Archive 2012 · Which Travel Tripod/Balhead for NEX?
rioni
p.1 #1 · Which Travel Tripod/Balhead for NEX?
Looking to get a small (the smaller the better) tripod for an upcoming trip with a NEX5N. Which tripod/ballhead combo would you recommend? I like the GP3 Gorillapod but not sure how stable that will be. I'll be shooting with lightweight rangefinder lenses. Any suggestions appreciated.
Feb 12, 2012 at 06:01 PM
philber
p.1 #2 · Which Travel Tripod/Balhead for NEX?
Rioni, I have used a GP3 Gorillapod as recently as yesterday night with a NEX 7 + Leica R 60mm Makro. For inside use, it is OK, even if bending the legs to achieve proper composition is a lot fiddlier than a more convetional Manfrotto table tripod. For outside use, both are very limited by their low position, but the Manfrotto is a lot more rigid, if less adaptable, which is why it was the one I took on a trip around the world. But, if you are into exposures longer than handheld permits, you really should consider a "real" tripod. I have used a Cullmann Nanomax 220. It is very light and stealthy, easy to deploy and use, and doesn't cost more than the two minis I mentioned.
Of course, it is not perfect, and you shouldn't expect perfect results for 30-second exposures. Which is why on this trip I also carried a Gitzo 0541 and oversized ballhead.
Because of its high pixel density, the 5N is sensitive to perfect conditions, and a less-than-totally-stable platform (or less-than-perfect-glass for that matter) will lose you some of that delightful camera's astonishing performance IMHO.
Hope this helps
Feb 13, 2012 at 12:30 AM
vallejo
p.1 #3 · Which Travel Tripod/Balhead for NEX?
I think that a small Gitzo CF and any small ballhead from Gitzo or Induro with a removable plate is hard to beat...There a waist holder from Gitzo that is excellent...
Feb 13, 2012 at 01:11 PM
douglasf13
p.1 #4 · Which Travel Tripod/Balhead for NEX?
I would look into brands like Benro for a small carbon tripod at a better value. I bought to one to try out a few years ago when my Gitzo was in need of repair (top leg joint snapped in half out of nowhere,) and I've been using it ever since.
Feb 13, 2012 at 01:17 PM
Smiert Spionam
p.1 #5 · Which Travel Tripod/Balhead for NEX?
For something pocketable, I use the Leica table tripod and a RRS BH-25. The Manfrotto table tripod is in the same vein, and cheaper. Kirk makes a nice one, too.
Feb 13, 2012 at 01:18 PM
JaanOs
p.1 #6 · Which Travel Tripod/Balhead for NEX?
Sirui T-005 kit with C10 ballhead?
http://www.argraph.com/Sirui/Sirui-T-005-Tripod-Series.html
Not pocketable but can be sturdy enough. NEX5 with a "big gun"
http://www.upload.ee/image/2073983/_MG_5775.jpg
Feb 13, 2012 at 01:34 PM
rioni
p.1 #7 · Which Travel Tripod/Balhead for NEX?
Thanks for the recommendations everyone. I have a Gitzo GT1541 that I was thinking about selling for a more compact option but maybe it's best to just keep it.
Feb 14, 2012 at 07:18 AM
inglis
p.1 #8 · Which Travel Tripod/Balhead for NEX?
Could you put a Contax 100-300 with a Nex on any of these tripods for decent daylight shots with success? Just wondering about the level of stability.
Feb 14, 2012 at 07:57 AM
Smiert Spionam
p.1 #9 · Which Travel Tripod/Balhead for NEX?
You probably can with the Leica or Kirk. They have no joints to flex, so they perform more like a much larger tripod. All the usual caveats apply about long focal lengths, difficult shutter speeds, etc. -- but I find that a very solid table tripod is more stable with longer lenses than a 0 or 1-series conventional tripod. I haven't tested extensively with the NEX, but I've used the Leica combo with a DX DSLR at 200mm successfully. The lower vibration of a mirrorless body should make the NEX incrementally more stable on a small tripod.
With a tiny head, weight distribution is important -- it's helpful to use a lens adapter with a mount.
Edited on Feb 14, 2012 at 09:45 AM · View previous versions
Feb 14, 2012 at 08:34 AM
FlyPenFly
p.1 #10 · Which Travel Tripod/Balhead for NEX?
I use the TrekPod II, works ok
http://www.trek-tech.com/products/trekpods.html
Feb 14, 2012 at 09:03 AM
