Archive 2012 · Kirk will now put spray on cargo liner material on your l...
sjms
p.1 #1 · Kirk will now put spray on cargo liner material on your long lens feet (
Sure Grip material
we are in marketing heaven now
http://www.kirkphoto.com/Quick-Release-Lens-Plates.html
Jan 13, 2012 at 11:28 PM
p.1 #2 · Kirk will now put spray on cargo liner material on your long lens feet (
I wonder, what would happen if you sent in a RRS lens foot...
Jan 14, 2012 at 12:30 AM
sjms
p.1 #3 · Kirk will now put spray on cargo liner material on your long lens feet (
conflict of interest?
Jan 14, 2012 at 02:56 AM
GroovyGeek
p.1 #4 · Kirk will now put spray on cargo liner material on your long lens feet (
Why would they care if they make the same profit? I can understand the emotions but from a business standpoint it would be a bonehead decision to turn you away.
Jan 15, 2012 at 02:29 AM
runamuck
p.1 #5 · Kirk will now put spray on cargo liner material on your long lens feet (
What will this rough surface do to the smooth surfaces of your ball head over time? If the coating is soft, it will just wear smooth in a short time. If it is too hard, it will chew up your clamping jaws.
Jan 17, 2012 at 02:48 AM
sjms
p.1 #6 · Kirk will now put spray on cargo liner material on your long lens feet (
i think they can precision apply it to the areas that will not come in contact with the jaws
Jan 17, 2012 at 02:51 AM
runamuck
p.1 #7 · Kirk will now put spray on cargo liner material on your long lens feet (
Then what does it come in contact with? If it contacts nothing, it is an exercise in expensive uselessness.
I think the comment about marketing heaven said it best.
Jan 19, 2012 at 12:49 AM
sjms
p.1 #8 · Kirk will now put spray on cargo liner material on your long lens feet (
quote:
" This new coating makes carrying your long lens by our lens foot with this coating safer and more securable"
and
"not allowing the lens foot to slip in your hands even if they are wet"
maybe it is applied to the entire piece.
Jan 19, 2012 at 12:48 PM
rick_reno
p.1 #9 · Kirk will now put spray on cargo liner material on your long lens feet (
My RRS feet fit tight now, I don't think I'd want anything sprayed on them.
Jan 19, 2012 at 03:37 PM
sjms
p.1 #10 · Kirk will now put spray on cargo liner material on your long lens feet (
my experiences with Kirk design keep my preference for RRS well intact. not fandom just better designed and executed overall for the items i use from them
Jan 19, 2012 at 06:39 PM
photomax
p.1 #11 · Kirk will now put spray on cargo liner material on your long lens feet (
The original Canon foot has a padded surface for carrying the lens in the hand. Kirk will do the same thing and apply the coating to the top of the foot where you hand will fall. This would not interfere with the Arca clamp or or grooves. I like the idea.
Jan 19, 2012 at 06:51 PM
GKoenig
p.1 #12 · Kirk will now put spray on cargo liner material on your long lens feet (
I think there are a couple of options out there for folks who would want to add a grippy texture to any lens foot (or piece of anodized aluminum). I am sure Kirk has created some quick masking tooling to make the install of their spray-on-bedliner a bit better than a shade-tree sorta job, but there are lots of good grip material options available.
Agrip is the old-school firearms grip material. They die cut it for various pistols, but they also sell it in sheet form:
http://www.brookstactical.com/index-2.html
Jan 21, 2012 at 07:37 PM
sjms
p.1 #13 · Kirk will now put spray on cargo liner material on your long lens feet (
interesting if one finds a need for it.
Jan 21, 2012 at 11:03 PM
