Archive 2012 · Portrait Session: Kelli
megbrock
p.1 #1 · Portrait Session: Kelli
Hi! My name is Meg and this is my first post in the people forum. Any feedback is appreciated. Thank you!
1.
http://www.megbrock.com/wp-content/uploads/2012/02/1-2.jpg
2.
http://www.megbrock.com/wp-content/uploads/2012/02/1.jpg
3.
http://www.megbrock.com/wp-content/uploads/2012/02/2.jpg
4.
http://www.megbrock.com/wp-content/uploads/2012/02/3.jpg
5.
http://www.megbrock.com/wp-content/uploads/2012/02/4.jpg
6.
http://www.megbrock.com/wp-content/uploads/2012/02/5.jpg
7.
http://www.megbrock.com/wp-content/uploads/2012/02/6.jpg
8.
http://www.megbrock.com/wp-content/uploads/2012/02/7.jpg
9.
http://www.megbrock.com/wp-content/uploads/2012/02/8.jpg
10.
http://www.megbrock.com/wp-content/uploads/2012/02/9.jpg
11.
http://www.megbrock.com/wp-content/uploads/2012/02/10.jpg
12.
http://www.megbrock.com/wp-content/uploads/2012/02/11.jpg
14.
http://www.megbrock.com/wp-content/uploads/2012/02/13.jpg
15.
http://www.megbrock.com/wp-content/uploads/2012/02/14.jpg
16.
http://www.megbrock.com/wp-content/uploads/2012/02/15.jpg
Feb 09, 2012 at 12:39 PM
MattWeth
p.1 #2 · Portrait Session: Kelli
Nice series - looks like you both had fun! #8 is my pick - great expression
Looking forward to seeing more of your stuff.
Feb 09, 2012 at 01:42 PM
benee
p.1 #3 · Portrait Session: Kelli
Hi Meg - I've seen a couple of your posts in the wedding forum - thanks for stopping by here! I really dig 14 the most - it stands out from the rest IMO.
11 is cool as well!
Feb 09, 2012 at 01:48 PM
McDermott
p.1 #4 · Portrait Session: Kelli
Great set, all very nice. Only small nit, pic 10 right under the eyes seems a tad warm. Well done!
Mike
Feb 09, 2012 at 01:59 PM
megbrock
p.1 #5 · Portrait Session: Kelli
Thanks for the feedback! I brought my soft box outside for the first time for this session and it was a lot of fun. I am normally a big fan of naturally lit portraits but it's always great to try something new! The snow was a nice bonus.
Feb 09, 2012 at 02:33 PM
Chad S
p.1 #6 · Portrait Session: Kelli
It looks like you had some tough conditions to deal with. Great job
Feb 09, 2012 at 02:41 PM
Awasos23
p.1 #7 · Portrait Session: Kelli
She has some awkward leg positioning a few times. 3, 6, 9 for example. I feel like 12 is too truncated. I like the light and the expressions you captured.
Feb 09, 2012 at 03:06 PM
redclay92
p.1 #8 · Portrait Session: Kelli
I second what Awasos23 said, 3 is very awkward.
But the lighting is really great, I love using strobes outside.
Feb 09, 2012 at 03:14 PM
megbrock
p.1 #9 · Portrait Session: Kelli
For #3 I told her to look up and spin, which is why her leg is bent. I can see how it is a bit awkward. Would you have suggested for #6- legs further apart/ closer together?
Thanks!
Feb 09, 2012 at 03:59 PM
danchez
p.1 #10 · Portrait Session: Kelli
I may be a bit weird, but I love #12
Feb 09, 2012 at 04:24 PM
Miker Reid
p.1 #11 · Portrait Session: Kelli
Love the subject and setting.
Good stuff, you have to appreciate a girl that will stand out in the snow for pictures
Feb 09, 2012 at 05:19 PM
vawill84
p.1 #12 · Portrait Session: Kelli
awesome set, I love the emotions you captured working with her.
A little nitpick, but I dont like the lighting on 9, I think in this case following her face with the softbox instead of having it to her left might have made the image a bit more natural.
Overall though, very nice!
Feb 09, 2012 at 05:37 PM
megbrock
p.1 #13 · Portrait Session: Kelli
I know! It was so fun- she was a trooper!
Feb 09, 2012 at 05:54 PM
cgardner
p.1 #14 · Portrait Session: Kelli
It's a nice set, but two things to realize about flash:
1) If you want it to look natural you need to get it about 45° above the eye line of the subject. That's the average angle natural light comes and the downward angle modeling in flattering full face / butterfly pattern where the "key" light is centered on the nose 45° above the eye line, and the "short" / oblique facial angle combination where the key light is placed 45° to the side of the nose and 45° above the eye line.
When flash angle is less than 45° the modeling becomes progressively less "mid-day" natural and like a deer caught in the headlights of a car by the time it is down and eye level. Low artificial lighting can work effectively in some situations such when it is late in the day and the sun is also low, but low natural light isn't very flattering either.
2) When you move a single flash off axis it will create sideways shadows which will be dark and unflattering. The solution it the same indoors or out. To control the tone of the shadows you need a separate fill source coming from the direction of the camera where it will reach every nook and cranny on the face the camera sees.
Using a flash bracket will raise the flash sufficiently to eliminate the flat "deer in headlight" look in the single flash shot. The centered raised flash angle hides most of the shadows from camera view so for full face poses you can often get by with no fill — most of the face and front of subject are highlighted. When you move a second flash off axis the flash on bracket is ideally placed for the fill needed to keep the shadows light and soft.
The way to conceptualize how the key and fill work together is to imagine starting in a dark room with just the centered fill raising its power until desired detail is seen in the darkest objects like folds of black clothing. Then when the key light is turned on it overlaps and creates highlights. The shadows already lifted by the fill flash remain the same. Keep increasing key flash until the highlights are rendered accurately just below clipping.
The cause and effect is the same outdoors, you just start with the sun at the back, expose it under clipping and the sky light in front is the baseline fill. You then need to add enough fill flash to get the desired detail, then overlap the off axis key flash, either centered 45° above the eyes aimed directly at the nose for full face / butterfly, or placed 45° to the side of the nose and 45° above the eyes for a short / oblique combo.
Try it and compare with your results here.
Feb 09, 2012 at 06:16 PM
hardlyboring
p.1 #15 · Portrait Session: Kelli
word on all this.
Feb 09, 2012 at 07:05 PM
robby521
p.1 #16 · Portrait Session: Kelli
love 8
Feb 09, 2012 at 11:33 PM
megbrock
p.1 #17 · Portrait Session: Kelli
Thanks for the information! I will definitively try it out.
Feb 10, 2012 at 09:15 AM
Bruce Sawle
p.1 #18 · Portrait Session: Kelli
Lots of dust bunnies on your sensor. Just kidding love the snow. 14 and 15 are my favorites.
Feb 10, 2012 at 10:32 AM
derry1
p.1 #19 · Portrait Session: Kelli
Very good, 8 is my fav..
nice shooting,,
Derry
Feb 10, 2012 at 11:51 AM
jerbear00
p.1 #20 · Portrait Session: Kelli
Nice set I too like #8 and #11. Good stuff
Feb 10, 2012 at 02:17 PM
