Archive 2012 · Macro Math question
Betacamman
p.1 #1 · Macro Math question
I _think_ I know the answer, but I wanted to ask around: If a macro lens does, say, 1:1 lifesize on a 35mm camera, does putting it on a crop camera change the macro ratio/magnification?
My impression is that, while the "reach" changes on a crop, the macro size ratio would not.
Jan 25, 2012 at 01:39 PM
JJuLLiAAn
p.1 #2 · Macro Math question
No, the ratio does not change.
Jan 25, 2012 at 01:55 PM
umihoshijima
p.1 #3 · Macro Math question
No. 1:1 means that it can take a photo such that the image the lens projects on the sensor is the same size as real life. On a crop, the image projected is of the same size, but only a crop of it lands on the sensor. It's similar to the fact that a 50mm lens is still considered a 50mm lens on a crop camera - the magnification is also a property of the lens that does not change with sensor size.
Jan 25, 2012 at 07:47 PM
Betacamman
p.1 #4 · Macro Math question
Makes sense. Thanks!
Jan 25, 2012 at 08:04 PM
e6filmuser
p.1 #5 · Macro Math question
It depends what you mean by "the macro ratio/magnification". It remians the same at the sensor but a print will have a magnification factor equal to the crop factor over a print from a full frame sensor. By the same consideration, for two sensors of the same resolution, the resolved detail in the printed image will seem to have been reduced by the crop factor, in
Jan 29, 2012 at 09:36 AM
