Archive 2012 · 70-300mm DO IS USM qq
hansdoddema
p.1 #1 · 70-300mm DO IS USM qq
Hi there!
Quite a number of abbreviations to start with in the title, but have a question.
I got this 70-300mm DO IS lens used, and have been happy with it so far. But when I picked it up today, I noticed that the focus ring and especially the zoom ring wobble (vertically), must have gotten a bit worse/loose. It's not flimsy or anything, just wondering if the the wobble normal, might have to do with the long lens creep? Is it something that can be repaired/serviced?
Thanks,
Hans
Feb 11, 2012 at 05:38 PM
Tenn.Jer
p.1 #2 · 70-300mm DO IS USM qq
Hans -
I've had mine for several years and had to send it in for servicing when a couple of the tiny screws in the barrel (near the front end) had fallen out without my noticing - and a third one was loose. This caused the front element holding area (I don't know the proper name for this) to wobble a bit and slip into a canted angle. Check those screws (and any other you can see); maybe they're the problem. The barrel assembly (two parts) has otherwise never wobbled, actually it's quite solid fitting and, since that servicing trip, doesn't even creep when held down. Good luck with it - I've always enjoyed mine.
Jerry
Feb 11, 2012 at 07:00 PM
nutek
p.1 #3 · 70-300mm DO IS USM qq
Hi, yes my 70-300DO does that too - the focus and zoom rings are able to wobble a little vertically. No issues with it so far; enjoy using the lens
Feb 11, 2012 at 11:42 PM
Dick Snyder
p.1 #4 · 70-300mm DO IS USM qq
I had a little problem with the zoom ring on my copy. Sent it to you Canon and it came back working smooth as silk. Great little lens.
Feb 11, 2012 at 11:57 PM
