Archive 2011 · Google Chrome: Color is OFF
JR Magat
p.1 #1 · Google Chrome: Color is OFF
I just bought a used 24" Apple Cinema Display to use with my MBP for editing. I love the screen already, however, I noticed that the colors I had open in LR3 were wayyyy different than what I saw on Google Chrome (it was my main web browser at home); looking at the same picture from my Smugmug. The colors in Chrome were a yellow/orange tint. I opened up my Smugmug in Safari and Firefox and the colors matched what I saw in LR3...
I did some searches online to see if there's an issue with Google Chrome and color profiles and saw this old thread:
http://www.google.com/support/forum/p/Chrome/thread?tid=3de2ee5284399d84&hl=en
Can anyone confirm that this is the case? Is there a setting/fix for this? I was at first freaking out thinking my monitor was not calibrated...
If it helps, the picture I am referring to is this (which looks fine on my work computer using IE):
http://jrmagat.smugmug.com/Events/Goodwill-Community-Church-1st/i-FtCPGNb/0/XL/JRP3552-XL.jpg
(do you see a difference if opened in Google Chrome as well?)
Jun 24, 2011 at 01:11 PM
Eyeball
p.1 #2 · Google Chrome: Color is OFF
Here is what I am sure about:
Chrome will not translate non-sRGB colorspaces to sRGB or your monitor profile. If you post an AdobeRGB or ProPhoto image to the web, it will look off independent of whether you embedded the proper ICC profile or not.
What I am less sure about:
If you are running Windows and use the "- enable-monitor-profile" switch, Chrome MAY map what it assumes is an sRGB image to your monitor using your monitor profile. I use the switch but honestly I'm not sure if it does anything or not. My monitor is not wide-gamut so I have to do detailed testing to find out and I just haven't taken the time.
If you are running Mac, then I think you are currently out of luck. I see people claiming that the Mac OS takes care of this for you but I find that hard to believe. Many people get confused on color management matters (including me ). On Windows, for example, the OS will pick up things like gamma adjustment and white point but it will not use the detailed profile mapping unless the application is color managed. I highly suspect that is also the case for the Mac but someone please correct me if I'm wrong.
Based on what I've read, the Chrome team has never paid much attention to the needs of photographers and graphic designers for things like color management. They seem to give a higher priority to speed (and color management can have an impact there) and trying to convert Chrome into an operating system. It's a shame, really, because there are a lot of things to like about Chrome.
Therefore, my recommendation would be to either use Firefox or Safari. My preference is Firefox since you can configure it to color manage images with missing profiles (essentially, it assumes they are sRGB) and also I get the feeling that Firefox may be slightly better than Safari in the security department.
Regarding your posted image, I don't see much difference between FF and Chrome, although I am on Windows and I don't have a wide-gamut monitor.
Jun 24, 2011 at 02:20 PM
JR Magat
p.1 #3 · Google Chrome: Color is OFF
Thanks for the info! It sounds like Google isn't set up for color management... which is a shame. I use Mac, so that could explain why I am seeing it more than you are.
I will be using FireFox; I prefer it to Safari
Jun 24, 2011 at 03:31 PM
ecidi
p.1 #4 · Google Chrome: Color is OFF
JrMagat, here is a good read and tutorial on Web Browser Color Management:
http://www.gballard.net/psd/go_live_page_profile/embeddedJPEGprofiles.html
Jun 25, 2011 at 01:59 PM
DougDolde
p.1 #5 · Google Chrome: Color is OFF
Looks pretty much the same to me in Safari or Chrome. Calibrated Eizo OS X
Jun 25, 2011 at 02:59 PM
ht1948
p.1 #6 · Google Chrome: Color is OFF
I just found out you can force Chrome to manage color, just follow this guide:
http://klyment.com/serendipity/archives/386-2010.05.17-Activating-Colour-Management-in-Google-Chrome.html
Jul 13, 2011 at 11:23 PM
DblDrgn
p.1 #7 · Google Chrome: Color is OFF
I think the latest beta of chrome is finally color managed. I downloaded it and have been viewing images side by side with firefox and it seems like it's identical. BTW, I'm using 17.0.963.38 beta
Jan 23, 2012 at 11:29 AM
