Archive 2011 · Epson 3800 maintenance request 0088
bridant1
p.1 #1 · Epson 3800 maintenance request 0088
I'm getting the message "maintenance request 0088" on my 3800 printer. I think this means the internal clock battery needs replacing. Cannot find anything with a google search on how to replace the battery. Anyone have any info on this problem?
Nov 07, 2011 at 11:57 AM
Jack Heckaman
p.1 #2 · Epson 3800 maintenance request 0088
Yep - RTC battery is done - Replace and Execute RTC initialization using the Adjustment Program.
I have the maintenance manual in digital form. PM me if you are interested in a copy.
Nov 07, 2011 at 01:41 PM
ecidi
p.1 #3 · Epson 3800 maintenance request 0088
Where is the RTC battery located in an epson 3800?
Nov 08, 2011 at 10:50 AM
howardm4
p.1 #4 · Epson 3800 maintenance request 0088
on the motherboard accessible from the back after some screw removal etc
Nov 08, 2011 at 03:07 PM
benton1
p.1 #5 · Epson 3800 maintenance request 0088
Does anyone know where to get the appropriate nvram.exe for the Epson 3800? I have a maintenance task to perform.
Best Regards
Feb 16, 2012 at 02:54 PM
benton1
p.1 #6 · Epson 3800 maintenance request 0088
Still looking for the maintenance software for Epson Pro 3800
Best Regards
Apr 22, 2012 at 02:59 PM
scchang
p.1 #7 · Epson 3800 maintenance request 0088
I can't find the battery type for the RTC backup. I'd like to have one before I take the printer apart. Does anyone know what type of battery is needed? Thanks.
Edit: I couldn't wait: It's a CR2032
May 11, 2014 at 05:32 PM
xvvvz
p.1 #8 · Epson 3800 maintenance request 0088
>> Execute RTC initialization using the Adjustment Program<<
Where can this software be found, please? Is there any way to replace the battery without requiring the program?
Thanks!
May 11, 2014 at 10:26 PM
scchang
p.1 #9 · Epson 3800 maintenance request 0088
I found it here: http://tempfile.ru/file/2658895
You'll also want the service manual.
I replaced the battery and tried to print, but the error message didn't clear. I ran the adjustment program and was able to set the RTC clock.
All was good after that.
May 12, 2014 at 10:30 AM
xvvvz
p.1 #10 · Epson 3800 maintenance request 0088
Thanks. I had already found the service manual .pdf but not the program. I will investigate the link you sent.
Thanks.
May 12, 2014 at 01:51 PM
scchang
p.1 #11 · Epson 3800 maintenance request 0088
I should also mention that the adjustment program is Windows only and the printer driver must be installed.
May 12, 2014 at 03:23 PM
