I am trying to avoid buying another PW FlexTT5. I want to be able to occasionally trigger a 580EX from a set-up that has a PW MiniTT1 on camera and an AB800 that has a TT5 and AC-9 attached.
A good IR trigger should be fine for my uses right now but the old Wein peanuts have some pretty nasty reviews associated with them on B&H. Thoughts?
I doubt they'll be compatible with the Pocket Wizards, but I really like the Yongnuo RF-602's that I have. A transmitter and 3 receivers were only ~$70. I've never had a single miss syncing at 1/250. These things are great.
Hrow wrote:
I am trying to avoid buying another PW FlexTT5. I want to be able to occasionally trigger a 580EX from a set-up that has a PW MiniTT1 on camera and an AB800 that has a TT5 and AC-9 attached. ...A good IR trigger should be fine for my uses right now...
If you can use manual power adjustments for the 580EX, then an optical slave triggered by the flash of the AB800 would work.
