already put this in the master thread, sorry sorry for the extra post, but since that is now crazy long for anyone to wade through and mostly just earlier speculation or when is my copy getting here, though I would post it out here too.
Initial 5DMkII Sport Shooting Thoughts:
so I got to shoot half a match of men's NCAA soccer today.
originally, before release, I harped a lot on the 5dmkii's old AF,shutter,mirror. I guessed the AF would be the most annoying thing for sports, followed by mirror blackout, fps and then shutter lag. I have changed my mind about some things and certianyl that ordering.
I was in a rush and originally forgot to turn off the IS on 300 and I had not field set the micro-focus calibration or set the center point AF expansion.
I started looking things over and was like oh nooo, this isn't better than the 50D is it? it's not even as good. it has to be. it is. but is it really? but I did keep in mind I had been playing with the stuff mentioned above.
Anyway, most happily, all of a sudden part way through the shoot it was just shot after shot after shot with bang on perfect focus! Maybe it was the IS messign with it at first, or maybe the center expansion made the largest difference, etc. whatever the case once I got it set how it should be set, I was actually pretty impressed. Granted it was the sort of lighting that my 40D and even 20D had done the very best at, when ti came to sports shooting, so this is hardly the definitve test, there was no glaring sun or backlighting (which both seemed to make my 40D almost entirely blind at times). All the same, it really did seem to pass with flying colors. Definitely a step toward the 1 series from the xxD. I don't recall getting any better precision the few times I got to use a 1DmkIIn for a bit of soccer.
When I put on the TC results did go down. Maybe I didn't set the MF adjust ideally for that combo. Maybe the TC always puts on this much of a hit and a native lens like a 500 f/4 or whatnot would do better. Or maybe only a 1 series can deliver the 1/3 DOF at f/4 and critical shot after shot for sprots at these high apertures. Anyway, at least it was not worse than a 300 + TC on a 50D (and was better than my 20D and 40D did with that combo, as is the 50D).
But my first impression was that it seemed pretty sports capable, at least with fast lenses and comfortable lighting. Can't say more yet. There were somewhat less direct on charges than normal so that didn't get quite as solid of a test either.
The fps are just DOG slow. DOG SLOW. Nearly useless for action sequences since by the time the 2nd frame comes around the action if often too out of ideal spot. I mean it is better than nothing, and ok maybe I'm overstating a bit, but you do get noticeably less double key pics per sequence than at 5fps and lots less than at 6.3fps. That said, often the best pics of all are the one shot timed ones, so maybe it's not so bad. I'd need to shoot another full game to see how badly or not it impacts take.
The shutter lag IS pretty beastly too. It's not quite so bad that you can't learn to adjust to it and I think I should be able to reliably adjust. Sometimes it is just too slow to catch a moment since you can't always anticipate in time. So you will lose some shots, again I can't say how many yet.
When I picked up my 50D again my god did it feel fast, felt like it was 15fps and 10ms lag and like it was going to run out of my hands though so yeah the xxD series, at least the current models, do entirely smoke the 5DMkII in terms of body performance feel, aside from AF (where 5d seems as fast as the fastest xxD and faster than the older xxD and likely better than all aside from perhaps the outer focus points).
But anyway if you focus a bit more on key one shots and learn to adjust to the shutter lag, the AF does seem to do pretty damn well with my 300mm f/2.8 at least under those fairly ideal shooting conditions, which is a lot better than I had feared. I'm honestly not sure the 1DMkIIn I've tried a few times would've done that sequence of shooting I did there today any better at all in terms of AF with the fast lens.
I'm almost thinking that I might end up not having any gripes about the AF in the end at all. But there are plenty of things I have not done with it yet.
I should add that I tend to almost never use the outer AF points, so I really can't say about those, quite a few people are saying they are awful and worse than the 40D/50D, but I have no clue.
All in all, despite the shutter/mirror/fps, I'm actually reasonably excited about it for sports.
Did you get around to micro-focus calibrating the camera to the 300 2.8 during the event, if so, did you notice much of a difference? You may not have had the camera long enough to judge, but I'm curious if you've found the need to micro-focus calibrate it for each event you cover and how easy it is to determine focus drift with the higher resolution display?
Thanks, Ron
i had done some MF adjust in the house, but then the first few shots from teh game were way off so I dialed in 2 less correction and later on i think i fiddled a little more and it seemed to be perfect then.
The new cams (50D and 5DMkII) let you zoom into a full-size (if heavily compressed) preview jpg and it does seem to be good enough to check it in the field. So that's much nicer than the old cameras.
Thanks for the posts! This is really useful to me as I have a 5Dii pre-ordered but am worried about AF performance. I'm going to post a request for fedback from sports shooters and let's see what else we can find out.
apdieb wrote:
Here is another just for the heck of it.
No offence, but where were you sitting when you shot these It doesn't look like these were shot at ice level and it looks like you were able to get away using only the centre AF point.
When you are shooting this loose, and far away from the action to boot, the 5DII AF performance should be able to keep up and the burst/drive rate should be your only issue. However, I think if you were closer to the action and needed to use any of the outer AF points, you wouldn't be as happy with the AF performance.
Khurram, nobody here's stating the 5D2 is a sports cam. Notably the lack of reliable AF on anything but the center point in dim lighting (if its successor is anything to go by) will get in the way, as do the other points stated above: low shutter speed and shutter lag. Knowing these shortcomings, I'm impressed with the accounts above and the shots posted and I think that's what the posters meant.
BTW, in your samples it seems center point AF would have done nicely, at least for the first two images
khurram1 wrote: apdieb wroteHere is another just for the heck of it.No offence, but where were you sitting when you shot these It doesn't look like these were shot at ice level and it looks like you were able to get away using only the centre AF point.
Yep. You may be correct. I wasn't sitting.. I was on the lower level observation deck. I have 2 more games this week Wednesday and Friday. I'll try it out when at ice level.. (I did try it out directly on the ice however....Just between periods though.. ).
For the record, I rarely, if ever, use anything other than the center AF point (while shooting sports)... both with my 1DMkIII or any other body I own...
Well I tested it at ice level tonight with an 85F1.8 lens. Darn AI-SERVO on the 5DmkII tracked just fine in very similar circumstances as your examples. I'll post a few shots as soon as they finish downloading....
For the record though...the FPS is a huge drop off when switching from the 1DMkIII. But the AF performance was just fine even at close distances.
Emile, I have been playing with my 5D2 with the 35L 85L and 50 1.4. Wide open min focal distance at all focus points. I am very surprised almost amazed at how accurate and how quick the non center points have worked. I have just been shooting around the room the black dog (I have a red on and a spotted one too). I too have have been blown away with AF performance in servo with the 100-400 when playing with the video at a soccer game. No images to post I have deleted them after looking the files are huge.
hhski wrote: Emile Gregoire wroteKhurram, nobody here's stating the 5D2 is a sports cam. Notably the lack of reliable AF on anything but the center point in dim lighting (if its successor is anything to go by) will get in the way, as do the other points stated above: low shutter speed and shutter lag. Knowing these shortcomings, I'm impressed with the accounts above and the shots posted and I think that's what the posters meant.
BTW, in your samples it seems center point AF would have done nicely, at least for the first two images Emile, I have been playing with my 5D2 with the 35L 85L and 50 1.4. Wide open min focal distance at all focus points. I am very surprised almost amazed at how accurate and how quick the non center points have worked. I have just been shooting around the room the black dog (I have a red on and a spotted one too). I too have have been blown away with AF performance in servo with the 100-400 when playing with the video at a soccer game. No images to post I have deleted them after looking the files are huge....Show more →
Good to hear! Note that I said anything but the center point: on my 5D the center AF point is as good as it gets in Canon-land. The other AF points however are a mixed bag and not really suited for work with the same lenses you named. 5D + 35L is probably my all time favorite combo (using center point or manual focus). Anyway: congrats on your new cam & enjoy it!
Venus wrote:
5DMK2 is designed for slow work. But no one ever said it cannot be used for sports or wildlife. 1DMK3 is designed for high speed action.
Sad thing is... Comparing my shots from the hockey game (both my 1DMK3 and 5DMK2)... I gotta say my 5D images were sharper. Just not as many of them...
Shooting Red Wings/Stars tonight... Probably try the combo again...
I don't think the center point is any worse than the 1d3 in terms of accuracy or speed. Also, not all sports are fast moving, and not all wildlife runs!
