it seemed getting the shot was more important than the birds welfare. Photographers like this give others a bad name.
Apr 12, 2012 at 05:02 PM
mco_970
p.1 #4 · Addendum to my Ethical Nest Photography Guide
Tim, I hope you contact the leader of the photography club. Sounds like the club needs a presentation on animal welfare (maybe from a local orinthologist). And they need to be aware that a few individuals can make the whole club look bad.
What they are doing needs to stop.
Apr 12, 2012 at 09:32 PM
larkinsg
p.1 #5 · Addendum to my Ethical Nest Photography Guide
Flash, in and of itself, usually is not too much of an issue. 400W-s of flash at 10' or less can be, as can umbrellas, softboxes and so on. Key here is less is more and, as another respondent pointed out, groupthink is an exercise in mindlessness.
Grover
Apr 12, 2012 at 10:23 PM
larkinsg
p.1 #6 · Addendum to my Ethical Nest Photography Guide
Tim,
In cases like this "Club" I suggest that you post the name of the "club" and the names and pictures of "members" and describe what they were doing here and in other forums on line.
Singling out bad actors in a crowd strips them of their anonymity and fear of further ostracism keeps the behavior from being repeated.
Grover
Apr 12, 2012 at 10:28 PM
jdc562
p.1 #7 · Addendum to my Ethical Nest Photography Guide
Here's an addition for seabird nesting colonies:
Parent seabirds protect their eggs and nestlings from predation by gulls, ravens, crows, etc., that are continuously lurking around the colony. When the seabirds are scared off their nesting sites, the predatory birds move in quickly, destroying the eggs and nestlings. It only takes one selfish photographer to cause massive loss of seabird production.
Apr 17, 2012 at 02:32 PM
larkinsg
p.1 #8 · Addendum to my Ethical Nest Photography Guide
Once again -- Think first and when in doubt don't disturb them... You are right -- when nesting on eggs or very small chicks they are at their most vulnerable. Hence the rule is pretty clear: "Do Not Disturb."
Thanks for pointing out another situation that is potentially problematic!
Grover
Apr 17, 2012 at 03:59 PM
ultrarunner
p.1 #9 · Addendum to my Ethical Nest Photography Guide
Grover, thanks for such a great analytical approach to thinking of what we're doing when shooting nesting birds. While I don't do much of it, I am an avid boater and typically will take a long lens with me. I'll keep your comments in mind...
Thanks again,
Mark
Apr 17, 2012 at 09:54 PM
dalite
p.1 #10 · Addendum to my Ethical Nest Photography Guide
Distance can be relative, but certainly not so close as to impinge on a bird's or animal's "fight or flight" distance. By this I mean that I do not think that under certain circumstances 35 yards is too close provided that the photographer or viewer is behind or inside some kind of "blind." That blind can be a car or a tent blind. I have often noticed that some species of birds are quite oblivious to photographers inside their cars even when the car is 30 yards or slightly less distant.
Another suggestion to not stress the nesting bird is the use of a wireless remote button which enables the camera (a stationary object and, hopefully, slightly camouflaged) to be set up closer than would otherwise be possible. The attached shot of a hummingbird nest, taken a few feet above my sister-in-law's garbage can at her side yard on a drizzly and overcast day was triggered by remote, the camera being about 10 ft distant, while I was about 30 ft in the opposite direction out in the street. By doing this I was able to photograph the parent hummer feed the two nestlings (but not in this photo shown). Had I stood being the camera at 10 ft, the parent hummer would never have approached the nest.
http://farm6.static.flickr.com/5051/5533415908_264fa46d96_z.jpg
Apr 18, 2012 at 12:29 AM
sevan pulurian
p.1 #11 · Addendum to my Ethical Nest Photography Guide
http://farm4.staticflickr.com/3133/4559384811_dfb92ff7c8_o.jpg
Distance to nest 4.65m= 15.255 ft plenty of room to not disturb nesting activity. As for Tim case, calling the authorities of the grounds is the best result. SAD is all that story will ever be, very SAD!!! Keep your distance and respect them is the number one rule on any nest. Too bad if all you have is a P&S keep your distance.
If you also see other around the nest, don't be afraid to voice your concerns and remind the idiots to stay back! Remember they were here way way before us and we came in and took over their habitat.
ALSO! If you discover a nest keep it on the DOWN LOW! This helps from a viral spread on the location, then before you know it you will have have the world paying a visit to the location and eventually causing the bird to abandon the nest.
As Dalite mentioned a wireless trigger is key, remotely shooting will increase the chance of getting better images. Rarely will you see a nest at eye level like the one I captured, I mean eye level! I couldn't believe how low the nest was.
Sevan
Edited on Apr 18, 2012 at 01:16 AM · View previous versions
Apr 18, 2012 at 01:10 AM
sevan pulurian
p.1 #12 · Addendum to my Ethical Nest Photography Guide
larkinsg wrote:
Tim,
Grover
Also a great way to start a war! Selfish A holes are all these types of people are, giving the rest of us a bad wrap and eventually getting all photogs banned from the area or strict rules laid upon us, all it take is for one individual or group to ruin tit for the rest.
Apr 18, 2012 at 01:13 AM
Fizzog
p.1 #13 · Addendum to my Ethical Nest Photography Guide
Just to clarify things on this side of the pond. In the UK it is illegal to photograph schedule I birds at or near the nest without a licence. For all other birds I'd say follow the excellent advice above.
Here's the list: RSPB
Apr 18, 2012 at 03:02 AM
larkinsg
p.1 #14 · Addendum to my Ethical Nest Photography Guide
Thanks for the info on the UK -- I am certain that there will be many here that can use that info.
There are so very many more problems over there that we, thus far, have not had in such concentration over here. Egg collectors being one such species that comes to mind.....
Grover
Apr 18, 2012 at 11:19 AM
larkinsg
p.1 #15 · Addendum to my Ethical Nest Photography Guide
War is a bit strong -- and this works. Had an incident quite a while ago where a den was being disturbed by a photog on an "assignment." One set of photos to the editors and a short note and the assignment was re-assigned -- to a more ethical photographer.
We have to enforce the rules and ethics in our field; if we don't there soon won't be anything left to take pictures of....
Apr 18, 2012 at 11:27 AM
larkinsg
p.1 #16 · Addendum to my Ethical Nest Photography Guide
Yes, I use remotes also -- they are nice and work quite well. Bema trippers are also good -- I've made a number of such devid=ces over the years and they are invaluable for getting Hummingbirds at flowers....
Grover
Apr 18, 2012 at 11:32 AM
larkinsg
p.1 #17 · Addendum to my Ethical Nest Photography Guide
larkinsg wrote:
Yes, I use remotes also -- they are nice and work quite well. Beam trippers are also good -- I've made a number of such devices over the years and they are invaluable for getting Hummingbirds at flowers....
Grover
Argh -- I clearly cannot type today! Corrected above....
Apr 18, 2012 at 11:33 AM
sevan pulurian
p.1 #18 · Addendum to my Ethical Nest Photography Guide
Agreed but when it is a mob of useless photogs not on an assignment and they could give a rats ass of who you are, then you have a bigger issue on our hand. Now if it was a photog from a well known organization then your approach is the best. But when they are enthusiast then what better then get a hold of the proper authorities to deal with it.
Im all for enforcing rules upong those that have no respect or a brain, trust me bikers, pet owners in the wrong place with their pets, poachers and so on, even lousy idiots feeding the ducks under the 'NO FEEDING THE DUCKS' sign, LMFAO!
Apr 19, 2012 at 11:21 PM
