Archive 2011 · back up failure
ranankay
p.1 #1 · back up failure
I have windows 7 with two 500 g hard drives connected and I tried to backup my computer but it keeps failing , says the main hard drive is fragmented and stops the backup short.
any suggestions on what I should do ?
Thanks randall
Sep 09, 2011 at 10:55 PM
Bill Weaver
p.1 #2 · back up failure
Have you tried defragging the main drive?
Sep 10, 2011 at 05:49 PM
ranankay
p.1 #3 · back up failure
I thought in windows 7 it done that automatically
Sep 11, 2011 at 07:47 PM
Bill Weaver
p.1 #4 · back up failure
I just recently got a Windows 7 machine, and haven't found that feature yet.
The old fashioned way still works fine for me.
You are right, the auto defrag feature is there.
Amazing what can be found with just a little looking.
Sep 13, 2011 at 01:29 PM
Ernie Aubert
p.1 #5 · back up failure
What method are you attempting to use to generate the backup? There's a product called Casper that makes a bootable clone. I've been using it for several years; I've tested and verified that I can indeed boot from the clone, and I have my system again exactly as it was when I last ran Casper. No restoring necessary.
Sep 15, 2011 at 08:59 AM
kakomu
p.1 #6 · back up failure
What are you trying to back up? Are you attempting to clone your HDD, or are you just backing up your documents/photos/etc?
What program are you using to backup?
Sep 15, 2011 at 09:47 AM
TrojanHorse
p.1 #7 · back up failure
Get a bigger hard drive... 1 TB is under $100 now.
My defrag runs every wednesday night at 2 am or whatever... its likely yours does something similar, assuming you leave your computer on. Check the schedule.
Sep 16, 2011 at 03:04 PM
ranankay
p.1 #8 · back up failure
Yes mine defrags automatically -thanks Trojanhorse
Thanks Kakomu It's recommended by my system to backup all files when you purchase a new computer in case it's needed later and this is what I'm attempting to do. Maybe I should just disconnect all my external HD's and then try to do a backup.
Thanks Ernie ,but I wasn't really wanting to buy another piece of software /hardware
Sep 17, 2011 at 06:41 AM
EB-1
p.1 #9 · back up failure
You can get a 3TB drive for $110.
Sep 19, 2011 at 08:45 PM
