This topic is in the 2010 archive. You can read it and like its posts here. It is read only.
Archive 2010Mamiya 55mm F1.4 - Worth it?
Jos Tesseract
p.1 #1Mamiya 55mm F1.4 - Worth it?
A Mamiya Sekor SX 55mm F1.4 has caught my eye. Can be had for just over $100. Is this one worth going after? I haven't found a whole lot about it online.
Jan 05, 2010 at 08:41 PM
Jos Tesseract
Details
p.1 #2Mamiya 55mm F1.4 - Worth it?
No one has anything to say about this one?
I'll take that as a "pass on this one"
Jan 06, 2010 at 05:52 PM
Details
p.1 #3Mamiya 55mm F1.4 - Worth it?
Not necessarily. Make sure it's a M42 mount (which it should be for a SX body, see links), and then you're on your own. At $100, it's a little more expensive than a SMC Takumar 50/1.4 (which has excellent multicoating). I expect the Mamiya has single coating, not that there's anything wrong with that.
http://herron.50megs.com/ZE.htm
http://freenet-homepage.de/stauber/mamiya-nc/m42_lenses.htm
Jan 06, 2010 at 06:55 PM
viczig
Details
p.1 #4Mamiya 55mm F1.4 - Worth it?
Hi,
I had a non SX version for a while, nice sharp lens on par with the Takumar 1.4. I think at $100 bucks its overpriced.
Jan 06, 2010 at 08:30 PM
Uruhkai
Details
p.1 #5Mamiya 55mm F1.4 - Worth it?
In my experience with Mamiya SX, the lens usually gets a kind of ridge/rim in the aperture ring that prevents it from fitting 100% with the adapter ring.
If you go for this lens, make sure the ridge/rim has been flatten, otherwise there will be no infinity.
Jan 06, 2010 at 11:36 PM
Alf Beharie
Details
p.1 #6Mamiya 55mm F1.4 - Worth it?
One could argue that its not worth going after any 50mm-ish f1.4 lens when you can get a f1.2 version for the same money.
$100 may seem cheap but you could get a Canon FL 55mm f1.2 for that sort of money.
Jan 06, 2010 at 11:42 PM
Details
p.1 #7Mamiya 55mm F1.4 - Worth it?
Yes, but you can't get infinity focus with an older manual focus Canon lens on a newer Canon AF body, without either an adapter with optics (degrades IQ) or a mount change (increases price).
Jan 07, 2010 at 07:16 AM
Yakim Peled
Details
p.1 #8Mamiya 55mm F1.4 - Worth it?
I saw the topic and my heart leaped but it was just for a moment. It is not a M645 lens.
Happy shooting,
Yakim.
Jan 07, 2010 at 08:39 AM
gasrocks
Details
p.1 #9Mamiya 55mm F1.4 - Worth it?
I had the Mamiya SX and sold it, just was not special, to me. I also sold my Pentax 1.4, didn't like the bokeh. Yes, Canon 58/1.2 or 55/1.2 can be gotten for $150, but then you have to find someone to convert it for you. Sold my 58/1.2, kept the 55/1.2.
Jan 07, 2010 at 08:42 AM
georgweb
Details
p.1 #10Mamiya 55mm F1.4 - Worth it?
Chirp chirp chirp,
M42 Mamiya Sekor SX 1.4/55 @f/1.4 no crop no pp on K100D tungsten WB jpg all neutral
According to Frank Mechelhoff @taunusreiter.de you are getting with this lens a multicoated Contarex Planar (1959 design). This is the predecessor of that monster Planar which followed (1972 til today). The older design smokes the new one in bokeh but will not win the sharpness contest. However, at f/2 onwards and definitely f/2.8 onwards it'll not be shabby either. For me it's the perfect allround lens. If you have a Canon DSLR you have the choice to get the Rolleinar MC or Voigtländer AR versions both in Rollei QBM mount (and spare tinkering).
Here's some more chirping and also what to file and cut off,
http://www.pentaxforums.com/forums/pentax-slr-lens-discussion/85327-mamiya-dtl-55mm-1-4-opinions-compatabillity-issue.html
Best of luck, Georg
Jan 10, 2010 at 05:55 PM
Ataboy
Details
p.1 #11Mamiya 55mm F1.4 - Worth it?
I have Mamiya Auto-Sekor 55/1.4. It is fun. Wide open it is somewhat dreamy and has interesting bokeh, I'd say it gives pictures retro look:
http://i859.photobucket.com/albums/ab156/apolskoy/Samples/_MG_2316.jpg
Stopped down it becomes your usual perfectly sharp f/1.4 prime lens with excellent colors:
http://i859.photobucket.com/albums/ab156/apolskoy/Samples/_MG_2345.jpg
Jan 10, 2010 at 08:21 PM
FM ForumsLeica & Alternative GearJoin Upload & Sell
