I see these RAID substitute enclosures came out last June and what a simple setup. I like simple. But it also needs to work well. I was hoping someone has a little experience and can recommend or not. Looks like CNET has given it a slightly higher rating, which is usual, than the user rating of 8.8 vs 6.9 of a possible 10.
Anyone have any personal use ratings? Cost is a bit high but do they work?
I have one. I love it. Over the last .. 8 months now.. it's taken about 5 minutes of my life. 2 of those were the actual physical install of the drives and software (the software is NOT necessary, but I like it because it checks for updates)
Another 1 minute was for installing updates. 2 or 3 so far. and the last 2 minutes to get SyncBackSE to run a realtime mirror from my SCSI drive (my temp photos area) to my Drobo, so that as soon as I download images, or as I edit, there's a realtime mirror of it.
Slow. Not glacial, but given that it's USB2, and creates parity on the fly across all its drives, it aint fast.
Certainly, the Drobo has it's flaws, and this, the lack of firewire or networking (natively, that's a 200 dollar upgrade), etc, are the drawbacks. They would be exascerbated if you used this for your main file storage.
I use it as a backup. I have all my files on other drives (scsi, large IDE) to view files quickly. The Drobo just keeps a second copy of it in case anything disastrous happens.
Oh and while they are both physically in the same location, I use Photoshelter for my online backup of all my files.
So if you use DROBO solely as external backup (with an offsite copy) why not just use external drives. And if they fail you get another and back it up again ?
Extra backup/security is built into the way the DROBO writes files across a maximum of 4 drives. If one of the drives goes bad, everything on it can be recreated from what's on the other three. As Max once explained it to me, even if two of the four drives go bad, you're still covered. Individual external drives don't provide that kind of safety net.
Russ, I don't remember saying that (or meaning to). If two drives (at the same time) go tits up, you may be pooched. Depends on the amount of data you have on there.
The Drobo is smart, and if you have the space for it, it will actually go from a 4 drive to a 3 drive config and start moving its parity files evenly across the drives.
But usually, it likes getting a drive back.
But, two drives going tits up probably means that you have some power issues. A UPS will make sure that anything sub-catastrophic should not be a problem. Anything catastrophic that would FUBAR your UPS would probably also kill you physically, in which case, you got other problems to deal with.
However as I understand it, it can run on 2 drives only, though with 4 bays, and HDD's as cheap as they are today, that's not really an advantage. Fill em up. Now is this a setup that one always leaves plugged in & running? Or is this only turned on for backup?
"Individual external drives don't provide that kind of safety net. "
I understand how DROBO works. (And think you should check their site because as the other poster said if you lose 2 drives you may be outta luck). I don't understand why DROBO makes. . You have the third copy. And also, the chances of two drives going at exactly the same time is remote. So if you primary goes. You have the ext drive. And vice versa. And as OutSideShooter points out you can also buy 2 ext drives if want. And you don't have to buy a DROBO box or deal with DROBO speed. I guess if you can't afford any downtime to do the replication of the failed drive then DROBO may be worth paying for ?
Max: Sorry for my misunderstanding and misstatement. Since I don't own and have not used a DROBO, I should just be watching rather than contributing to this discussion.......Carry on!
I will readily admit, that reading on Drobospace (the official drobo forum) that the polarity of feedback is a bit saddening. For some, Drobo is a worryless dream come true. Others? Good luck getting it to even register drives.
I got a good one, and am happy about it. Would I reccomend it to anyone else? Yes. But then
1) I'm a risk taker
2) If I lost it all, I wouldn't lose anything because I have a Photoshelter account as well.
It's more common than you might expect.. Two drives from the same manufacturers, from the same (presumably bad) batch, can fail at relatively close intervals. Google published a white paper on this a while back.
"can fail at relatively close intervals" doesn't equal at the same time. And in the unlikely event the one in a million happens, there is the third offline copy. Given the slow speed I guess I don't see how DROBO is improving over just stand alone external drives other than, as I mentioned, if you want to access DROBO while doing a restore of the main drive, I guess you could.
For this point, "at the same time" == "relatively close intervals" when the second failure precedes recovery from the first. How fast is this unit at moving the data, and how much additional stress it puts on the disks while recovering is info I will not venture to speculate about.
Hammy, that was, im sorry to say, hilarious. Well you wrote it well. But glad to hear your data is ok.
If it was just a little easier to work with, I'd say online storage solutions could be great, mostly because the cost is offset by convenience. With Photoshelter, I don't have to worry about keeping my drives on and the electricity cost involved. I don't have to worry about redundancy because they do that. nightly backup? they do that.
But instant access to all files is kind of a pain. It's not hard, just not... instant.
I've never used the Drobo so cannot comment directly about its operation. However, personally I'd much rather prefer to use NAS-based solution rather than USB. For the past two years I've been using a nice little "box" from BitLeap which sits on my network. It's basically a small form factor pc with multiple disks in a RAID array. It periodically checks all the folders I've marked for backup (every 10 minutes in my case) and backs up any new files or files that have changed. The unit itself can be configured as a backup appliance, file server, or both.
As an added level of security, I also subscribe to BitLeap's off-site backup. At regular intervals (again, set by me), all new and changed files are backed up offline to a secure offsite location. That site is then in turn backed up to another offsite location in another state. That effectively gives me 3 copies of my data. I can restore down to the file level through a web browser from anywhere that has internet access. Through that same web interface, I'm able to add folders to backup, monitor disk usage, and add additional servers to backup if I wish. On top of all that, the whole system is monitored and managed by BitLeap staff. For the price it really is quite robust.
One benefit of using BitLeap is that for a minimal additional cost per month, I can use the unit to connect to my network via VPN. Not only is the connection encrypted but it also connects through the secure BitLeap network giving you an additional layer of security.
I know that many people are leary of bandwidth usage when it comes to offsite backup. I've met with and spoken extensively to BitLeap staff and they've demonstrated how they've effectively optimized the entire process so that only small, manageable packets of data are transferred across the internet thereby reducing impact on my connection. As a company they've been around for several years, are very easy to contact and work with, and stand behind their products and services 100%. For instance, should my backup appliance realize a total failure, they will drop ship a new unit to me with all my data already restored. For someone who values their images and data, this solution is certainly worth it's weight in gold.
After spending 10 minutes I could only locate the one post in which he comments about the Drobo being slow. I suppose if one is searching for a file that would be a concern. A Drobo or any backup array is not for file searching, but for secure storage, so that does not deter me. I want ease & security.
PShizzy, this one user's comment from the CNET review, "We only wish Drobo came bundled with its own backup utility so that the important first step of data backup wouldn't be left to the whims of end users.", confuses me.
Because as you said, "
I have one. I love it. Over the last .. 8 months now.. it's taken about 5 minutes of my life. 2 of those were the actual physical install of the drives and software (the software is NOT necessary, but I like it because it checks for updates)".
What software are you speaking of? And what backup software would I need? Riht now I am using Synchback.
