Archive 2012 · Anything for scanning 110 negatives?
chriscanon
p.1 #1 · Anything for scanning 110 negatives?
I just joined the forum tonight and read through this thread on scanning slides and negatives. But the negatives are 35mm size. Does anyone know how I can scan the hundreds of 110 negatives (and a few other sizes from the 40s, 50s and 60s) I have lying around. They are snapshots, so not all of them are worth reproducing and will have to be looked at one by one. But I could find no scanner that accepts other than 35mm. Any suggestions.
Christine
Jan 09, 2012 at 09:57 PM
Peter Figen
p.1 #2 · Anything for scanning 110 negatives?
Any decent flatbed scanner will scan whatever you put down on it. For snapshot-ish types of images, that may be all you need.
Jan 10, 2012 at 03:56 AM
chriscanon
p.1 #3 · Anything for scanning 110 negatives?
Thanks, Peter. I'll give that a try.
Jan 10, 2012 at 09:03 AM
BauerPower
p.1 #4 · Anything for scanning 110 negatives?
I use a Canon 9000 flatbed scanner. Set it up for scanning negatives and do no use the plastic negative template. Just lay the negative on the flat bed in the area where the upper lid light will shine through it. If the negatives are curly, I sometimes lay a piece of window glass on top of them to keep them flat. Good luck.
Jan 10, 2012 at 09:39 AM
HerbChong
p.1 #5 · Anything for scanning 110 negatives?
if you have a Nikon Coolscan 4000 or 5000, i think they used to make a 110 negative adapter.
Herb...
Jan 10, 2012 at 02:59 PM
