Archive 2011 · Samyang 35 mm f/1.4 for Astronomy
David Baldwin
p.1 #1 · Samyang 35 mm f/1.4 for Astronomy
Anyone out there had a chance to use the Samyang 35 mm f/1.4 at wide apertures for star photography yet? I am particularly keen to find out how well this lens deals with coma issues in the corners at f1.4 and f2 using full frame cameras.
Any sample images would be appreciated too. Thank you.
Jul 27, 2011 at 05:21 PM
paulesko
p.1 #2 · Samyang 35 mm f/1.4 for Astronomy
Maybe you already know, but lenstip do coma testing when they review a lens. You can have a look here for the samyang 35 1.4
http://www.lenstip.com/297.7-Lens_review-Samyang_35_mm_f_1.4_AS_UMC__Coma_and_astigmatism.html
http://www.lenstip.com/upload3/3378_sam35_koma.jpg
in case you want to compare, here you have the same test with the canon 35 1.4
http://www.lenstip.com/170.7-Lens_review-Canon_EF_35_mm_f_1.4L_USM_Coma_and_astigmatism.html
http://www.lenstip.com/upload3/2589_can35_koma.jpg
nikon
http://www.lenstip.com/286.7-Lens_review-Nikon_Nikkor_AF-S_35_mm_f_1.4G_Coma_and_astigmatism.html
http://www.lenstip.com/upload3/3332_nik35_koma.jpg
and the new carl zeiss
http://www.lenstip.com/307.7-Lens_review-Carl_Zeiss_Distagon_T*_35_mm_f_1.4_ZE_ZF.2_Coma__astigmatism_and_bokeh.html
http://www.lenstip.com/upload3/3427_zei35_koma.jpg
Jul 28, 2011 at 05:29 AM
Two23
p.1 #3 · Samyang 35 mm f/1.4 for Astronomy
So it looks like the Samyang is actually pretty good, and the Zeiss is the best of the lot?
Kent in SD
Jul 28, 2011 at 07:54 AM
morpheus2891
p.1 #4 · Samyang 35 mm f/1.4 for Astronomy
wow... spot size is awesome on the zeiss... coma well controlled on the samyang but the spot size isn't as good. still, for wide angle, artsy shots it should work (especially at F2)
Jul 28, 2011 at 12:49 PM
JimBuchanan
p.1 #5 · Samyang 35 mm f/1.4 for Astronomy
Nice comparisons of spot size between lenses.
Re: Astronomy, I hope the takeaway is that any of these fast 35mm lenses is not very appropriate for astronomy. It may seem counter-intuitive, but the best lens for stars is a slower lens with excellent corner image quality and a flat field, such as almost any of the Zeiss ZM wides, especially the 25 Biogon, the latest Leica R28 Elmarit, or slower versions of the ZE/F wides.
Point light sources will not be point light sources in the corners of faster, more difficult to correct lenses. Sensors don't have reciprocy failure like film, so there is less of a need for faster exposures. Current methods of astrophotography involve stacking multiple exposure frames in software.
Jul 28, 2011 at 02:33 PM
kf_tam
p.1 #6 · Samyang 35 mm f/1.4 for Astronomy
Dear Jim,
Please do understand that closing every stop means doubling the exposure time, and in astronomy the exposure time is in the minutes or even hours. In many area, there are too many rainy and cloudy nights, so when one fine, clear night finally comes it is just too wastful to close down too much (or use a lens too slow).
We usually combine multiple sub-exposure of minutes to get the equivalence of a deep exposure to get around dark current and reduce the possibility of screwing up (a night plane flying over). But it is still the same principle: you must get as much photons as possible to minimize noise, otherwise the image is not "presentable".
So the astrophotographer has to compromise in term of speed and image quality. Usually the corners are less important so if the image is good at the edge of APS format it is usually good enough. The truly poor corners can be cropped off later.
Jul 28, 2011 at 05:19 PM
pdmphoto
p.1 #7 · Samyang 35 mm f/1.4 for Astronomy
Are the lenstip coma tests done at infinity? If not, the posted results may not translate well for astronomy.
Jul 28, 2011 at 09:39 PM
JimBuchanan
p.1 #8 · Samyang 35 mm f/1.4 for Astronomy
Very good point.
Fact remains, coma will kill an astro photo. You want to see round stars, not butterflies. There is excessive coma in every one of these f/1.4 lenses.
Look what just one stop buys you in regards to coma: ZE35/2.0:
http://farm7.static.flickr.com/6024/5986715294_d5099744f7.jpg
Jul 28, 2011 at 10:31 PM
AhamB
p.1 #9 · Samyang 35 mm f/1.4 for Astronomy
They're not very specific about it, unfortunately: http://lenstip.com/2.2-article-How_do_we_test_the_lenses__Evaluation_criteria.html
Jul 29, 2011 at 03:07 AM
