Genes Home Offline Upload & Sell: Off
p.1 #8 · Does photo use matter for what you charge? | |
Mark L has a point, but it is VERY negotiable.
1. If they give you a contract that makes you an employee working for a specified rate per hour and indicate you are a working as a photographer under their umbrella, then you are a "for hire" employee and any work you produce belongs to them, lock stock and barrel. You get no copyrights. There is nothing wrong with this, as long as your contract calls out specifically how much post processing and editing you are going to be performing, and how that time will be accounted for and paid for (normally at the same rate as your actual photography and to-from transport time). In this case you should also charge a rental fee for all of your equipment. Just be sure they are paying a living wage that INCLUDES your social security, insurance, etc.
2. If they are hiring you under a normal independent business contract (the way most photographers work), you will negotiate a fixed price for your time, PLUS a fixed price for each deliverable. You have to define what those deliverables are, and be sure you can live within those constraints and still make a living wage. Usage is a MAJOR factor. One portrait of a business team to hang on the wall and publish in the annual report is pretty simply, but rights to indefiantely publish, edit, revise and even sell or use in commercial advertising is something else again - primarily becuase you are losing the ability to sell those images for those purposes yourself. Basically, you want to charge the customer for "lost opportunity costs".....most understand this and will negotiate with you on this item.
Gene
