Archive 2012 · NEX 7 exposure inconsistency
partitura
p.1 #1 · NEX 7 exposure inconsistency
I decided to go out to take a couple of brick wall photos today with my Nex 7 and a couple of lenses to take a look at the edges. I didn't get very far, because I noticed an oddity in exposure.
In Aperture Preferred mode, I took a shot with my 24mm Sony/Zeiss at f1.8, then an identical shot, changing only the aperture to f5.6. The exposures did not come out the same. The f1.8 shot was noticeably brighter than the f5.6 shot. (ISO stayed the same at 100)
I tried the same setup with my CV 35mm f1.2, at 1.2 and at 5.6. Same result.
So I came indoors, put the 24mm back on, turned up the ISO, and pointed the camera at the ceiling at f1.8 and f5.6. Same exact results yet again. It is obvious looking at the images and at the histogram. These two ceiling shots are below.
I'm using Lightroom 3, with no post processing at all.
What could be causing this Is the shutter not accurate?? Something screwy with the metering? Operator error?
f1.8
http://www.partitura.com/photos/ceiling-1.jpg
f5.6
http://www.partitura.com/photos/ceiling-2.jpg
Mar 12, 2012 at 07:02 PM
douglasf13
p.1 #2 · NEX 7 exposure inconsistency
Assuming that you're using matrix metering, it's often because of the vignetting at larger apertures. Does it do that with center weighted or spot?
Mar 12, 2012 at 07:12 PM
partitura
p.1 #3 · NEX 7 exposure inconsistency
I tried setting the Nex 7 it to both center weighted and spot and had the same results. The f1.8 is about 3/4 of a stop brighter than that at f5.6.
Out of curiosity, I tried the same test on my Nex 5N, set on center weighted. There was a difference there, too, between exposures, although much less. Maybe 1/4 of a stop, if that.
Very strange.
Mar 12, 2012 at 07:46 PM
douglasf13
p.1 #4 · NEX 7 exposure inconsistency
Is the vignetting on the 7 stronger than on the 5N with the 24/1.8??
Mar 12, 2012 at 08:08 PM
partitura
p.1 #5 · NEX 7 exposure inconsistency
I've not done a real vignetting comparison between the 5N and 7.
However, it is not just this lens. I saw the same behavior on my CV 35 f1.2, and just ran another test on the Contax G 90. This time I compared f2.8 and f8. Same thing, yet again, with the camera set on center weighting.
hmmm...
Mar 12, 2012 at 08:44 PM
douglasf13
p.1 #6 · NEX 7 exposure inconsistency
hmmm...
I asked about the vignetting because, if the NEX-7 vignettes any of these lenses more than the 5N, that could be a reason for the differences in exposure. Does the CV 35 vignette more on the 7 than the 5N?
Mar 12, 2012 at 08:57 PM
partitura
p.1 #7 · NEX 7 exposure inconsistency
I just did a little test on both cameras - shooting a featureless wall with the CV 35mm with aperture set at f1.2.
In Lightroom, it takes almost the same vignetting correction to fix both. So it appears to me that the 7 is not vignetting more than the 5N when using this lens.
I'm still puzzled by this.
Mar 12, 2012 at 10:49 PM
philber
p.1 #8 · NEX 7 exposure inconsistency
Partitura, I did a 5N and 7 comparison, when I shot the same shot wide open and at f:5.6 with both cameras, and there is no difference in exposure. I used a ZM 35 f:2.0. So, at least, it means that the problem you encountered is not systematic.
Mar 13, 2012 at 02:30 AM
partitura
p.1 #9 · NEX 7 exposure inconsistency
Ok, Philippe, that is good to know. I'm going to spend some more time today to see if I can figure out what is going on.
Thanks
Mar 13, 2012 at 08:10 AM
FlyPenFly
p.1 #10 · NEX 7 exposure inconsistency
What was your shutter speed on the F1.8 outdoor shot?
Mar 13, 2012 at 08:12 AM
BenM
p.1 #11 · NEX 7 exposure inconsistency
Could it be DRO?
Mar 13, 2012 at 08:16 AM
philber
p.1 #12 · NEX 7 exposure inconsistency
The default setting on my NEX 7 had DRO activated, and I did get exposure "issues", some good, some less so. Until I turned it "off".
Mar 13, 2012 at 12:03 PM
partitura
p.1 #13 · NEX 7 exposure inconsistency
I'm thinking now it might have been DRO. I thought I had it turned off, and when I went to the menu it said off (really, I promise!), but I turned it off again, and now everything seems ok. Who knows?? Anyway, no more problems as of today. Thanks for your help folks.
Mar 13, 2012 at 04:45 PM
