Archive 2011 · Sony Zeiss ZA 24mm f1.8 Sonnar
iskraII
p.1 #1 · Sony Zeiss ZA 24mm f1.8 Sonnar
Unlike other Zeiss lenses I have, this ZA 24mm Sonnar does not come with usual Zeiss MTF chart and optical structure diagram. It has not been listed on official Zeiss website. From a Chinese website, I finally got the information I have looking for. Hope they will help dicussion about this interesting lens. Sonnar or not, you be the judge.
original link is here
http://xjrumo.com/2011/08/24/e24-za/
Dec 24, 2011 at 05:36 PM
Tariq Gibran
p.1 #2 · Sony Zeiss ZA 24mm f1.8 Sonnar
Unfortunately, unlike non za Zeiss lenses, the mtf is only theoretically computed and not measured from a real lens. Thus, actual performance will be lower.
Dec 24, 2011 at 05:50 PM
iskraII
p.1 #3 · Sony Zeiss ZA 24mm f1.8 Sonnar
How do you know it isn't measured? Because of Sony or because of it is APS-C? Thx
Dec 24, 2011 at 06:46 PM
Tariq Gibran
p.1 #4 · Sony Zeiss ZA 24mm f1.8 Sonnar
All you have to do is look at the F8 MTF chart and note the red line for 10 cycles which is right at 100 on the vertical axis in the center of the lens (0 on the horizontal axis). This is an impossible measurement for a real lens. Look at the best Zeiss and Leica measured MTF's and you will not find one which is this high. That's pretty much a dead giveaway this MTF is not real world measured.
Dec 24, 2011 at 07:32 PM
grahamb3
p.1 #5 · Sony Zeiss ZA 24mm f1.8 Sonnar
"ZA" mount lenses are for the Minolta/Sony "alpha" mount DSLR/SLT cameras. The "E" mount on NEX is a smaller mount.
"ZE" are for Canon, so Zeiss for the NEX can't be labeled "ZE", but as they don't fit the Alpha mount, they shouldn't be identified as "ZA".
Dec 25, 2011 at 09:03 AM
AhamB
p.1 #6 · Sony Zeiss ZA 24mm f1.8 Sonnar
Tell that to Sony, because they are the ones calling this lens ZA. It's just the E mount variation of ZA...
Dec 25, 2011 at 09:28 AM
ken.vs.ryu
p.1 #7 · Sony Zeiss ZA 24mm f1.8 Sonnar
ZA = zeiss autofocus
Dec 25, 2011 at 11:07 AM
Tariq Gibran
p.1 #8 · Sony Zeiss ZA 24mm f1.8 Sonnar
The problem is that the nomenclature is not consistant with other Zeiss Z named lenses which are named for the mount they fit onto. We have the ZF for F mount, ZK for K mount and the ZE for the EF mount. Since the Minolta/ Sony SLR AF mount is universally known as the A mount, logic would dictate only those lenses intended for the A mount would be called ZA. This would follow the previous naming scheme above. Saying that ZA stands for Zeiss autofocus would suggest that any Zeiss autofocus lenses designed for Canon or Nikon would be called ZA, and that will never happen. ZA is specific to Sony. Sony created confusion by naming E-mount Zeiss lenses ZA, the same nomenclature used for the A mount...and you can bet this was a Sony choice.
Dec 25, 2011 at 11:17 AM
theSuede
p.1 #9 · Sony Zeiss ZA 24mm f1.8 Sonnar
The best you can do with a true diffraction limited lens (Strehl > very high) is slightly less than:
For F5.6
10lp/mm : 0.94
20lp/mm : 0.90
40lp/mm : 0.79
For F8.0
10lp/mm : 0.92
20lp/mm : 0.85
40lp/mm : 0.71
Anything reporting a number higher than this (it is of course possible, but you have to resort to solutions like wavefront-controlled light collimation, not very probable in a photographic lens case...) is either calculated, or they've cheated really bad.
The MTF charts here should be compared to MTF charts from other Sony lenses, If you know a "good sample" from a similar Sony lens/report system then you can take an educated guess at what the lens will be like - in relation to the "other lens".
Dec 25, 2011 at 12:52 PM
carstenw
p.1 #10 · Sony Zeiss ZA 24mm f1.8 Sonnar
Well, ZE was taken, and I guess Sony wanted to keep some brand recognition too. What else could they have called it, ZN (N for NEX)? Sony shouldn't have called it E-mount, if they had been looking ahead a bit.
Dec 25, 2011 at 04:37 PM
Lotusm50
p.1 #11 · Sony Zeiss ZA 24mm f1.8 Sonnar
Rather, "Zeiss Alpha"
Dec 25, 2011 at 04:49 PM
sebboh
p.1 #12 · Sony Zeiss ZA 24mm f1.8 Sonnar
what about the m42 zeisses? they aren't called ZM because its already taken. they're called ZS for screwmount.
Dec 25, 2011 at 05:12 PM
Tariq Gibran
p.1 #13 · Sony Zeiss ZA 24mm f1.8 Sonnar
Still refers to the mount.
Dec 25, 2011 at 06:55 PM
philip_pj
p.1 #14 · Sony Zeiss ZA 24mm f1.8 Sonnar
Well, more Alpha Zeiss than Zeiss Alpha.
AZ has a better sense of direction to it, like alpha-omega.
Back to the fictional world of computed MTF reality, once you allow a fudge factor in the charts at the top of this thread, the lens seems pretty poorly behaved at f8, for users after decent cross frame, fine detail performance. Each line has seemingly developed a mind of its own. Pretty tidy at wide open aperture however, even at 15% off.
This is one good example why I wish CZ would publish the ZA lens data on their own website along with their other designs, past and present. Measured on an optical bench along with the others, thank you.
Dec 26, 2011 at 05:45 AM
douglasf13
p.1 #15 · Sony Zeiss ZA 24mm f1.8 Sonnar
FWIW, all Sony DSLRs, SLTs and NEX cameras fall under the Alpha moniker, which contains both a-mount and e-mount.
So:
ZA means Sony a-mount lens for 135 sensor.
ZA DT means Sony a-mount lens for aps-c sensor.
ZA E means Sony e-mount lens for aps-c sensor.
Dec 26, 2011 at 11:39 AM
FlyPenFly
p.1 #16 · Sony Zeiss ZA 24mm f1.8 Sonnar
It seems Kurt Munger has reviewed this lens and it seems okay.
I'm seriously considering it.
The biggest weakness seems to be purple fringing CA. Otherwise, corners look OK but not great.
Feb 13, 2012 at 11:42 AM
drofpilneb
p.1 #17 · Sony Zeiss ZA 24mm f1.8 Sonnar
On all accounts I've read (Digllyod, Steve Huff to name 2) and shots I've seen, it seems like it will be a winner. Maybe not razor sharp at 1.8, but lots of character, good color and Zeiss contrast. It is certainly bigger than the m4/3 options, but from the spec, it's quite light. I'm definitely going to try it out with my Nex 7, assuming that ever arrives.
Feb 13, 2012 at 12:51 PM
FlyPenFly
p.1 #18 · Sony Zeiss ZA 24mm f1.8 Sonnar
Yeah, I have the Contax G 45mm F2 and it's a phenom lens when I can nail the focus but I've found I've missed focus on about 50% of shots if I'm trying to do a quick or candid portrait of my friends or life.
It's just frustrating so I think this lens might do the trick and I'll be able to use ambient light. Every review says that the AF is spectacularly fast and with Contrast detect, should be 100% accurate.
If I need to do landscapes, I'll break out the Contax G 45mm.
It does seem to have an unusually large amount of CA for a F1.8 APS-C lens without OSS at $1000 but choices are pretty limited.
Feb 13, 2012 at 01:05 PM
mawz
p.1 #19 · Sony Zeiss ZA 24mm f1.8 Sonnar
It's a lens with some definite character. Expect it to be very good close in and in the centre, it gets weaker at the edges and at infinity, but remains quite acceptable in performance, especially stopped down. The corners do get a lot better when stopped down.
My experience is it's great at wide apertures and short/mid focal distances and quite good at infinity when stopped down to f5.6-8. Rendering is very much a Sonnar look, so somewhat smoother than your typical Zeiss Planar or Distagon.
Feb 13, 2012 at 01:09 PM
ken.vs.ryu
p.1 #20 · Sony Zeiss ZA 24mm f1.8 Sonnar
with the rising prices for G lenses, the ZA 24 E is becoming a bargain.
Feb 13, 2012 at 01:13 PM
