Archive 2011 · mp-e3 replacement
kateman
p.1 #1 · mp-e3 replacement
searched the forum...
did not find a definitive answer.
so...i am using 1D mkIIs' for backups.
what is the best after market replacement
for mp-e3 batteries?
thanks in advance.
B
Dec 11, 2011 at 02:03 PM
Ian.Dobinson
p.1 #2 · mp-e3 replacement
Lenmar gets a good rep on here.
As far as I have used I have found a few cheap ebay ones perform just as well as a genuine canon . the only thing I have had to do is take the caps from a genuine canon and put on the 3rd party one.
It seems to be a thing with all the 3rd party ones that the caps dont fit as well as genuine
Dec 11, 2011 at 02:09 PM
omarlyn
p.1 #3 · mp-e3 replacement
B
Well, if you searched for 'MP-E3' batteries, you likely got zero results because it's actually an 'NP-E3' battery.
In any case, My Lenmar replacements are fantastic on my 1D…I recently shot a 4,000 entry race event on two batteries (never actually having completely exhausted either battery)
HTH,
Omar
Dec 11, 2011 at 02:11 PM
kateman
p.1 #4 · mp-e3 replacement
Ian and Omar, thanks for the replys and suggestion.
Omar, spelling has never been my strongest attribute.
I will try the Lanmar's.
Omar, have you had to replace the caps as Ian suggested?
while i was waiting for replies, a google search implied that
this is the best solution.
B
Dec 11, 2011 at 02:22 PM
p.1 #5 · mp-e3 replacement
I used Lenmar's with great satisfaction for my two 1DII's.
Dec 11, 2011 at 02:24 PM
mco_970
p.1 #6 · mp-e3 replacement
I put Lenmars on my 1D2n and the Lenmar caps fit OK, but I kept the Canon ones just in case.
Ian.Dobinson
p.1 #7 · mp-e3 replacement
On my previous 1D2n i got 2 cheap ebay ones to replace a knackered genuine that refused to hold charge. the 3rd party ones were absolutly fine and held charge very well . the only issue I had with their caps was when n portrait orientation the camera could shut off (no probs in landscape) . so I took a cap from the genuine and replaced it on one of the ebay ones. result a perfect battery.
search places like ebay for knackered genuine ones. they do have a cost but they are worth it.
Dec 11, 2011 at 02:28 PM
kateman
p.1 #8 · mp-e3 replacement
Jcolwell, mco and Ian...
thanks for the imput.
everyones' advice has convinced me.
tracking down Lenmars now.
again thanks, all.
This FM place rocks.
B
Dec 11, 2011 at 02:35 PM
omarlyn
p.1 #9 · mp-e3 replacement
B
I did it once but found the Lenmar fit to be just as good as the OEM Canon so I actually switched it back. For the record, both my Lenmars have been purchased within the last year so I don't know if previous ones had any 'fit issues'.
Omar
Dec 11, 2011 at 02:40 PM
p.1 #10 · mp-e3 replacement
Omar
I had no fit issues with my Lenmars that were purchased in 2008.
Dec 11, 2011 at 02:45 PM
kateman
p.1 #11 · mp-e3 replacement
once again, thanks you guys!
got lenmars on the way.
B
Dec 11, 2011 at 03:23 PM
Daigen-za
p.1 #12 · mp-e3 replacement
Here's a copy of the reply I just posted in another battery thread:
I also use Lenmars (have 2) purchased from Amazon.
The fit (at the front curved edge where the release push button is located) is not flush to the camera body like with my two Canon batteries.
First one purchased a year or so ago, shot an event 1300+ pictures with 1D2 and battery indicator still showed full.
Purchased second one a month ago, recently shot an event 700+ pictures with 1Ds2 and battery indicator shows full.
As recommended by a forum member in an older thread, prior to using a new battery I use the REFRESH option on the Canon charger, and then let it stay connected to the charger for a least a couple hours after the charger indicates the battery is fully charged.
The thought being that the charger will indicate the battery is fully charged when really it is only say perhaps 95% charged. So keep charging particularly for that first charge. Don't know how accurate this is but doesn't seem to have hurt my batteries, particularly my first Lenmar. The second Lenmar I haven't yet run to empty.
https://www.fredmiranda.com/forum/topic/1069052/0#lastmessage
Dec 15, 2011 at 11:05 AM
