This topic is in the 2010 archive. You can read it and like its posts here. It is read only.
Archive 2010Zuiko 1:1 Macro Lens 80 mm f/4
Bifurcator
p.1 #1Zuiko 1:1 Macro Lens 80 mm f/4
Hey guys, I was doing my daily lens shopping rounds until about an hour ago. The last item I inspected was the Zuiko 1:1 Macro Lens 80 mm f/4 for $430 - excellent conditionn. When I got home I looked it up:
http://www.alanwood.net/photography/olympus/macro-lens-80-4m.html#leaflet
http://www.mir.com.my/rb/photography/hardwares/classics/olympusom1n2/shared/zuiko/htmls/macrozuikoD.htm
... Oct 12, 2010 at 06:33 AM
rtester
Details
p.1 #2Zuiko 1:1 Macro Lens 80 mm f/4
You should be able to pick up one of these for under $200 and a set of tubes or bellows for under $100. So the price is very high.
I just picked up one to play with, not that I have the time right now, and will also get the newer model when I see one at the price I want. All this while I am waiting for the 90/2.
Are they worth it ? Value wise at $300 which is about close to what a non USM Canon 100 goes for? Hard to say, if you are looking for a good all around macro to get into macro work I would say no. Pick up a Tamron,Sigma,Canon or even a Phoenix. Shoot at AE and MF and dial up to f11 and actually get some comparable work with much less effort.
If you have time and cash and are just looking for the lens that gives you characteristics that may be unique, then yes.
Oct 12, 2010 at 07:39 AM
Ed Sawyer
Details
p.1 #3Zuiko 1:1 Macro Lens 80 mm f/4
These lenses (the 80mm Oly macro and auto-macro) are fairly unique in some ways. They are optimized for 1:1 specifically, and excel at that. The symmetrical layout cancels out many aberrations at 1:1 or close to it, by design.
The one pictured is the earlier version - the more desirable version is the later auto-macro 80mm (which needs to be mounted on tubes/bellows since the rear end of it sticks out beyond the lens mount plane). The later version is a $300-400/lens, and has a specific close-up lens attachment to go with it (also rare).
At or around 1:1 these are going to be better generally than an all-purpose macro like the canon's and Oly 90, I'd say.
-Ed
Oct 12, 2010 at 08:23 AM
Bifurcator
Details
p.1 #4Zuiko 1:1 Macro Lens 80 mm f/4
This one?
http://www.alanwood.net/photography/olympus/macro-lens-80-4a.html
And rtester, yeah that figures about the price. That particular shop misprices almost everything older than 20 years. Sometimes it's one tenth the price and sometimes it's 2 or 3 times the price. In this case two. I of course, go there for the underpriced ones. Like today I picked up the Zuiko 50mm 1.2 and the 1.4 for $20 and $10 respectively - both fairly minty! I was hoping the 80/4 Macro was like that too and worth 2 or 3 times what they had it tagged at. Oh well...
Oct 12, 2010 at 10:16 AM
AhamB
Details
p.1 #5Zuiko 1:1 Macro Lens 80 mm f/4
That's just absurd. One could easily pay 20-30 times (!) the price for that 50/1.2 in European and other countries...
Oct 12, 2010 at 10:35 AM
Bifurcator
Details
p.1 #6Zuiko 1:1 Macro Lens 80 mm f/4
AhamB wrote:
Bifurcator wroteLike today I picked up the Zuiko 50mm 1.2 and the 1.4 for $20 and $10 respectively - both fairly minty!
That's just absurd.
Yeah! But that's also what I say when I see US prices too.
Yup, $250 to $300 seems to be the going rate for the 1.2
Oct 12, 2010 at 10:38 AM
ManWearPants
Details
p.1 #7Zuiko 1:1 Macro Lens 80 mm f/4
I posted these info in the OM thread. I shall repost them here since it is a dedicated thread for it
additional read on the 1st and 2nd version:
first version -> http://www.alanwood.net/photography/olympus/macro-lens-80-4m.html
second version -> http://www.alanwood.net/photography/olympus/macro-lens-80-4a.html
There is an achromatic corrected x2.5 closed up lens from Olympus that can be screwed onto 49mm. This will give the 80/4 2:1 when used with the auto tubes 65-116. This is developed for the IS but can be used on OM lenses.
http://www.alanwood.net/photography/olympus/close-up-lenses.html
A-Macro: IS/L Lens A-Macro H.Q. Converter f=40cm
My opinion is if you are just using it with the auto bellow to get 80/4 1:1, it is a waste of money as there are lots of lens out there which can do this. But if you add the close up lens, then you have one of the smallest and lightest 80mm macro lens that can go up to 2:1 magnification.
BTW, I have been lurking around looking for one of these auto bellow with tripod. They do not come that cheap anymore. In fact, most of them are at the $200+ level. With the creation of this thread and a few pictures added, I am sure the price will soar further. I would think if you can collect the trio of bellow with tripod + lens v1 + close up for less than $400, it may be still ok. But it is getting hard.
BTW, you can use these macro lenses on Kenko extension tubes stacked up and with an adapter. Would come convenient if these tubes are already part of your kit.
$400 for version I of the lens seems to be on the high side. I understand the version II is selling ard that price. And do note version I serial starts with 2 while version II starts with 1. Don't buy those starting with 2 thinking that you have got the later version , like I did
Oct 12, 2010 at 10:44 AM
Bifurcator
Details
p.1 #8Zuiko 1:1 Macro Lens 80 mm f/4
Thanks MWP! Cool info!
Oct 12, 2010 at 11:34 AM
Ed Sawyer
Details
p.1 #9Zuiko 1:1 Macro Lens 80 mm f/4
Bifurcator -
yes, that's the 2nd version.
Those prices are crazy low for 50/1.2 OM. Usually a nice 50/1.2 OM will fetch well north of $500 USD on ebay, sometimes over $600.
The dedicated close-up lens for the 80/4 auto-macro that I was thinking of is this one:
it says:
This high quality close-up lens is specially designed for use with the Zuiko MC Auto-1:1 Macro 80mm f/4.0 lense to extend its magnification range with the Telescopic Auto Extension Tube 65-116 from 1X to 2X. This close-up filter/lense is believed to have been multicoated and it also accepts a 49mm threaded filter.
It is use by mounting at the front of the 1:1 80mm Zuiko Macro lense and removable. A wrench is also came with the lense for easy removal of the filter. Olympus warns avoiding using this close-up lense with any other Zuiko optic other than the Zuiko MC MACRO 1:1 80mm f/4.0. Further, the use of this unit for magnification 1.2X or lower is NOT recommended because the lense itself can offer a better performance when used alone. During operation, always stopped the aperture down to f/5.6 or smaller for better optical results. Olympus also suggests the compatible focusing screens when used for macrophotography with such combination are 1-4, 1-10 and 1-11 types.
More info on this particular piece on Alan Woods' site:
http://www.alanwood.net/photography/olympus/close-up-lens-170.html
I actually have this whole setup (65-116, auto-macro 80/4, and f=170cm close up lens) but haven't had a chance to use them much. I may consider parting with it all.
Olympus OM stuff was as good as it got in the day for Macro. They (olympus) were very into it, and regarded it as one of the pillars of the OM system.
-Ed
Oct 12, 2010 at 11:52 AM
melcat
Details
p.1 #10Zuiko 1:1 Macro Lens 80 mm f/4
I've had one of the early versions sitting in a cupboard for years. It came with the bellows, which I broke on the first outing (poor aluminium casting, if you ask me).
What looks like a focussing ring in the picture is the aperture control. This is a preset lens. There is no focussing helicoid, so you need a bellows. On the other hand, the preset is going to be more convenient than the auto aperture when adapted to Canon.
I found this bellows for Canon:
http://www.fotodiox.com/product_info.php?products_id=501
No idea about the quality, but I was less than impressed by the original OM one.
Oct 13, 2010 at 01:58 AM
ManWearPants
Details
p.1 #11Zuiko 1:1 Macro Lens 80 mm f/4
Which bellow are you refering to that has poor alu casting?
This one?
http://www.alanwood.net/photography/olympus/telescopic-auto-tube.jpg
Oct 13, 2010 at 07:11 AM
debuggerus
Details
p.1 #12Zuiko 1:1 Macro Lens 80 mm f/4
congrats on the 50/1.2, Bifurcator. Great find!
Oct 13, 2010 at 07:27 AM
melcat
Details
p.1 #13Zuiko 1:1 Macro Lens 80 mm f/4
This one?
No, it was an actual bellows with concertina-like material. What you show is the Auto-Tube 65-116, which came much later and would have been spun or pressed and welded rather than cast. I think it was usually bought with the 135mm macro but I never saw either piece when I was actively buying this stuff in the 1990s.
While the lenses aren't too bad, the weakness of some of the ancillary gear in the OM system was something most system users got to know. Cracking Shoe 4's for the OM-2N and feet that broke off the T-32 flashes were the rule. Of course the bellows I broke was bought used.
Oct 13, 2010 at 07:44 AM
Krosavcheg
Details
p.1 #14Zuiko 1:1 Macro Lens 80 mm f/4
Bif, for that price you can pick up the lens, enlarger lens and auto bellows...
Oct 13, 2010 at 08:24 AM
FM ForumsLeica & Alternative GearJoin Upload & Sell
