Archive 2012 · Underwater housing
k clayton
p.1 #1 · p.1 #1 · Underwater housing
Has anyone used the Ikelite Underwater Housing 6871.07 for the Canon 7D?
What did you think? was it easy to use?
Thanks
Feb 04, 2012 at 01:09 PM
opies2
p.1 #2 · p.1 #2 · Underwater housing
we have one...super easy to use. The only speed bump is figuring out the zoom mechanism...not very straight forward
Feb 04, 2012 at 01:34 PM
k clayton
p.1 #3 · p.1 #3 · Underwater housing
Thanks opies2
Feb 04, 2012 at 01:39 PM
ragebot
p.1 #4 · p.1 #4 · Underwater housing
Just my two cents. Housings are just the start. You will/may also need extensions for the specific lens you use and ports or domes as well. Depending on which lens you want to use on the you may also need some other parts.
Just as Nikon and Canon have different lens mounts underwater housings have different mounts so not all extensions/ports will fit on all housings. Some folks think the Ikelite housing limits the choice of ports compared to some of the other housings.
This is not to say the Ikelite housing is not a fine product with some real advantages; just that some other choices may offer different advantages.
Feb 04, 2012 at 03:12 PM
A.Y.
p.1 #5 · p.1 #5 · Underwater housing
You'll find a lot of 7D underwater photographers at wetpixel dSLR forum.
Feb 04, 2012 at 03:41 PM
k clayton
p.1 #6 · p.1 #6 · Underwater housing
Thanks everyone!
Feb 04, 2012 at 04:29 PM
