Archive 2012 · HELP... Rokkor 58mm f1.2 Aperture?
MasterJack
p.1 #1 · HELP... Rokkor 58mm f1.2 Aperture?
Just got one of these beauties on eBay. I shot several shots with it with no problem. All of a sudden when I change the aperture the lens does not stop down. I took it off the camera and removed the (MD-NEX Adapter) and the blades will not open and close - they stay fully open. Any ideas what may cause this? Faulty lens? Faulty user?
Thanks,
John
Feb 06, 2012 at 01:47 PM
Jabberwockt
p.1 #2 · HELP... Rokkor 58mm f1.2 Aperture?
Sounds like a stuck aperture mechanism, it is relative easy to take the Rokkor apart and clean the mechanism but if you don't trust yourself then either take it to the shop or email the seller, hard to believe that the seller didn't know about this.
Feb 06, 2012 at 02:07 PM
MasterJack
p.1 #3 · HELP... Rokkor 58mm f1.2 Aperture?
Thank you. What's odd is that it worked for a while - on and off actually... would it have worked at all if it were stuck or needed cleaning?
Feb 06, 2012 at 02:18 PM
ricardovaste
p.1 #4 · HELP... Rokkor 58mm f1.2 Aperture?
I've cleaned mine twice (completely, each aperture blade individually) and re-greased helicoid... and it came back. I think I am just unlucky, or something... cleaning the blades is pretty simple as long as there isn't oil leaked EVERYWHERE.
MasterJack
p.1 #5 · HELP... Rokkor 58mm f1.2 Aperture?
I should probably take advantage of the 7-day return policy. I don't think I should have to mess with it being that I just got it....
Thanks,
John
Feb 06, 2012 at 02:27 PM
MasterJack
p.1 #6 · HELP... Rokkor 58mm f1.2 Aperture?
Anybody know who could service this lens? I live in Houston. Anybody live here that would like to make some extra cash...
Feb 06, 2012 at 04:10 PM
crazeazn
p.1 #7 · HELP... Rokkor 58mm f1.2 Aperture?
haha, I had the same issue and jacked it up. Try pro camera repair on richmond.
Feb 06, 2012 at 07:33 PM
mcbroomf
p.1 #8 · HELP... Rokkor 58mm f1.2 Aperture?
Not uncommon, I had the same problem and got my seller to have it fixed. I have a 50/1.4 that is stuck.
Mike
Feb 06, 2012 at 07:49 PM
MasterJack
p.1 #9 · HELP... Rokkor 58mm f1.2 Aperture?
Thanks guys for the info... and I was so excited to try it.... oh well once fixed it should be good to go....
Feb 06, 2012 at 08:35 PM
brockwhittaker
p.1 #10 · HELP... Rokkor 58mm f1.2 Aperture?
Are you using a converter for EOS? Sometimes on the mount if it is locked/unlocked, it differs on whether or not you can change the aperture.
Feb 06, 2012 at 08:42 PM
MasterJack
p.1 #11 · HELP... Rokkor 58mm f1.2 Aperture?
No sir - using it with a NEX-7. I have an MD to NEX adapter..... the aperture won't change even if the adapter is off.
Feb 06, 2012 at 08:45 PM
mMontag
p.1 #12 · HELP... Rokkor 58mm f1.2 Aperture?
Jim Buchanan - FM member - is a highly qualified lens mechanic especially on that lens.
http://www.jimbuchananspace.com/Camera_Services.html
Feb 06, 2012 at 10:35 PM
