I haven't tried BIF, as it's not normally what I photograph, but did cover a triathlon a few days ago. I photographed mostly the cycling portion as well as some of the run using the Mark III and 400 2.8 IS with and without the Canon 1.4x TC. In general results were good, though I was not blown away compared to the Mark II N. With the N and past 1D cameras I've primarily been a center point user as results with the peripheral non-cross sensors, particularly those farther from the center, have usually been inconsistent. So, of course, up until that event I'd been using the Mark III primarily with the center sensor. It's how I started covering the bike portion of the triathlon. Here the center sensor can work well because it usually falls on the handlebar and since most riders typically hunch forward with heads in line with handlebars, has worked well in the past. Initial review on the camera's display indicated that results were probably similar to the N but didn't seem spectacular. There were too many instances where the AF focused on the crotch or stomach, probably mostly due to inaccurate AF point placement by me. And there were entirely OOF shots as well as series of OOF shots. Part way through I decided to switch to the top most AF point (in vertical orientation) in order to focus on faces as it would be easier to maintain AF point placement. Post race editing on the computer indicated this resulted in better, more consistent focus on faces, which logically shouldn't be a surprise, but based on past poor experiences with pre Mark III AF points way off center, did come as a relief. I was able to get very good sequences of riders at a second location traveling up to about 30 mph along a sweeping downhill bend from full length to very tight upper torso and handlebar compositions. But I never got a sequence where all frames were perfectly focused. Often the first frame was off or at least maybe one or two images per sequence would be soft, but generally results were very good. With the 1.4x TC the number of keepers did drop, likely due to the loss of cross type AF sensitivity. This portion of the race did present lighting issues as it was late morning overhead sun, which resulted in strongly shaded faces. Exposure was 2/3 to one stop brighter than I normally would set on the Mark II N in full sun but with highlight tone priority enabled, the Mark III kept highlights from blowing while allowing usable shadow information to be retained.
Surprisingly I experienced more AF issues with the run than the bike portion. There were instances where maybe only 50% of a sequence was sharp, with the soft images generally backfocused a foot or two. Since runners are much larger than BIF, I wouldn't expect AF to pick up the background in this situation and I don't think it was trying to in cases of OOF shots. Looking at this more closely, the problematic sequences were all backlit and generally of runners with plain tops, which therefore were lower contrast and a greater challenge for AF lock. Some had bib numbers placed where the AF point would pick it up, but I suspect that the up and down motion from stride to stride would move the bib number off the AF sensor and possibly cause issues. AF here was center point only with no AF expansion (I had expansion turned off the entire day). Perhaps expansion could have helped AF retain a better lock. CF III-4-0 was set, which would seem to be the logical choice since there was generally no issue with something else suddenly crossing in front of the runner for AF to lock onto and III-5 was not activated (I generally leave it off as it is then obvious that AF can't find a lock when it starts hunting). AI Servo tracking sensitivity was at the default middle setting.
My suspicion that AF placement could be part of the issue has been somewhat verified by examining a few hundred of the bike and run images in Imagebrowser (Canon's Mac version of Zoombrowser?), which has a function to overlay the AF array and indicate where the active point of focus is located for a given image. Many of the images that were off, were so because the AF sensor was not placed where I thought it should have been, namely on the face of a cyclist. It was often on a shoulder or upper torso area below the face, hence the reason I was seeing a lot of shots focused behind a riders face. There were still some images, particularly with the running shots, where the sensor was correctly placed on the subject yet focus was a couple feet behind. But, I would guess that of the overall images not correctly focused, a majority were so due to inaccurate user placement of the AF focus point... accounting for perhaps around 2/3 of the images, particularly for the cycling shots. But where the AF point was correctly placed and the focus was off, it seems to have happened more at farther camera to subject distances, though here a similar degree of AF error would appear to be more significant than at closer subject distances. The misfocused running shots trouble me more in that they seem to indicate that my Mark III (like any AF SLR) is having some degree of difficulty focusing on backlit low contrast subject matter (troublesome because I often prefer to shoot sports backlit). Looking at those images in Imagebrowser, the high contrast bib number in many instances does move onto and off the active AF point from frame to frame and may account for the poor results. It'll be a matter of finding the optimum CF settings to counter this.
After reading the BIF concerns on the naturescapes forum and other places, and after examining my results from the triathlon and a few other sports events (hockey and soccer so far) it does seem that AF on the Mark III is considerably different from past 1D cameras. There are certainly more options to adjust which in turn likely affect AF performance. In particular I wonder if AF point placement is much more critical.
Since I'm generally photographing people in motion, I will try turning on AF expansion and experiment more with AF tracking sensitivity based on the nature of the subject matter being photographed. Sometimes it's sports where there is frequent brief obstruction of the main subject by others running in front, like in football, soccer, hockey, etc. so it will be interesting to see how this setting may affect results. A recent suggestion on the naturescapes thread is to set the AI Servo sensitivity to fast rather than slow, which I am beginning to think might be a good idea for situations where a clean line of sight on the subject is usually the case.
Perhaps those having AF issues with BIF should view their problem images in Image/Zoombrowser to get a better feel for whether or not the active AF point was really located where they thought it should be.
Not the same as BIF, but I posted a couple cycling sequences here: www.pbase.com/scheffler/iii_focus
These are the original Sjpeg files straight from the camera, hence the horizontal orientation, as I guess the rotation tag is not recognized by pbase. If you download the original versions and view in Image/Zoombrowser you'll see that at times AF point placement was correct but AF was behind the subject a couple feet while other times placement was not exactly on the face and focus is precisely on the AF point. Therefore my conclusion so far is the Mark III AF is generally very good, but not flawless and I need more time to optimize the CF settings to improve my results. I'm also not ruling out some flaky behavior by this camera, which is serial 505xxx and has firmware 1.0.8.
