fredmiranda.com Login
This topic is in the 2008 archive. You can read it and like its posts here. It is read only.
Archive 2008AF Problem with 1D Mark III -my case
PasiM
p.1 #1AF Problem with 1D Mark III -my case
Had to take my 1D Mark III to a repair shop after two months of purchase.
Right from the start i was wondering why 30-40% of images taken was not correctly focused.
They were either back OR front focused.
Actually AI Servo gave better results than One Shot!!
I tried all settings imaginable.
This happened especially whwn using 16-35mmL 2.8 II and 24-70mmL 2.8
Strangely 70-200mmL 2.8 IS USM worked much better all the time.
All lenses i used worked perfectly with my 5D.
Normally i use RAW only but once i had a customer who wanted pics for his web site only and i decided to use sRAW.
I was amazed. Every single image was pin sharp!
Never happened with RAW.
I made testes few times again with same results.
By serial number this copy should not be on the "sub-mirror-focus-error-list"
Any one else have similar probs?
Edited on Jan 25, 2008 at 12:11 PM
Jan 25, 2008 at 12:06 PM
johnnydanger
Details
p.1 #2AF Problem with 1D Mark III -my case
My 1D3 exhibited 'wandering focus' in one shot mode as I like to call it. Tripod mounted, high contrast black/white illustration as subject, 10 shots with remote cord and 50%+ of them AF incorrectly (especially at f1.2-f2.8). Like the camera just couldn't pull focus but gave an OK focus acquired beep anyways.
Maybe sRAW was sharp because the smaller file condensed the blurry detail into something more sharp?
My 1D3 is at Canon getting the sub-mirror fix now so we'll see what comes of that.
Jan 25, 2008 at 12:50 PM
Greg Schneider
Details
p.1 #3AF Problem with 1D Mark III -my case
Bingo.
Jan 25, 2008 at 12:58 PM
PasiM
Details
p.1 #4AF Problem with 1D Mark III -my case
No Bingo
Even if it´s a smaller file you can detect where the actual focus point would/should be.
As i mentioned above when using normal RAW mode it was visibly front/back-focus issue which was highlighted especially using wide apertures like f2.8.
This was not the case with sRAW.
I know this sounds weird but it happened.
Edited on Jan 25, 2008 at 02:34 PM
Jan 25, 2008 at 02:31 PM
