dan hillis Offline Image Upload: On
p.1 #4 · extension tubes on a 100macro | |
jmcfadden wrote:
It will make the distance to subject Very , Very small indeed , basically if you understand what a macro lens is actually doing , it is *adding* extension tubes to *itself* this is why if you put the camera in aperutre priority at the maximum aperture ie f3.5 and then turn the focus ring to 1:1 the aperture value will have increased somewhat because you are losing light as you gain extension
J
Thanks John! so other than making the distance to subject very small (short ?) it will not change the magnifaction? BTW how do you like that new D70. thanks again dan
