Archive 2011 · Model Lamp with VML
drew.bowser
p.1 #1 · Model Lamp with VML
So I just got my Vagabond Mini Lithium in today, and I didn't see anyone talking about using a modeling lamp with it...Mainly I saw post complaining about the mount system :P
So I fired up my VML and had the model light on, the pack was humming VERY loudly. Is this normal?
Also, I know Paul says...NO MODEL LAMP, but how would a CFL or a LED bulb work in it? I mean, at 4 watts...how much could a LED really stress the pack?
Oct 19, 2011 at 12:20 PM
mill4570
p.1 #2 · Model Lamp with VML
Have you looked at the PCB Tech forum? The TS people can give you plenty of information on the VML.
I do not use the modeling light on VML power.
Richard K.
Oct 19, 2011 at 12:49 PM
Mr Kris
p.1 #3 · Model Lamp with VML
What strobes are you using? PCB sells a low-wattage modeling lamp for the Einstein specifically with intent to use it with the VML. It is a 25watt lamp.
Oct 19, 2011 at 01:29 PM
drew.bowser
p.1 #4 · Model Lamp with VML
IM using the AB lights. I was specifically thinking about a LED lamp...
I haven't looked at the PCB forum, Ill check it out!
Oct 19, 2011 at 02:01 PM
RoadconePhoto
p.1 #5 · Model Lamp with VML
unless you're shooting in a fairly dark location the low wattage lamps are basically useless for setup... you can get away with one modeling lamp on for a while but i wouldnt push it...
Oct 20, 2011 at 11:57 AM
AdenMendez
p.1 #6 · Model Lamp with VML
You can look into getting some led bulbs. I haven't tried them myself because they're expensive for what they are. I don't know if they'll be useful for an actual WYSIWYG modeling lamp, but if you want them for a focus assist light in darker situations, it should work. However, I believe you loose the lamp tracking ability with the alienbees.
http://strobist.blogspot.com/2011/02/found-30-led-modeling-light-for-your.html
Oct 22, 2011 at 02:17 PM
