So Amazon delivered a brand spanking new Canon 7D this afternoon (finally!) - hitting reload a bazillion times paid off! ;-)
So the first thing I did (and you may want to do also) is a quick check for dust bunnies. Basically shoot a white LCD screen the smallest aperture available, pull it into Photoshop, do an auto-tone (or equalize), and they'll jump right out at 'ya, especially at 100%.
NOW ... they are pretty scary looking when you do that ... but be sure to go back to the original image to see what it actually looks like ... and then ask yourself how often you shoot at F/32 ... they become much less visible as you open up.
Attached below are two images from the very first shots with the 7D. Did it ship absolutely spotless with ZERO dust on the sensor? Not quite as there are a couple of dust bunnies there - click through to a full-up analysis at various F-Stops.
However, is it worth cleaning your sensor for these - not for me. And my battery is almost charged, so I'm going shootin'! ;-)
alek
P.S. It's not a bad idea to archive these images so you have a baseline for future reference.
I got mine but did not check for dust. If you see this as you have, just run the sensor shaker in there a few times it will probably clean it. When I got my 40D it had some dust, but it cleaned itself up 100%. I've never had to use the senor cleaner on the 5DmkII, the shaker does well.
My 40D gets dust bunnies from time to time, maybe not that big, but they go away on their own. The sensor cleaning really makes a difference compared to older cameras without
