Archive 2011 · Ballhead for Feisol 3441
csebasti
p.1 #1 · Ballhead for Feisol 3441
I'm looking for a new lightweight tripod, and am leaning toward a Feisol 3441S or 3441T. If I do get one of these, I'll also get the short center column. I've been looking at the Photo clam ballheads to go with this, and would like get the largest ball diameter that will still allow the legs to fold backwards on the tripod with the short center column.
I haven't been able to find info on whether the PC-36N or the PC-40N will work, and its been about a week since I emailed Kerry at reallybiccameras.com to ask about this and haven't gotten any response.
Does anyone know if either of these ballheads will work still allow the legs to fold back all the way when using a short center column? I believe the PC-33N will, but I'd rather not go that small.
Chris
Aug 21, 2011 at 07:20 PM
pw-pix
p.1 #2 · Ballhead for Feisol 3441
The Feisol CB-50D works with a Feisol CT-3342 to allow the legs to fold back over the head. Check out the sizes of it here and compare to the Photoclam you want to see if it will be OK.
http://reallybigcameras.com/Feisol/Ballheads#CB-50D
The Photoclam Pro Gold II also works well in that arrangement
http://reallybigcameras.com/PhotoClam/Pro_Gold_II.htm
Aug 22, 2011 at 04:53 AM
Peyton
p.1 #3 · Ballhead for Feisol 3441
I have a Markins M10 on my CT-3442 - it is just slightly too large for the legs to completely fold back over the ballhead. I would imagine the Markins Emille or Traveler would be a good fit for this.
Aug 22, 2011 at 07:25 AM
peter_n
p.1 #4 · Ballhead for Feisol 3441
^ +1. I've tried the PC-33 and Markins Q3T and prefer the Markins. As you can see from the pic below the Markins' ball diameter is bigger than the equivalent PhotoClam.
http://www.nolan.com/forum_imgs/photo_clam_markins.jpg
Aug 22, 2011 at 09:26 AM
arvindb
p.1 #5 · Ballhead for Feisol 3441
I have owned Feisol for many years and loved it. It is very compact and can fit into a carryon bag. Very light weight. My Feisol was the first item that I would pack in any trip I had. I used an Acratech GV2 ballhead with it and loved this combo.
Rgds
Arvind
Aug 26, 2011 at 05:03 AM
jemkewl
p.1 #6 · Ballhead for Feisol 3441
Acratech GP-s is my recommendation. I use a GP on a 3472.
I love the open design of the acratech ... easy to clean and no need to worry about dirt or rust
Sep 09, 2011 at 02:19 PM
danob
p.1 #7 · Ballhead for Feisol 3441
I own both an Acratech and Markins Q3 both suit my Feisol well but the Markins is by far the best ballhead I have ever used.. Very smooth and even takes my 800mm F5.6 at a push..
Sep 11, 2011 at 08:39 AM
tuanv1980
p.1 #8 · Ballhead for Feisol 3441
The pc 36n or ns will fit into the ct 3441s or 3441t just fine. The pc 40 might be a little too large.
Feb 08, 2012 at 12:53 AM
peter_n
p.1 #9 · Ballhead for Feisol 3441
The thing about the Markins is its design. You need a ballhead with a max panning base and ball housing of 50mm for the legs to fold back parallel to the center column. The Markins Q3T has a max outside diameter of 50mm and a ball diameter of 38mm. Nothing else comes close to those specs as that is the largest diameter ball you can currently buy with an OD of 50mm on the base/housing.
Feb 08, 2012 at 02:23 PM
Jeff
p.1 #10 · Ballhead for Feisol 3441
Kerry told me that the ProGold II was the largest head that would fit without getting in the way of the legs. I'm pretty sure he said the 36 would fit, the 40 was slightly too big.
I got the ProGold II and am very happy with it. Anything larger and the 3441 would not fit in the bag, if you care about that. It's a great travel combo.
Feb 12, 2012 at 12:05 AM
