This topic is in the 2009 archive. You can read it and like its posts here. It is read only.
Archive 2009Cut Bokeh Circles
ptys
p.1 #1Cut Bokeh Circles
I didn't know which part of the forum this belongs to, but since it's gear specific, I decided to put it here.
I noticed that my Minolta 58 1.2 cuts bokeh circles at the bottom of the frame. It only happens wide open at the bottom of the frame. It goes away around f1.4-f2
http://farm3.static.flickr.com/2639/4227630772_95d90b9f5f.jpg
This is in portrait position, and the physical bottom of the frame is on the left side. I googled around and found only one post on flickr about this. The poster stated that the only wide aperture lenses (s)he knew not to suffer from this are Leica (on Leica bodies). This was taken with Canon 7D.
Is this expected? My 50 1.8 doesn't do that, but neither does the Minolta at 1.8.
Thanks.
Dec 31, 2009 at 02:07 PM
mt-m
Details
p.1 #2Cut Bokeh Circles
This happens when mirror box interferes with optical path. Happens more with cropped cameras with smaller mirror boxes.
Dec 31, 2009 at 02:57 PM
Dpic_arctic
Details
p.1 #3Cut Bokeh Circles
I have no idea.
Stop down to f/22 or something like that. Press the DOF preview button. The shape the blades make (point the lens at yourself while the DOF preview is on) is going to be the same shape as OOF highlights. Maybe one of the blades is caught, so it isn't closing to complete the circle. Just a guess.
Dec 31, 2009 at 03:35 PM
mMontag
Details
p.1 #4Cut Bokeh Circles
ptys,
Put this over on the Alt Gear Forum - a.k.a. - the Rokkor Channel. You'll get a lot of responses - they're busy with Zeiss right now and could use a good new Rokkor thread.
I know this has been discussed before - you could try a search.
mt-m - you may be correct, however, I get the truncated cat's eye on a full frame.
Dec 31, 2009 at 04:21 PM
EB-1
Details
p.1 #5Cut Bokeh Circles
+1 on the mirror box.
Dec 31, 2009 at 06:46 PM
mt-m
Details
p.1 #6Cut Bokeh Circles
"cat's eye" effect is internal vignetting of the lens elements. Vertical or horizontal cutoff is definitely the result of the mirror box. It happens on full-frame cameras too.
Dec 31, 2009 at 07:54 PM
dcains
Details
p.1 #7Cut Bokeh Circles
Me, too. This is with my EF50/1.4 on my 10D:
http://deanwcains.smugmug.com/photos/118082495_ctkHR-L.jpg
Dec 31, 2009 at 08:32 PM
Dpic_arctic
Details
p.1 #8Cut Bokeh Circles
I'm thinking now that it has nothing to do with the aperture blades, otherwise all of the bokeh would be identical.
Dec 31, 2009 at 08:41 PM
dcains
Details
p.1 #9Cut Bokeh Circles
Here, you can start to see the result of the aperture blades. Same setup, but this shot is at f/2.8 versus f/1.4:
http://deanwcains.smugmug.com/photos/118082852_p8Dig-L.jpg
Looks like it must be the close proximity of the flipped-up mirror to the top of the sensor (the image is flipped, in-camera) that's the culprit. There's much more clearance near the bottom edge of the sensor because of the well the AF sensor assembly sits in.
Dec 31, 2009 at 08:47 PM
Ian.Dobinson
Details
p.1 #10Cut Bokeh Circles
Dpic_arctic wrote:
I have no idea.
How could this be? as it would show in all the circles and the OP states it only happens wide open not stopped down even a stop
Jan 01, 2010 at 04:45 AM
Dpic_arctic
Details
p.1 #11Cut Bokeh Circles
Dpic_arctic wrote:
I have no idea.
Yes, I changed my mind about that, as I noted in a couple posts up.
Jan 02, 2010 at 04:04 PM
FM ForumsGeneral Gear-talkJoin Upload & Sell
