Archive 2011 · Charging battiers in car
sboerup
p.1 #1 · Charging battiers in car
So I know that the PCB lights require a Pure sine wave inverter in order to power them, and that those inverters are a bit more expensive.
However, I'm looking for an inverter I can put in my car that I can charge batteries with, like the Powerex AA chargers, but also the Vagabond Mini batteries as well. Would a simple modified sine wave inverter work?
I'm not looking to go cheap, but if the modified sine wave is more than adequate to charge batteries then thats all I care about now.
Example: http://www.amazon.com/Power-Bright-PW400-12-Inverter-Watt/dp/B000OOZY5S/ref=sr_1_1?s=sporting-goods&ie=UTF8&qid=1316890647&sr=1-1
Alternative solutions are welcome
Sep 24, 2011 at 02:04 PM
cwebster
p.1 #2 · Charging battiers in car
Why use an inverter between the battery and the charger, you're just wasting energy.
Get a battery charger with a 12VDC input and connect directly to car's 12VDC supply.
<Chas>
Sep 24, 2011 at 02:07 PM
sboerup
p.1 #3 · Charging battiers in car
<Chas>
I'm looking to plug in multiple devices, so 2 plugs would be great. I'm not quite sure what you are suggesting though, have a link?
The inverter is converting DC energy to usable AC...am I missing something here?
Sep 24, 2011 at 02:09 PM
hondageek
p.1 #4 · Charging battiers in car
Yup, you're missing something. You don't need to go DC>AC>DC. Batteries are DC to begin with. Most chargers take household AC and convert it to DC to charge the batteries. All of my MAHA chargers came with a cigarette lighter adapter. You can get a splitter to plug into your car to charge several things at once.
Sep 24, 2011 at 06:07 PM
sboerup
p.1 #5 · Charging battiers in car
OK, I get the fact that the car is DC and so are my batteries. Where do I find a battery charger specifically for the Vagabond Mini's that plugs directly into a cigarette adapter?
If I went with the inverter for the sake of simplicity, am I really losing a lot of energy in the process?
Sep 26, 2011 at 01:20 AM
RustyBug
p.1 #6 · Charging battiers in car
http://www.paulcbuff-techforum.com/viewtopic.php?f=8&t=1620&hilit=car+charger
There's a thread on the PCB technical forum @ this.
The VML uses 16.8V whereas you car's DC is below this (not a good charging curve they say, i.e. battery damage, shortened life, etc.) ... they recommend going the way of DC/AC/DC ... specifically mentioning $19.95 @ Walmart/Walgreens, etc., i.e. no worries @ sine wave for charging purposes.
I've got a 100W B&D DC/AC that I use for camera batteries, etc. ... looked at getting a bigger one for the VML, seems like 200W is max you can use through your CL (fused). Larger than that and all I found require direct connect to your car's battery.
I originally bought two batteries to swap in/out with my VML ... have only needed AC mostly, but good to know that PCB is fine with DC/AC @ car for charging purposes.
Sep 26, 2011 at 07:28 AM
sboerup
p.1 #7 · Charging battiers in car
Thanks for the link! From Luap himself....
Sep 26, 2011 at 10:57 PM
Two23
p.1 #8 · Charging battiers in car
I use a Walmart DC--> inverter plugged into my cigarette socket. I then plug the charger for the lithium Vagabond into that to charge the Vagabond battery. Works like a charm.
Kent in SD
Sep 29, 2011 at 08:50 PM
