Archive 2012 · Recommendations for a Tripod for the Sigmonster...
Lethal_weapon
p.1 #1 · Recommendations for a Tripod for the Sigmonster...
Have the Sigmonster in my greasy little hands and now need a less greasy Tripod.
No IS means I need the really good stability and with my suspect LLT I will need all the help I can get. Currently I have the Induro C414 Carbon 8X tripod which served me well for my Canon 600 F4 MK1 and 400 2.8 MK1 when I had them. Also still have the Jobu Heavy Duty MK III
which seeme to support the Sigbeastie with my 7D or 5D MKII nicely.
I had an incident with the tripod legs giving out with the 600 and luckily I was there to catch it so I am hoping this will not happen again (nor do I want to chance it) as the Sigmonster and 600 F4 are similar weights but the Sigbeast is longer.
With busting my already depleted account,. what would be my best bet?
Cheers
Ben
aka Lethal Weapon
Feb 03, 2012 at 01:33 AM
ragebot
p.1 #2 · Recommendations for a Tripod for the Sigmonster...
This is what I use
http://www.photocentric.net/gitzo_desc.htm
with this head
http://www.bhphotovideo.com/c/product/554099-REG/Manfrotto_393_393_Heavy_Duty_Gimbal.html
YMMV
Feb 03, 2012 at 03:27 PM
rdcny
p.1 #3 · Recommendations for a Tripod for the Sigmonster...
Either this one:
http://www.ebay.com/itm/Benro-C3570T-C-357-M8-Carbon-Tripod-Leg-Fast-Ship-/310376310762?pt=US_Tripods&hash=item4843dea7ea
or this one (heavier duty and better for your new lens):
http://www.ebay.com/itm/Benro-C4570T-C-457-M8-Carbon-Tripod-Leg-Fast-Ship-/140693649765?pt=US_Tripods&hash=item20c1feb965
Feb 03, 2012 at 05:25 PM
Donald Blue
p.1 #4 · Recommendations for a Tripod for the Sigmonster...
I was shooting a 500 f/4 with a Gitzo 3530 LSV with a Wimberley II, when I got the 600 f/4 I realized that I needed a stronger tripod. I went with the Gitzo 5541LS and it has definitely made a difference in the sharpness of my shots...it's not cheap but it is one rock solid tripod.
Feb 03, 2012 at 08:47 PM
Lethal_weapon
p.1 #5 · Recommendations for a Tripod for the Sigmonster...
Thanks for the recommendations everyone!
Looks Like its not going to be an inexpensive solultion.....
Will try some more shots with my current setup as it wasn't too bad today
Feb 04, 2012 at 12:31 AM
davidearls
p.1 #6 · Recommendations for a Tripod for the Sigmonster...
This is pretty easy, especially if you have a limited budget.
Tripod: Berlebach Report, either the 2002 (if you're short) or the 3002 (if you need more height). There are no metal or carbon fiber tripods that give you the dampening of wood. And the Berlebachs are way cheaper than CF.
For the head, look for a Manfrotto 393. It's about a quarter the cost of a "tony" Wimberley, and butt-ugly to boot. But you get the long Manfrotto plate and no matter what camera body you put on the lens, you can find a perfect balance point.
I use this setup with a Canon 600 f4 (non-IS) on both the heavy 1DsII body and the light 60D. My ancient 600 tips the scale at almost 14#. With long, heavy, high-distributed-mass lenses, balance of the mount is everything. Except times two for no IS.
Feb 06, 2012 at 12:47 AM
Lethal_weapon
p.1 #7 · Recommendations for a Tripod for the Sigmonster...
Thanks David
A wood Tripod...cool!
I will have to check these babies out
My current one is kinda busted after it had its last incident and I am nervous using it
Never thought of a wood tripod but it makes sense with the absorbtion and dampening affect of wood. Now all I would have to worry about is termites and woodpeckers!
Feb 06, 2012 at 12:57 AM
