Archive 2012 · 7D/Hotshoe flash problems...Please help
jerbear00
p.1 #1 · p.1 #1 · 7D/Hotshoe flash problems...Please help
Having an issue with my 7D. I am using the MR-14EX ring flash on Manual 1/100, f25, iso400 when I take a photo the exposure is essentially black. The flash fires but not enough light comes out. Please help. what I have tried so far is as follows:
1. Reset everything on 7D, flash is on ETTL, Even tried using manual flash with no avail
2. Fresh batteries
3. Checked MR-14EX on my 5dii (works great)
4. Tried a 430EX on my 7D, same problem
5. Tried the pop-up flash (works fine great exposure on same settings)
6. Took all the batteries out of the 7D for a reset.
7. Camera worked with flash for 1 night then quit.
8. Reinstalled the firmware (did not fix the problem)
What now?
Thanks
Feb 07, 2012 at 05:07 AM
BrianO
p.1 #2 · p.1 #2 · 7D/Hotshoe flash problems...Please help
jerbear00 wrote:
...Tried the pop-up flash (works fine great exposure on same settings)
Have you checked the screws that hold down the hot shoe to see if they're loose?
Feb 07, 2012 at 05:56 AM
jerbear00
p.1 #3 · p.1 #3 · 7D/Hotshoe flash problems...Please help
yes but thank you for the suggestion
Feb 07, 2012 at 06:17 AM
mwtphoto
p.1 #4 · p.1 #4 · 7D/Hotshoe flash problems...Please help
try cleaning the contacts on the shoe. also I have heard of the rubber gasket around the shoe may get in the way so that contact is not complete.
Feb 07, 2012 at 04:49 PM
jerbear00
p.1 #5 · p.1 #5 · 7D/Hotshoe flash problems...Please help
Thanks I will keep trying. I have it working now. Not sure what I did. Thanks again!
Feb 08, 2012 at 12:43 AM
