Archive 2012 · Chromatic Aberration
anthonysemone
p.1 #1 · Chromatic Aberration
fellow gear heads , I'd appreciate your thoughts. While not directly photographically related, CA appears also, and not surprisingly, to be an issue with rifle scopes. I just purchased a high-end rifle scope, part of a new line offered by Bushnell Precision Optics, produced especially for the law-enforcement ERT, HR, as well as for military long-range precision applications. It's the 3.5x21-50 HDMR with G2 reticle.
After having it mounted by my dealer, I promptly took it to a safe location where I mounted the rifle to a bench, and began checking out the scope clarity, resolution, IQ, etc. The day was high overcast and very bright; no shadows, however, snow covered the ground.Target was a tree about 1meter in diameter at about 75 meters from my location. IQ, etc. was superb. Bright clear sight picture. And then I moved to 10x, 14x and 21x. Making certain that parallax was not an issue - it adjusts down to 50 meters, and that I had the eyepiece well-focused for my vision, I saw quite a remarkable production of CA and purple/yellow fringing. I could eliminate all of it if I made sure that my eye was precisely located in the absolute center of the eyepiece, or, what I interpreted to be the centermost point because that's where all of the aberrations disappeared.
So, can the environmental conditions of high, bright overcast sky with a sharply contrasting "target" against an uninterrupted and equally bright, reflective ground cover of snow, together with the optic variables of high magnification produce a worst-case scenario test, artificially enhancing the presentation of chromatic aberrations, purple/yellow fringing? Or, is the scope defective? FWIW, I have sent it off to Bushnell for their evaluation, but I wanted to be prepared for the report after they evaluated it, and I also wanted to be fair to them.
TIA,
tony
Jan 26, 2012 at 11:59 AM
Bernie
p.1 #2 · Chromatic Aberration
If you bought a camera lens with the same magnification and none of the issues you reported in the scope, you probably would be paying upwards of $15,000.
I looked at birding scopes some years ago, thinking with an adapter I could get away cheap. Between the high f stop (f8 at least), lack of contrast, and the chroma, I opted against spending the money.
The human eye can compensate for a lot of optical sins (including floaters inside the eyeball). The camera cannot. PP can do more and more lens correction but not for the amount of chroma in cheap glass.
Jan 26, 2012 at 01:36 PM
anthonysemone
p.1 #3 · Chromatic Aberration
Bernie, thank you, sir. Helps for you to have put that in a $ perspective
Jan 26, 2012 at 01:49 PM
IsleofGough
p.1 #4 · Chromatic Aberration
I have had S&B, USO, Swarovski, Simmons, Leupold, and Hensoldt scopes. The best resolution was hensoldt (zeiss), but it had the worst CA by far. It was also the most expensive and best made and the CA became a nonissue.
Jan 27, 2012 at 11:43 PM
