I have an opportunity to buy a Nikon 6T diopter to go with my 200mm Micro . Has anyone ever tried this on a Nikon 200mm AF D Micro lens ? I would like to try some extreme close up's this summer but I do not want to waste my money if this combo does not work well . 6T dipoters are not ultra expensive but they are not free either .
I happen to have the 6T and the 200 micro. I have never thought about using these two combined as I have never been a big fan of the 6T, however your query peeked my interest.
I went and shot a real quick comparison (15 minute total setup through web download) and these measurements are approximate, so take this imformation with that in mind. Both were taken at approximately the closest focusing distance. With the 6T the distance was about 18 inches subject to film plane and without the 6T the distance was about 28 inches. Magnification is around 2 to 1 with the 6T and naturally 1 to 1 without it. Exposure on both was 2.5 seconds @ f/18 using my crappy little desk flourescent lamp. I also didn't take the time to properly set up the shot (ie., lighting, no mirror lockup and crappy focusing), however conditions for both shots were the same.
If you would like I could do a proper test, but I think in general this will give you some idea. The smaller outlined areas are 100% crops for each respective capture.
Thank you VERY much for the test result data . I really appreciate it GSteele .
I think that these images speak for themselves . The added magnification is certainly there , but , I am not too sure if I am willing to live with the effect on image quality . Hmmm..... ,
Thanks again for your extra effort . It's helped me a LOT .
Rob
"As with all AF Micro-Nikkors, the close-up lens should probably be mounted in a reversed position to ensure optimal corner-to-corner sharpness. When the 200 ED is applied to landscape photography, f/11 is the optimum (and only) setting that renders corner-to-corner sharpness."
What? How can you mount a filter in a reversed position?
"What? How can you mount a filter in a reversed position? "
Reversing rings are commonly available in various sizes. They have two male threads instead of the typical male/female threads found on filters and contain no glass. I use them all the time for reversing not only filters but lenses for extreme macro work. I made my first one by knocking the glass out of two scratched filters and super gluing them with the male threads left out in both directions.
Right. I have seen them for lenses but I had no idea that someone would do this for filters. Why don't you just get a spanner wrench to remove the filter from its mount and then put it back into the mount reversed?
Why don't they just place the filter in reversed in the first place if it is such a great idea?
