Archive 2012 · CANON: HSS off camera discussion no triggers
MTBtrials
p.1 #1 · CANON: HSS off camera discussion no triggers
I haven't posted much in this part of FM, so I'll introduce myself as a wedding shooter.
I hope this is the right section to speak about functions specific to canon
If not can the mods please relocate my thread?
Anyways, I'm in Mexico at the moment and have put down my cybersyncs to try and get my head around using the canon "master/slave" relationship in order to sync speedlites and in some cases get better results than I would simply stopping down the aperture and running a 1/125 or slower shutter speed (gotta love the 5D2's sync speed). For the sake of this discussion I will mention that unless you have either the radio poppers or the flexTTL radio style triggers (and maybe one other brand?) you will not be able to use HSS with "regular triggers", so your only other option is to use your camera manufacturers built in wireless system assuming you have one flash or camera body capable of being a "Master" and another flash capable of being a "slave".
I have posted two pictures for anyone trying to "learn" from this thread. The first was with a 70-200 2.8 IS, 5D2 and 580exII triggered with cybersyncs... normal flash sync meant I needed to crank my speedlites power, work it in close and run a tight aperture in order to eat up the ambient enough to not blow the background. (I put as much as I can remember about the exif in the notes with the picture... )
The second shot was using HSS with my 580ex being the on camera master and my 580exII being the off camera slave. I was rocking aperture priority with my 85L (it's hard enough trying to get my daughter to sit still yet alone look at me while dialing in a shutter speed under moving clouds )
The problems I have:
1) I haven't figured out how to shoot off camera HSS in manual mode. It seems to be TTL or bust. Is this the case?
2) if it is TTL or bust, do I have to make my slave "B" group in order to set my on camera flash (which isn't part of the exposure, just a trigger) to a very low power setting and adjust the power setting on my slave?
3) Now that I'm thinking of it, can "A" group be manual at 1/128 and "B" group be HSS TTL or ideally HSS manual?
Most people just want to sit by the pool on their vacation. I try to learn something I haven't been capable of before
TIA
Mark
Ok, had to link to my images on flickr... trying to upload more images on this mediocre connection is getting painful....
Image 1, on the beach, open (hard) sunlight.
Canon 5D2, 70-200 f/2.8 IS, 580exII @1/2 power, probably zoomed around 85 or 105mm.
Aperture was somewhere around f/11-16
Image 1 exif:
(grabbed from flickr)
Camera Canon EOS 5D Mark II
Exposure 0.006 sec (1/160)
Aperture f/14.0
Focal Length 110 mm
ISO Speed 50
Exposure Bias 0 EV
Flash Off, Did not fire
Image 2 exif:
Exposure 1/4000 sec
Aperture f/2.5
Focal Length 85 mm
ISO Speed 100
Exposure Bias -4/3 EV
Flash On, Fired
In human terms, I was on aperture priority mode, 85L, my 580ex on camera, telling the 580exII to shoot at +2/3 (or is that 1/3) while the camera is at minus 1/3 or 2/3
Jan 14, 2012 at 07:27 PM
BrianO
p.1 #2 · CANON: HSS off camera discussion no triggers
I just checked this on my 580EX (the original, not EX II). Using the on-flash control buttons, I set it for HSS while it was in ETTL mode, and then switched it to Manual mode. HSS remained active, and I could adjust the power output for the full range from 1/1 to 1/128 in the usual way using the wheel on the back of the flash.
No, you can leave the slave on A group if you want to. Then you can set the Master flash on the camera not to fire. It will fire the ETTL preflashes, but won't fire for exposure. (The final "Fire Now!" pulse may be visible in reflective objects, or if the flash-to-subject distance is close.)
MTBtrials wrote:
3) Now that I'm thinking of it, can "A" group be manual at 1/128 and "B" group be HSS TTL...
I haven't tried it, and I only have one flash with me at the moment, but I'll have to try that next time I get the chance. I don't think so, though. I think if you change any group to Manual, all groups have to be Manual.
One thing that I know will work is to set one or more flashes to Manual power using the on-flash controls, and they can then be mixed with A, B, and/or C Groups set to ETTL. Syl Arena talks about this method in The Speedliter's Handbook, and he refers to the manual mode slaves set that way as "free agents." Free agents don't belong to a Group, and in fact you'll see the Group letter disappear when you change an off-camera Speedlite in Slave mode from ETTL to Manual using the on-flash controls. (If you change it from ETTL to Manual remotely, using the Master wireless controller, it will stay in whatever group it was assigned to, but as I said I think all groups will then go into manual mode.)
One reason to have free agents would be in a case where you have some lights set up as set lights to expose an unchanging environment, but you have a subject lit with on-camera flash moving within that environment. The flash to subject distance would be changing as the subject moves, and the camera might also be moving around, so ETTL flash would best handle the dynamic exposure. But since the fixed flashes lighting the environment aren't moving, they could be set for a constant level.
Just remember that if you're shooting above sync speed, all the lights have to be in HSS mode, whether Manual+HSS or ETTL+HSS.
Jan 15, 2012 at 01:11 AM
cgardner
p.1 #3 · CANON: HSS off camera discussion no triggers
1) Confirming what Brian said the HSS indicator should appear and toggle on/off on the display when HHS button on the flash is pressed in either ETTL or M mode.
2) The Master always defaults to Group A. If you also set the Slave to A then both will fire at the same power. If set the slave to B then you can set each separately from the master flash or camera menu.
3) No. You can't mix modes because the slave gets it's orders from the master. It can be a bit confusing when switching modes back and forth until you realize the display on the slave does not change until after the first shot is taken in the new mode and it gets the change order via pre-flash from the master.
Below are some HSS range tests I did in M mode. I started with an ambient only baseline, exposing per the clipping warning to keep the sunny parts just at/below clipping...
http://super.nova.org/TP/HSS/_MG_5034.jpg
First using a single flash directly at 1/1 I changed distance until the front side highlights were exposed just slightly darker than the sunny ones....
http://super.nova.org/TP/HSS/_MG_5026.jpg
I found the max. range at ISO 100 was about 7ft.
Something to realize about lighting patterns when flash is added outdoors in backlight is that before flash is added the skylight creates downward "butterfly" style modeling on a subject's face and clothing. You can see this if you shoot ambient only, ignore the fact the background is blown out and expose based on the highlights on the face. Something else to be aware of is that the angle of the skylight can create dark eye sockets unless you get the face up into the skylight. That's why outdoors with adults I find something to stand on or bring along a small ladder. Raising the camera and saying "hey look at me" gets light into the eyes without the camera shooting up the nose. That's not necessary with kids because you are taller, but still watch out for shaded orbits.
What happens when you add flash from near the camera axis (e.g. hot shoe) it that in the process of lifting the shadow side the flat flash also cancels out most of the modeling from the skylight and you'll wind up with results similar in appearance to a flat flash shots indoors on the faces. The solution to that is to add your second flash from the same direction the natural light was already modeling the face. For a full face shot with a natural butterfly pattern on it all you need to to is raise the flash straight up on a flash bracket. I always use a bracket so I always automatically get a butterfly style pattern of flash over the top of the butterfly pattern of natural light in full face views with just one flash...
http://super.nova.org/TP/BelenBacklitEyes.jpg
You can see the highlight pattern the flash creates over the skylight better when the photo is blurred...
http://super.nova.org/TP/BelenBacklitBlur.jpg
The flash falls off front>back on the face framing it with shadows. The sides of the face not hit by the flash wind up with skylight fill. No fill is usually need, because the shadows on the sides frame and slim the faces and the pattern doesn't creating any distracting shadow on the face.
With one flash you don't have much control over the shadows. They are what the brightness of the sky and camera's range make them. Normally the shaded side is 3 stops darker — Sunny 16/Shady 5.6. That's almost half the range of the camera which is why the front side is so dark when the back is exposed below clipping.
http://super.nova.org/TP/HSS/_MG_5034_Zones.jpg
At the beach or near a white building you'll get added natural fill. In my shot above the white clothing added bounced fill up onto the face in much the same way. So the same strategy at the beach or light clothing may look different, with darker shadows, in darker surroundings with less reflective clothing.
Setting exposure in front is simple. I place the sunny highlight 1/3 below clipping in the playback. On the front I raise flash until the front side clips then back off two 1/3 stop clicks putting the flash lit highlights 1/3 stop below the sunny ones.
There's no rule that says you must expose the highlights below clipping. If you choose to allow the sunny highlights to clip and lose detail the more you clip them the lighter the sky-lit shadows will be. That's how many expose with flash outdoors, gauging exposure by the tone of the shadows at the cost of blowing the highlights. Rather than clip highlights what I'll do when using my bracket in a full face view is put my slave below camera about chin level to the subject.
http://super.nova.org/TP/ButterflyCanon2.jpg
As I mentioned outdoors I'm usually shooting from a higher vantage point making Master the "key". I put my slave as fill about chin level with the subject, sun directly behind. This one was a higher than normal POV because I was trying to eliminate the distractions behind her...
http://super.nova.org/TP/ButterflyCanonExample.jpg
With the the fill added there's much more detail in the uniform and black shoes than there would have been with just one flash.
If you want natural looking flash shots outdoors start by taking full advantage of the natural light and complement it with the flash instead of fighting it. When moving my off camera flash 45° from the nose light an oblique view I first do the same thing I do with single flash: first pose the face towards the skylight keeping direct sunlight off the face.
As shown above in the single flash shot the Master / Fill on the camera bracket more or less kills the modeling created by posing the face to the brighter skylight. To restore that natural modeling the logical thing to so is to ass the second Key flash from the same 45° angle relative to the nose the skylight was modeling it before flash was added. That's what I mean about the flash complementing the natural light not fighting it.
Back to the HSS range test. Here because Master/Fill only needs to raise the shadows to the point detail is revealed the range increases. Out of years of habit using similar powered manual flashes once I got the shadows dialed in at 1/1 power via distance I just moved my Slave/key light in at a 45° angle until overlapping the fill it exposed the highlights just below the sunny ones that still retain detail. It wound up at 6ft.
http://super.nova.org/TP/HSS/_MG_5035.jpg
In HHS changing to a wider aperture and adjusting the shutter to keep the sunny highlights the same, below clipping, didn't affect the flash exposure....
http://super.nova.org/TP/HSS/_MG_5037.jpg
Something you will note in these test shots is the background looks under exposed. That's the cause and effect of: 1) the sensor range being shorter than the scene range, and 2) the decision to expose the sunny white highlights below clipping.
Any time a scene is longer in f/stop than the sensor range and exposure is set for sunny whites below clipping EVERYTHING in the photo darker than white will wind up looking underexposed. At some point in the darker shaded areas you'll reach the DR threshold where there is no scene detail recorded and only the residual noise is seen. The fact the background isn't "normal" will be noticed less when less of the underexposed background in shown in a photo.
http://super.nova.org/TP/HSS/_MG_5035_Cropped.jpg
I do controlled tests like that so I know the limits of my equipment and don't exceed them. I know when using HSS with dual flash to stay within 10ft with camera and fill. Beyond 10ft I know I will need to revert to normal flash mode and deal with the DOF at 1/250th @ F/11 @ ISO 100 in other ways like finding less distracting backgrounds.
I normally shoot in ETTL mode because it's easier to set ratio and I don't need to be concerned as much about flash distance with regard to ratio and exposure. I know from testing A:B = 1:2 fits the full range of the foreground to the DR of my sensor so I use that as my starting baseline. I take a test shots, adjusting FEC so highlights are just at/below clipping winding up with a full-range, perfectly exposed file that reproduces the foreground similar to the way my eyes see it — "normally".
When shooting with ETTL ratios I also pre-configure M mode A and B both at 1/1. That way when shooting in ETTL and FEC adjustments don't seem to be affecting exposure as I expect them to I can press the mode button, switch to M and fire off a full-power test shot to see how close the flash is to it's max range at the camera settings I'm using.
I usually use two flashes, one bracket and one off camera. Indoors I can control background tone with a combination of shooting and subject/background distance (i.e. via inverse-square fall-off) and by splitting my fill or key by bouncing some light off the ceiling and some directly using my DIY diffusers. I'll occasionally add a third flash when needed for background control as in this shot...
http://super.nova.org/TP/LightingDiagram.jpg
Group C operates differently in ETTL and M modes. The way the flash is metered in ETTL A:B are set via the bar scale on the display. C isn't included in the ratio or exposure calculation. C is set on the Master via a +/- setting. C=0 is the default guess by the metering. Take a shot, look at a the A:B foreground vs. C background when adjust C + or - to make it lighter/darker relative to the foreground. C shouldn't hit the foreground because it will affect exposure in unpredictable ways. So for example you wouldn't want to use C as a hair light. For hairlight in ETTL the better strategy would be to put Key and Hairlight both in Group B and a similar distance to the nearest part of the subject they hit.
In M mode since there is no metering the three groups can be used in any role.
Jan 17, 2012 at 03:04 PM
BrianO
p.1 #4 · CANON: HSS off camera discussion no triggers
BrianO wrote:
...set one or more flashes to Manual power using the on-flash controls, and they can then be mixed with A, B, and/or C Groups set to ETTL.
cgardner wrote:
...You can't mix modes because the slave gets it's orders from the master.
This is too funny; I explain how to do it, and in the very next post Chuck says it can't be done.
I left out one piece of information on purpose; a bit of a test, as it were. If anyone other than Chuck wants to know how it's done, send me a PM.
Jan 18, 2012 at 04:06 AM
cgardner
p.1 #5 · CANON: HSS off camera discussion no triggers
The first part of the question was can Group A (Master) be set in M mode and operate a slave set in ETTL mode. I know no way of doing that, and your answer while correct in a different context, isn't correct with regards to that specific question.
One reason is that when the Master flash is set to M mode the control interface on the Master flash changes so there is no way to remotely control ETTL functionality on the slave. Also as I mentioned the slave designed to function in the system as a passive partner getting instructions from the Master.
Thus if the Master (Group A) is in M mode the first coded signal it sends to the slave is "Use Manual Mode for the next shot". When the Master is M mode the pre-flash command sequences are also difference. In ETTL each group fires separately for the purpose of metering as shown below:
http://super.nova.org/TP/CanonETTL.jpg
But in M mode since there is no metering controlling the flashes the metering pre-flashes are omitted. The Master knowing the desired power setting for each group just needs to relay them to each slave then tell it when to fire.
The situation is different if the Master is in ETTL mode. If the the Master is in ETTL mode the A:B ratio and C group FEC control interface is in play and the Master can control the slaves in those groups via ETTL (camera controlled metering).
Canon flashes also have the ability to be put in independent mode so they can be used manually with third party radio or optical slave triggers. On a 580ex this mode is accessed by putting the flash in Slave mode then pressing and holding the mode button for 2 second until the "M" indicator on the flash blinks. Desired MANUAL power level is then set at the flash. This is covered on p. 43 of the 580ex manual. The controls on the 580exII may differ but as I understand it the functionality is similar.
When placed in "Dumb Manual" mode the slave flash will ignore the pre-flashes from the Master and metering flashes from the slaves operating in ETTL mode but will respond to the signal from the Master's pre-flash signal to fire the main flash, or via a signal via the center pin (or the external PC on the 580exII) from a third party trigger.
So to recap, if the Master in M mode it can't to my knowledge control a slave in ETTL for two reasons: the control interface and the lack of any metering pre-flashes ETTL would need to work.
But if the Master in ETTL mode it can also fire a slave if placed in the "dumb" blinking "M" mode. But what is possible often isn't advisable. The manual flash(es) won't be included in the metering for the ETTL flashes and if they overlap the ETTL flashes those areas will become overexposed.
There are control options with the system such as overriding FEC or manual power setting at the slave. You might want to do the for example if using key and hairlight both in Group B in a three flash configuration (Group A master as fill) to control the hairlight power separately.
As for the second part of the OP's question "... or ideally HSS manual? " the answer to that was covered in the previous answers about whether HSS could be used in manual mode. Yes that is possible, but I thought that would be obvious once the OP understood how to operate in HSS M mode on Master and Slaves.
So Brian, if you do know how to put the Master in M mode and then meter and control a slave in ETTL mode with the Canon system please enlighten me how that is done and I will bow in your general direction....
Jan 18, 2012 at 08:20 AM
BrianO
p.1 #6 · CANON: HSS off camera discussion no triggers
cgardner wrote:
The first part of the question was can Group A ( Master) be set in M mode and operate a slave set in ETTL mode. ...So Brian, if you do know how to put the Master in M mode and then meter and control a slave in ETTL mode with the Canon system please enlighten me how that is done and I will bow in your general direction...
The OP never said "Master," he said only "Group A." I then went into detail to say that, no, it couldn't be done, as far as I know, with groups, but could be done individually. You then -- following my post -- said you couldn't mix modes, period. You didn't say "except as Brian explained," or "unless switched out of group mode," or anything like that, nor did you say "You can't put the Master in Manual and Slaves in ETTL; you just said "No, you can't mix modes."
Since your post immediately followed mine I took it to mean exactly what it said, which was wrong; however since you did include the numbered reference to the OP's post, I'll accept your explaination that you were not including non-group modes when you said it couldn't be done.
Jan 18, 2012 at 12:19 PM
MTBtrials
p.1 #7 · CANON: HSS off camera discussion no triggers
Thanks for the awesome replies guys
After reading your replies and starting to get my head around the canon system a bit more, I found I have a problem with one of my flash units.... and it's sort of putting a damper on what I can easily do from camera.... my 580ex1 is "stuck" in master mode, I removed the hot shoe and confirmed that one of the times the flash has fallen while on a light stand (I really need to bring an assistant for my e-sessions ) the internal part of the selector to set the mode for the off/master/slave is completely broken, so my 580ex1 is "stuck" in master mode. This might not sound like a problem, but I realized how much easier it is to "assign" commands from my 5D2 with the 580ex2 on the hot shoe, than it is to muddle about in the confusing menus of my 580ex1.
The reason I wanted to have my "Master" in manual is to save battery consumption. In the bright sunlight, in HSS mode, it's killing two sets of batteries simultaneously, and I'm not even using my on-camera flash as part of the exposure!!! The main objective I would like to achieve would be to be able to use HSS with my off camera flash (assuming the on-camera is a canon model).
I guess I'm more looking for a means to an end, than to do something specific or special in one mode or another. After reading both of your posts several times over, I understand that I can have group A (assuming this is the on camera for this discussion) and group B set at different levels, but this seems like it needs to be a ratio like 1:2 or something to that effect opposed to saying group A at -4 and group B (assuming this is the off camera unit in slave mode) is at perhaps +2/3ev...
I know that I can use on-camera fill flash with HSS to make my subjects have eyes & detail again, but I mainly want to be able to shoot outdoors in AV mode (aperture priority) and run on the camera at -2/3 to get a little more contrast in the clouds or to get a bit more saturation in the background, and at +1/3 on the flash to get my subject to *pop* (like the second picture... the one of my daughter)
When I have tried setting my 580ex2, on the stand, slave, group A (or is it 1?) to 1/4 power with HSS. I still get the telltale not HSS band. I am not sure what I am doing wrong, unless I need to manually set it to HSS in a different group than the master? I dunno, I'm planning on messing around with the setup a little more today
Thanks guys!
Mark
Jan 19, 2012 at 01:19 PM
BrianO
p.1 #8 · CANON: HSS off camera discussion no triggers
MTBtrials wrote:
...I found I have a problem with one of my flash units.... and it's sort of putting a damper on what I can easily do from camera.... my 580ex1 is "stuck" in master mode, I removed the hot shoe and confirmed that one of the times the flash has fallen while on a light stand (I really need to bring an assistant for my e-sessions ) the internal part of the selector to set the mode for the off/master/slave is completely broken, so my 580ex1 is "stuck" in master mode.
You can replace the broken foot in about 5 minutes; you only need a small Phillips screwdriver. There are no high-voltage circuits in the foot, so it's not dangerous like taking apart the flash body might be.
Here's one link for a replacement foot. Don't wait, supplies are limited:
http://www.flashzebra.com/canon580ex_footassembly.shtml
MTBtrials wrote:
...The reason I wanted to have my "Master" in manual is to save battery consumption. In the bright sunlight, in HSS mode, it's killing two sets of batteries simultaneously, and I'm not even using my on-camera flash as part of the exposure!!!
You need to set the on-camera Master not to fire for exposure. This can be done in either Manual or ETTL modes. In ETTL mode it will still fire the preflash metering and comand pulses, but it will not contribute to the exposure. That will allow the batteries to last longer, and you can still fire the off-camera Group A slave(s) at any power level you desire.
https://www.fredmiranda.com/forum/ufiles/63/521463.jpg
Jan 19, 2012 at 03:55 PM
MTBtrials
p.1 #9 · CANON: HSS off camera discussion no triggers
Thanks Brian!!! I hadn't picked up on the master firing/not firing!
As far as the broken part, it's actually part of the flash it's self (I did the same mod on my hotshoe ) there is a little switch on a circuit board that the switch on the hot shoe interacts with.... that is what is broken on my 580ex1....
Super helpful! Thanks!
Mark
Jan 19, 2012 at 11:22 PM
BrianO
p.1 #10 · CANON: HSS off camera discussion no triggers
MTBtrials wrote:
...As far as the broken part, it's actually part of the flash it's self (I did the same mod on my hotshoe ) there is a little switch on a circuit board that the switch on the hot shoe interacts with.... that is what is broken on my 580ex1...
Sorry to hear that; I guess you have a DMF now. (That's a "Dedicated Master Flash.")
Edited on Jan 20, 2012 at 12:30 AM · View previous versions
Jan 19, 2012 at 11:45 PM
MTBtrials
p.1 #11 · CANON: HSS off camera discussion no triggers
lol, for the remainder of my vacation at least
Canon CPS still shows the 580ex1 on their list of repair-ables. Have you heard otherwise? I plan on sending a few pieces of gear in for a tune-up along with my 5D2 when I get back in town.... I want to get the sensor cleaned on my 5D2 (dust at f/14+ is really noticeable) and I have two bad pixels (which isn't bad considering I've shot over 3TB worth of images on the camera so far). (does CPS offer a free checkup/cleaning for silver members?)
Thanks again for all the help!
Jan 19, 2012 at 11:58 PM
cgardner
p.1 #12 · CANON: HSS off camera discussion no triggers
The Master flash defaults to Group A when it placed into Master mode so it is a given. Also if the Master is on or over the camera it acts as fill. If also you like to do the Master is placed on a 25' long TTL cord A can be used as key or fill. But again the OP appeared to be using the Master as I do so my advice was correct in the context of the question.
Some new users don't realize the Master is A by default because the manual, at least for the 580ex, never explicitly states that fact. But it becomes obvious when A:B ratios are used with the Master in the hotshoe or bracket because the Master Group A acts as Fill and the the Key requiring an A:B= 1:2 ratio to produce the same actual ratio as a 3:1 H:S ratio set manually.
H:S
1:1 Fill (Group A on axis)
2:0 Key (Group B off axis)
3:1 Reflected ratio
What the A:B ratio numbers express is not the reflected ratio as with the H:S convention but the relative incident strengths where they hit the subject and reflect when fired separately. During the pre-flash phase the A:B groups are not fired together to meter the ratio, likely because the metering zones on the viewfinder are not small enough to it accurately. It's because the evaluative zones the metering uses are so large that any TTL exposure will have a margin for error in small highlight areas.
When the Master is used on-axis (as required for the metering notation convention to work) the A:B ratios wind up being the reverse of the convention That is very confusing for many and one of the reasons I wrote my tutorials back in 2005 when I got mine and figured it out.
There's no rule that says fill must be centered but the ratio convention dates back to when that as normal practice. That's why two equal lights 1:1 incident, create a 2:1 H:S reflected ratio. The ratio math only works when fill is the same everywhere on the face and the key light overlaps:
H:S
1:0 Key (Group B off axis)
2:1 Reflected ratio
The "key" by definition is the source creating the modeling over the "fill", not in opposition to it. When two equal incident lights overlap the one creating the highlights is the key and the other the fill.
When two lights are placed on opposite sides this occurs:
H:S
1:0 light on left
0:1 light on right
1:1
In that situation there are two "key" lights and no fill. Both sides of the face are the same brightness and if the lights are moved far enough to the side you get a dark stripe down the middle of a 3D face or object. On a face there will be no fill in places like smile lines, the mouth and other places the cheeks shade both lights (cast shadows) and the tip nose will often have shadows going two different directions. It's great strategy to copy flat artwork without reflections back into the camera (one I used at National Geographic on a copy camera) but not one that is natural, flattering.
When lights are place that way with unequal power the brighter become the key and weaker the fill and they work in opposition to each other creating a split pattern but there is always darker stripe in the middle..
http://super.nova.org/DPR/Canon/images/ABtest2.jpg
In terms of cause and effect split / crossed lighting can be effective on white background because it makes the darker front of the face contrast more. The eye is pulled from lighter edges to faces and held there. It is also a way to create a ying/yang or dark/light dual personality vibe in a portrait. But when using that strategy one must watch for low spot in the shade of both lights because they will be very dark (e.g., smile lines, in and around the mouth where shaded by the cheeks).
I find that for the type of PJ style location shooting I do with my speedlights the centered fill on bracket strategy works best because I never need worry about fill placement or unfilled harsh shadows. Can simply dial in a ratio to set the mood, move my key light as needed to meet the creative goals for the shot pattern-wise, and the only adjustment required is FEC to keep the highlights under clipping.
In situations like those where you probably use your Master on a 25' leash for static setups I will instead be using my studio lights at home, or in the field I would use three speedlights, keeping one in centered to ensure I don't have unfilled dark gaps in my lighting pattern and two off of the sides as in this shot I did for a marketing piece at work for our copier management section which manages the 1,000 or so copiers at the US State Dept.
http://super.nova.org/TP/Three580ex.jpg
The challenge there was "short" lighting the two opposite oblique subjects and the full face subject behind in a flattering way with them different distances from the same. Part of the solution was to put the guy in the middle against a white background making the resulting crossed key lights work better on his face. The fill was centered split with my DIY diffuser on my bracket standing on a chair with the top of pressed to the ceiling for maximum spill fill into the background.
I light perceptually based on an understanding of how things like ratio affect perception. I start from a A:B = 1:2 baseline, see what that ratio which normally fits scene to sensor produces and adjust the ratio if it isn't revealing the shadow detail I want.
The second day I owned my Canon flashes I set up this this target and did a test to visualize what the different ratios actually produced and how accurately the metering would control them
http://super.nova.org/TP/RatioTestShot.jpg
The Group A fill on bracket was illuminating everything evenly except for front>back fall. Group B was to the right and only hitting the right side of the binder. Both lights overlapped on the flat card. I started with A:B = 1:1 and adjusted FEC to make the highlights white but allow some headroom for measuring fluctuation, then "ran the table" on the ratios from 8:1 to 1:8 without changing anything other than ratio.
http://super.nova.org/TP/CanonRatioTest.jpg
As you can see from 8:1 to 1:1 there is very little difference because in that configuration the Fill is overpower the Key with those ratios. At 1:1 the same 1K+1F:1F = 2:1 reflected ratio overlaps similar to the appearance of a manually set H:S = 2:1 , a A:B=1:2 looks similar to the conventionally metered H:S = 3:1 and so on. More or less.
In practice factors such as the modifiers used and how much bounced spill fill they contribute will change appearance of even conventionally incident metered and ETTL controlled ratios so you shouldn't get hung up on the numbers. The same H:S ratio set with a meter will even look different on light and dark backgrounds because the pupil of the eye reacts to overall brightness level in the field of vision making the same shadow tone that looks "normal" on a dark background appear darker when viewed surrounded by a white one.
http://super.nova.org/TP/RatiosPerception.jpg
There are two somewhat conflicting agendas with lighting. Technically it is desirable to fit the scene range to the sensor because that is what allows the camera to record detail everywhere, but the ratio needed to accomplish that often is not the one desired for conveying the mood of the subject or convey that the environment the subject is in.
I find that a 3:1 conventional or A:B = 1:2 ratio fits an indoor flash lit scene like my test example to the sensor. If I use 2:1 / A:B = 1:1 I get lighter shadows which perceptually makes the objects seem rounder and less angular — "softer" in lighting parlance. Why? The highlights are the same after exposure is adjusted but the lighter shadows lower the overall contrast gradient. Even of you use direct flash or very small modifiers and simply change the lighting ratio to create lighter shadows the overall perception will seem softer even with sharply defined shadows because the contrast gradient is less steep between highlight and shadows.
Choice of modification strategy matters with HSS because of the limited power. Modification strategy impacts light placement and key / fill strategies. The ones that work best with HHS aren't necessarily the best in general for lighting, but the best solutions to work around the power limitation successfully. Bringing a knife to a gunfight isn't wise, but having one available for close quarters combat when the bullets run out isn't a bad idea either.
The mood in lighting is created by controlling the shadows: placement with the key light, tone with the fill power, and transitions with fill placement.
Fill placed at camera falls off front > back on a face making the nose shadow the lightest one with a gradient in an oblique view that fades darker towards the ears helping to hide them. Fill placed to over on the shadow side of in the same oblique pose will create the opposite gradient in the shadows. The light> dark gradient is the reverse of frontal fill. The ear, being closer, to the fill will be brighter than the nose shadow furthest away. The nose often winds up with the darkest shadow on the face and if the fill is placed further back than the tip of the nose the nose and cheeks begin to shade it.
It's not a matter of one strategy being better than the other in absolute terms, but rather if shadows created by the strategy are a good match to the intended mood or impression one is trying to create with the lighting pattern.
For beginners fill is an afterthought. They are so focused on getting that flash off the camera axis that all they can see is what the key light is doing. Understanding what is happening in the shadows is a bit like tasting wine. If all you have ever tasted is $5/jug table wine you might not appreciate the subtle differences in flavor notes between vintage years of a more expensive non-generic wine. Not because you don't have good taste in general, but because your taste buds and brain haven't been conditioned by drinking hundreds of type and educating your palette regarding the different flavor notes in wine. With wine the difference is discerned in part by the "nose". The same is true for shadows in lighting. It is only by comparing different fill strategies that you can come to discern the difference it makes.
There is a belief by some that bigger is better with modifiers. It is if one needs a huge footprint for a close in light, want to maintain the character of the light as the key is move from 3ft to 10ft. or in situations where the fact as much light is bouncing off the ceiling as aimed directly is an effective lighting strategy....
But want to guess how big my SBs were for this shot?
http://super.nova.org/TP/table/Table04.jpg
You might be surprised.
http://super.nova.org/TP/table/Setup.jpg
I just used bare bulb and the room as the SB with a black drape over the right wall to create a subtractive lighting effect. That was to show a furniture maker who e-mailed me for advice how to do shots on a white background with just the two AB lights he owned.
Big modifers create the same cause and effect (less contrast between highlight and shadow tone) because they do two things: increase the family of angles hitting an object and in a small space the larger footprint the create at the same distance (relative to a smaller source) bounces more "spill fill" into the shadows.
If you compare a single large source 45°V/45°H to the nose in a full face shot of a person in a dark sweater vs. two direct flashes, one the same 45°/45° and the other chin level near the camera as fill where you will notice the subtle differences in strategies is the shadow on the side of the nose.
The single larger source light will "wrap" around the rounder forehead and chin and the top of the nose, not be able to put light on the side if the nose: it will remain very dark and between the highlighted forehead, cheeks and chin be very distracting when viewing the portrait.
If take off the big modifier and use it direct from the same spot as the big source it will create the same pattern on the face with highlights on forehead, cheeks and chin defining it's 3D shape with the same mask of highlights. The sided of the nose will also be equally dark. The differences you will see will be: 1) more distinct shadow borders, 2) more specular reflections and smaller catchlights, 3) you need far less flash power to shoot at the same f/stop.
When you add the second direct flash from near the camera it changes the appearance of the first direct source perceptually. Because it is even as it is raised overlapping the key light already adjusted for correct exposure for every stop you increase the fill you will must reduce the power of the key light to keep the highlights the same, thus the more fill that is added the less key light power is needed for exposure at the same f/stop. What you will notice about the nose shadow is that it gets lighter. What you will notice about the borders is that while they are still more distinct than the larger source they are not as sharp and when the direct flash is used without fill. Because the fill source is physically closest to the nose its inverse-square fall off front > back on the face will create a light > dark transition on the shaded side of the face not seen in either single light shots. When the fill is raised to the point where there is detail is revealed in the shadows of the dark shirt the overall appearance on the face will be softer than that of a large source if that large source isn't bouncing spill fill onto the front and sides of the face.
Perceptually the two direct flash strategy can be made to look as soft or softer than a single larger source. Soft/hard and the perception of 3D shape in 2D photos are all optical illusions in terms of cause and effect and there is more than one way to fool a viewer's brain into thinking and object has 3D shape and how angular or rounded that shape is.
The reason this is germane to speedlights and HHS in particular is that speedlights have limited power and it is reduced when HHS is used. Thus using a lighting strategy that employs direct flash will result in greater effective range than one where modifiers cut flash power by 1-2 stops. The strategy I have found works best with direct speedlights —having learned that way and tried everything else since — is to use centered fill with an overlapping key light.
A few years ago in the middle of a thread on how big a modifier is needed outdoors I grabbed the camera and flashes, went outside in the early evening on a summer day and dragged my wife out of the garden to take the shot below....
http://super.nova.org/TP/DualSunBacklight.jpg
It was shot in Av mode, -2 EC to get the sunlit skin on the shoulder and hair below clipping. I used no diffusers, just one 580ex on a bracket and the other 45° from the nose (90° from camera) above and to the right. Flash was in ETTL A:B mode. I don't recall the A:B ratio but it was before I started using a 1:2 starting baseline and I think it was 1:4 in part because I wanted to show the role soft skylight play in that situation. This is not how I would shoot a portrait session nor am I suggesting shooting one that way. But this is typical of how I light most of my candid shots outdoors with speedlights — without diffusers because speedlights just don't have the power to used them. Look at the nose shadow and the transition on the cheeks on the shaded near side. The shadows only get really dark in areas neither the flash fill on the bracket or skylight fill reached. The shadow is dark under the chin because the gray card used to monitor tonal range was shading it.
It's not the best lighting strategy or the most flattering results, but due to the low power and range in HSS mode it is often the only ones that are practical. If only shooting with single flash outdoors in sun I stick with full face poses and "butterfly lighting" because it minimizes shadows. No shadows, no fill needed because the loss of detail, if any, occurs where it is not noticed.
But in an oblique view the darker sky filled shadows alone wouldn't look "normal". That were I will use the two flash strategy with HHS. The added benefit of two lights vs. one is more range — 10ft vs. 7ft with single flash.
I use my fill on a bracket vs a stand because it's simpler logistically. That's a trade off because the bracket puts it higher than chin level which is more ideal for fill, creating a unfilled shadow under the chin. But then so does natural light so it doesn't bother me much.
I also use the same strategy of centered fill for my studio work. There power is not a concern and I can use larger modiifers when needed to make highlights less specular, catchlights bigger, get more "spill fill" when needed, etc. I use centered fill because it makes the nose shadow the lightest and least distracting on the face in my lighting patterns. Others might not notice the difference, but I do. So will anyone who objectively compares the strategies as I suggest.
http://super.nova.org/TP/DIYvsSB.jpg
Above when friends dropped by with their kids I started shooting with speedlights and switched to my studio lights with larger modifiers. I wasn't a "portrait" session, just have my lights set up all time. I didn't reshoot the boy because the speedlight shot was OK. Comparing the results afterwards I noticed, as you will if you look critically, that the girl's shot while using larger modifiers and a bit more and lower placed fill than with the speedlights looked "harder" to me. It puzzled me why until I realized I was reacting perceptually to the specularity in the highlights. The kids had been out in the sun all day sweating. The boy washed his face, the girl wearing make-up didn't. One of the things larger modifiers do is make the skin highlights less specular. but shiny skin will trump a big SB. I could have had her wash her face or use powder to cut the shine but they were just snap shots with decent lighting in t-shirts so I didn't bother.
What matters to me isn't the numerical ratio but how it looks and how I want the viewer to react to it. That's more about understanding the psychological aspects of lighting — how and why the viewer will react to the clues the lighting direction and contrast provided. That's the "bigger picture" beyond learning to control lighting with a meter to create a 2:1 or 4:1 — understanding they trigger different emotional reactions.
The challenge in a flash assisted shot is making the result look natural and not fake. That requires understanding how the brain decides lighting is fake and then avoiding creating those clues in your photos.
The two qualities that help make a viewer thing a photo is natural and real are:
1) the same tonal range they would expect to see in person by eye - a full range of detail.
2) the same directional clues of shadow angle and highlight placement they would see in person within the context of that setting. If the context of the photo is outdoors in mid-day a long sideways shadow hanging off the nose created by a flash placed too low will not seem natural. But if shooting in the afternoon with the natural light creating shadows like than in the background the same low placement of the flash would be in context. Natural light is a moving target because the sun moved in the sky. The flash needs to move similarly in sync and create the same perceptual clues to look "real" outdoors.
Indoors I approach flash as more like lighting a stage. If the ambient indoor lighting alone is doing that in a way that works for the goals of the shot I'll use it. If not I will supplement it and sometimes overpower it. More often than not with color photography the problem isn't the amount or direction of the ambient light but the fact is a different color temp. When practical I may gel the flash to blend it seamlessly. When that isn't possible I will usually take my wide shots where faces are not the focal point with the ambient light only with WB set to match, then crop out the off color background and try to overpower it with the flash for the people shots. When I want more background ambience in mixed lighting I will either bounce either fill, key or both or light the background with flash.
The playback is invaluable. Your eyes can see the ambient, but not how the flash changes it. Back in the days of film the reason technique didn't vary much is because using systematic technique was the only way to predict results and produce a photo without blown highlights or no shadow detail. The playback, histogram, and clipping warning are what allows me the freedom to use my lights a dozen different ways to create lighting patterns, but regardless of the pattern and how I created it I know I need the lighting ratio to fit scene to sensor. I know most of the time A:B = 1:2 used directly does that. But if bouncing and mixing flash with ambient that might not be the case. I start from the baseline of A:B = 1:2 but don't always wind up there in the end result. The "fit scene to sensor" baseline just makes it easier to compare what works better or worse.
Jan 20, 2012 at 02:36 PM
BrianO
p.1 #13 · CANON: HSS off camera discussion no triggers
cgardner wrote:
...Some new users don't realize the Master is A by default because the manual, at least for the 580ex, never explicitly states that fact.
Yeah, I find Canon's manuals woefully inadequate. They tell you which buttons do what, but not much on why to choose one setting over another. They also leave out a lot of important details, like about the Master being part of Group A, as if one would always disable the Master from firing when using slaves. (Maybe they hope to sell more Speedlites that way.)
That's why blogs like yours, and books like Syl Arena's The Speedliter's Handbook and Neil van Niekerk's On-camera Flash and Off-camera Flash are so needed. They really help to fill in the gaps between the how and the why, not to mention how to do it better.
And of course Canon's faults keep sites like this one active.
Jan 20, 2012 at 04:08 PM
cgardner
p.1 #14 · CANON: HSS off camera discussion no triggers
TV's don't come with a guide suggesting what to watch either and Canon's manuals are no worse than most I've read. The manual's job is to explain how the controls work. If you actually go through the manual page by page and try everything, which I usually do with all new gear, it becomes apparent how best to use it.
The trap I think many fall into is expecting one camera or flash to work just like the last one they used. The first thing I did when I got my 20D is put it in P mode and go around and shoot shoot to get a baseline on what the camera defaults did. Then I use Av mode the same way, next I used Av and corrected EC to taste to get a baseline on what types of situations required correction and which the default EC=0 correctly exposed.
I did the same when I got my 580ex, first using P mode and ETTL, then Av and ETTL then correcting with FEC to taste. One snowbound day I tested all 18 different ambient /flash metering combination. The more I test the more I understand what my gear can and can't do. Understanding the limitations, and staying within them I avoid problems others report.
I don't expect my approaches to work for everyone's needs, I just offer it as an approach to try along with everything else that's out there on Strobist, NK Guy's photonotes (he has book now also). NK Guy's site was a early source for me but I found that like the manuals it told now the gear worked not how best to use it. So that's the void I tried to fill with my web site. The Canon stuff is just a side-show to overall site which is a holistic approach to lighting which considers how clothing and background selection is just as important to the overall effectiveness of a photo. What got me started in that direction was something I read in a cinematography book about one of the great ones being able to "light a set with just a bucket of black paint". If someone understands what was meant by that I think any reasonably intelligent and curious person can figure out for themselves what makes lighting work to guide the viewer around a photo to what is most important and trick their brain into thinking it's 3D. It's all just an optical illusion created with various forms of contrast.
As far is the omissions in the manuals in my experience with similar products there is often a disconnect with what engineers think is the best way to solve a problem and how the end user actually uses the product. A good example of that is Canon deciding when first developing the EX flash line that all the digital camera user needed was ETTL camera metering, evidenced by the lack of manual mode on the first EX generation: 420ex and ST-E2. Another of not knowing the practical application of the gear is this diagram in the manual in the section on A:B ratios in ETTL mode
http://super.nova.org/DPR/Canon/images/CrossedAB.jpg
That led some people to think they needed a ST-E2 as a Master and crossing key and fill was how best to light a face.
I blame the 580exII problems on the marketing department. Instead of devoting R&D to what I would have bought like a more powerful flash or a dedicated slave that could be mounted directly on a stand and use a SB without a problem (via sensor on a tether like Vivitar used in the 70s) we got a new battery door, water proofing, an auto sensor mode and PC socket with a host of problems.
When I trigger my Canon 580ex with PW I use arrangement which solve the connecting and mounting problem with one piece of gear vs. needing a cord and a cold shoe. An $8 hot shoe extender I modified with a 1/8" plug from RatShack.
http://super.nova.org/TP/PW_285HV.jpg
I like having the flash controls separate from the camera. Even for FEC I adjust the flash on the bracket not on the camera. So having menu control on the camera isn't something I find even necessary. It was a necessary step to allow the camera flash to act as Master, both currently and long term with Wi-Fi but I want the flash on my camera working as fill as well as signaling.
I was actually surprised to see the results you got with as fill with your new 7D because the specs for the camera said the GN was something like 4 when the on camera flash was used to control the slaves. Like the ST-E2 it can't fire a flash behind the camera on a stand, something I can do with my 580ex master by turning it backwards or just bouncing fill off the ceiling above me.
Also from long experience with Japanese products (my first radio as a kid in the late 50's was a Sony TR-63 transitor radio) and visits to Japan there is often a cultural disconnect. One the reasons I didn't take many still photos in the 80s and 90s was because I was playing around with video. In 1985 wanted one of the new Sony Hi-8 camcorders. I had TDY in Tokyo so I took the subway to Akhiabara to try to find one (an adventure in itself due to the Nihongo only signage). I found one but when I tried to pay with my VISA card they acted like I was a scam artist trying to rip them off. I wound up in the manager's office trying to get the purchase approved, which proved a futile experience. I finally found one at the Navy Exchange.
I think Chuck Westfall better understands what the US market would go for. Back in 2004 when I was first researching switching to Canon I recall seeing a forum thread where he admitted the ST-E2 was weak link in need of upgrading, but eight years later Canon is still selling it. Up until a couple of years ago they were still selling EZ flash components on the on-line store.
Canon I think would benefit from an independent US based R&D / Design team. Mazda used that approach. The idea to create the Miata / MX-5 I drive came from the US team in California which started with the bare bones roadster simplicity of the MG and the styling elegance of the Jag XKE which was always one of my dream cars as a kid (I wasn't into Fords or Chevys). Mazda Japan to its credit listened to the US team and green lighted it as a project and over 20 years later the same basic design is still popular. In 2009, when I bought my MX-5 power hardtop with the Cash for Clunkers gummit handout Motor Trend rated it #3 as most fun to drive, and it is Zoom Zoom. I wish I could say the same about Canon flash.
Jan 20, 2012 at 05:22 PM
