Archive 2012 · Nikon 85mm tilt shift lens question.
kaynoe
p.1 #1 · Nikon 85mm tilt shift lens question.
I am doing macrophotography, mostly flowers and plants with the Nikon 105mm, and have been thinking about the Micro Nikkor tilt-shift 85mm 2.8 lens. I am using a Nikon D300s and am wondering if the PC-E version vs. the PC is worth the extra money. I have found a few used PC versions in very good condition for about half the cost a new PC-E, is the advantage of the full electronic version on this camera worth the additional $900? Thanks for any feedback.
Apr 02, 2012 at 06:39 PM
m1mgd00
p.1 #2 · Nikon 85mm tilt shift lens question.
Since no one else is chiming in...
I recently went through this calculus and ended up with the 85mm PC. From what I understand, the optics of the PC and PC-E versions are identical, only the aperture differs (mechanical for PC, electronic for PC-E). Basically, the mechanical aperture means that you have to manually stop down the lens to get a meter reading and to take the photo. I used to use the 28mm PC, so the stop-down method doesn't bother me--this is not a lens I will be using for quick-action. The sequence I use is:
  1. Open up to the lens to maximum aperture (e.g. f/3.5 for the 85mm PC)
  2. Preliminary focus
  3. Stop down to desired aperture and take a meter reading
  4. (Optional) Open up the lens to maximum aperture
  5. Tilt / shift lens as desired
  6. Stop down lens to desired aperture (if necessary)
  7. Final focus
  8. Press shutter release
If you don't open up the aperture in step 4, then that saves a bit of time, but it may make it difficult to see the effects of your swings/tilts on the plane of focus.
Having said all that, I do also have a 24 PC-E and it is nice to be able to focus and set lens movements at maximum aperture / maximum image brightness and let the camera do the stopping down. Also, if you don't use any movements the PC-E version is much more usable as a regular manual focus lens.
Hope that helps.
Apr 03, 2012 at 12:24 PM
kaynoe
p.1 #3 · Nikon 85mm tilt shift lens question.
m1mgd00
Thanks for the feedback. It was also my impression the optics are identical between the two lenses. For my purposes I think the non-E version will suffice. I appreciate the information.
Apr 04, 2012 at 06:00 AM
lxdesign
p.1 #4 · Nikon 85mm tilt shift lens question.
Save yourself the money ... the PC version will work fine as long as you are not in a hurry! I got the 24mm PC-E for landscape, and while its nice having the electronic control of aperture... its not completely necessary for my work.
Apr 04, 2012 at 09:57 AM
lou f
p.1 #5 · Nikon 85mm tilt shift lens question.
the pc-e has nano coating so its contrast will be that bit better. i'd go for the pc and pocket the cash, if i saw one over here for that money i'd jump on it in an istant!
Apr 04, 2012 at 10:57 AM
ryankarr
p.1 #6 · Nikon 85mm tilt shift lens question.
I've owned both and I greatly prefer the PC-E, because that way I never forget to stop down!
Other than that, I never noticed a difference.
Apr 04, 2012 at 03:01 PM
TSY87
p.1 #7 · Nikon 85mm tilt shift lens question.
any samples from either of the two?
I'm considering getting a pce lens as well
Apr 04, 2012 at 06:19 PM
